bondy Posted July 2, 2016 Share Posted July 2, 2016 this is 1 am going to be rebuilding. 4 Quote Link to comment Share on other sites More sharing options...
speshal Posted July 2, 2016 Author Share Posted July 2, 2016 Ooooh shiny! Quote Link to comment Share on other sites More sharing options...
bondy Posted July 3, 2016 Share Posted July 3, 2016 (edited) yes it is a clean Engine same as my 340 thats been rebuilt i did have the 1 in the photo vapor blasted then i had to polish the cases myself turned out nice. i have the earlyer 198 ignition case on this 198A it will be red and silver ith the Alloy bash plate the frame is also a 198A i have put the bigger Airbox on it. Edited July 3, 2016 by bondy 1 Quote Link to comment Share on other sites More sharing options...
smelling123 Posted July 3, 2016 Share Posted July 3, 2016 With the extra brackets and rear loop bit I wondered if the first frame on speshal s bike has been used as a sidecar setup? Also interesting box section swing arm 2 Quote Link to comment Share on other sites More sharing options...
guys Posted July 4, 2016 Share Posted July 4, 2016 ... It ran OK but there was one problem in that it came fitted with a side-car (not sure if it was home made or not) and I wanted to ride my bike solo, so I removed the sidecar, after a few rides I'd notice that it wanted to pull to one side even when attempting to go in a straight line, a quick strip down revealed that the frame had been bent to allow for the sidecar. ... Ed With the extra brackets and rear loop bit I wondered if the first frame on speshal s bike has been used as a sidecar setup? Also interesting box section swing arm Quote Link to comment Share on other sites More sharing options...
speshal Posted July 4, 2016 Author Share Posted July 4, 2016 yes it is a clean Engine same as my 340 thats been rebuilt i did have the 1 in the photo vapor blasted then i had to polish the cases myself turned out nice. i have the earlyer 198 ignition case on this 198A it will be red and silver ith the Alloy bash plate the frame is also a 198A i have put the bigger Airbox on it. I looked up vapour blasting and lo and behold there is a chap not 3 miles away that does it 1 Quote Link to comment Share on other sites More sharing options...
speshal Posted July 5, 2016 Author Share Posted July 5, 2016 Boo, it looks like my frame swap fell through, but no worries, I guess it gives me time to sort the engine out first P.s anyone got a 199-A frame hiding in their shed they no longer need Quote Link to comment Share on other sites More sharing options...
speshal Posted August 1, 2016 Author Share Posted August 1, 2016 Hello again I was just wondering if anyone could help me identify this frame, it has no numbers on it unfortunately? I'm guessing.... it's a 198 or 199 but some confirmation would be very handy. Thanks. Ed The silver frame is a ...... Quote Link to comment Share on other sites More sharing options...
model80 Posted August 1, 2016 Share Posted August 1, 2016 (edited) Possibly a 183 from 76/77 I don't think its 159 75/76, if I recall correctly that had round holes in the slump plate and not the elongated slots similiar to the one's in your photo. It doesn't look like a 199/198, as it doesn't have the brackets on the frame to house the gromets to locate the side panels. Thats not to say they have been removed at some stage as the difference between the 159/183/199 frames is minimal. With the main difference in the bikes been how the air box and side panels were attached. Would you have a photo of the companion swinging arm? Edited August 1, 2016 by model80 1 Quote Link to comment Share on other sites More sharing options...
guys Posted August 1, 2016 Share Posted August 1, 2016 Possibly a 183 from 76/77 I don't think its 159 75/76, if I recall correctly that had round holes in the slump plate and not the elongated slots similiar to the one's in your photo. It doesn't look like a 199/198, as it doesn't have the brackets on the frame to house the gromets to locate the side panels. Thats not to say they have been removed at some stage as the difference between the 159/183/199 frames is minimal. With the main difference in the bikes been how the air box and side panels were attached. Would you have a photo of the companion swinging arm? That's correct 1 Quote Link to comment Share on other sites More sharing options...
speshal Posted August 2, 2016 Author Share Posted August 2, 2016 Possibly a 183 from 76/77 I don't think its 159 75/76, if I recall correctly that had round holes in the slump plate and not the elongated slots similiar to the one's in your photo. It doesn't look like a 199/198, as it doesn't have the brackets on the frame to house the gromets to locate the side panels. Thats not to say they have been removed at some stage as the difference between the 159/183/199 frames is minimal. With the main difference in the bikes been how the air box and side panels were attached. Would you have a photo of the companion swinging arm? Unfortunately there is no picture of the swingarm That's correct Thanks guys, that's great information, I was trying a pictorial visual side by side comparison of a 199 frame. I guess the frame design department had a long Spanish lunch between 1970 and 1981 1 Quote Link to comment Share on other sites More sharing options...
model80 Posted August 2, 2016 Share Posted August 2, 2016 (edited) I guess the frame design department had a long Spanish lunch between 1970 and 1981 You're very harsh, it was from 1972, just after they finished the Model 93 Though in fairness it wasn't until 1983 with the arrival of the Yamaha TY 250, that we saw a commerically available radical frame re-design in trials. All of the European manufactures of the period were quite conservative and conventional in what they had commercially available to us mere mortals. Also bear in mind that Yamaha were the fore runners in offering a commercially available monoshock system in the MX world since 1976. Some of the other Japanese manufactures didn't catch up (bother) until 1981. When Suzuki produced it's "Full Floater" system and Honda the "Pro-Link" set-up and as they say, "the rest is history". Edited August 2, 2016 by model80 1 Quote Link to comment Share on other sites More sharing options...
noel063 Posted August 2, 2016 Share Posted August 2, 2016 It looks very much like my M183 frame. The number would be on the headstock but it has quite a bit of rust on it. Quote Link to comment Share on other sites More sharing options...
speshal Posted August 2, 2016 Author Share Posted August 2, 2016 Thanks guys, great info, I'm considering chucking my 199A engine in it if I can't find anything more suitable, I have a few irons in the fire atm but trying to find the right frame and swingarm is rapidly becoming a ball-ache Of course I found exactly what I want (199-A frame and swingarm) about 15 miles down the road and he has an alloy tank with it but trying to get a price out of him is like trying to get blood out of a stone. Failing that I shall make the world's most Frankenstein Bultaco you've ever seen 1 Quote Link to comment Share on other sites More sharing options...
speshal Posted August 2, 2016 Author Share Posted August 2, 2016 Hooray! Scratch all of the above, it looks like my frame swap is on, so I should be rebuilding a 199(A) - That's a 199 frame with a 199-A engine in it soon! 2 Quote Link to comment Share on other sites More sharing options...
