November 15, 201610 yr Installed one on my Montesa 348 over five years and never looked back. Well worth the price.
November 15, 201610 yr Used them on a couple of my race bikes, fit and forget. But don't forget to check behind the ignition cover now and again. My electronic ignition almost drowned.
November 15, 201610 yr Am thinking off putting 1 on my B however I bought the other type from rex count 3 years ago never had any trouble with it left the bike for 6 months fired up straight way I like the Elextrex is just got the 1 coil and cdi in 1 block that bolts to the original bracket. In saying that I have heard. A few say there no good I can't comment as I've never had 1
November 16, 201610 yr Do any of these ignitions have an advance built into them and provide a performance improvement or are they just to do away with the points and provide reliability?
November 16, 201610 yr Electrex say they have some advance curve built in. See https://www.dropbox.com/s/zcfoxs3bbdzit58/STK-154.pdf?dl=0 Its only for Femsa flywheels.
November 16, 201610 yr Thanks for that, I assume then they go a bit better than the standard points system.
November 16, 201610 yr bondy that the german one? ps im a bond too! Electrexworld are English, a lot of their stuff may by sold by HPI in Belgium as the photos & part numbers are the same I have 2 different bikes with their systems fitted, my TY250 is a work in progress so I can't comment on it's performance, uses the standard Yamaha flywheel. My 73 CZ380 has 1 been running their single plug system for 2 seasons now, came with a new flywheel. I can't fault the performance of the it but getting information out of them about whether the twin plug system they've just come out with uses the same flywheel & stator with different coil etc is next to impossible as their answering of emails is pretty hit & miss which does seem to be a common complaint from others as well
November 17, 201610 yr This is a German system I came across which also includes a new flywheel https://www.powerdynamo-shop.com/shop/show_product.php?cPath=6_86&products_id=680 They appear to have a very comprehensive range for Bultaco's https://www.powerdynamo-shop.com/shop/index.php?cPath=6_86 Edited November 17, 201610 yr by model80
November 17, 201610 yr I had one on a race bike, a chap who posts on here, seedoubleyou, used to sell them. Excellent bit of kit.
November 17, 201610 yr I've got a very similar system, same brand coil and flywheel, and I really like the lighter flywheel: makes the engine more responsive. The German system is a lot cheaper though. Wish I knew that before I bought it from the French webstore. DOH! http://www.francetrialclassic.com/en/ignition/1280-bultaco-trial-electronic-ignition.html Edited November 17, 201610 yr by guys
