- Today
TMofCumbria started following 199A Bing carb slide spring and throttle and 199A cylinder head fastenings
Should these be nut on studs are are some bolts. Right hand rear where there should be a head stay is a bolt but the others as far as I can see are nuts on studs
Hi. Just got a 199A and the throttle seems very heavy and the carb spring quite strong, stronger than I remember. Does anyone know what the free length of the spring should be, the number of turns and the wire diameter. The old twist grip is knackered. Anyone recommend a fast or slow domino right angle twistgrip and suitable cable. Thanks Tony
So what is the part number and lets see them, the photos you attached are copied from a previous post and don't show the part you report to be struggling with. If your bottom bushing is not on the stanchion tube then it's not a bottom bushing.
Seem to be the most popular boots in my area, have seen comments saying they're a bit taller than other brands Mine are at least 5 years old & I'll probably replace them with another set in the future
I have both bushes to replace the old ones and I have removed both top ones and the plastic sleeves but am struggling with removing the bottom ones. thanks Chris
What's the part number? Pretty sure that part does not exist, if it had one and you have the fork apart by now it would be obvious, it's not like fork bushings are pressed on the stanchion tube or anything. ... or here's another possibility, somebody one off customized your forks
Hi Has anyone had any luck on removing the lower bush in the lower legs of the tlr 200 forks. thanks Chris
SamStoney started following Tr35/Supertrial/? Fork oil type and level?
Changing the seals on my (I think) Supertrial, which has nonadjustable 36mm upside down forks; I can’t find a spec for oil anywhere, which isn’t surprising for this model. I’m guessing 5wt, and I can guess at the level based on current level, but if love to have a real reference to work from. Suggestions?
Yeah - that's the newer case, that Jim points out has the stop in a different position than my older case, w/o the recess guide. Anyway, through trial & error I found a spot that works....
Looking forward to seeing the restoration!
At least you won’t have to replace that tire…perfect condition. 😉
Here are some of the parts I've. I also have some new mudguards.
@ahell For its age I would not call that a dirtbag , considering that it is a trials bike it looks fairly good. In the UK that would have been for sale in that same condition for 2000.00 Euros so you paid well under its real value if you paid 200.00 Euros for it. Lucky you.
Hi Colin, I’m in UK, Essex, Woodford Green, sorry I didn’t mention it from the beginning! 🫣
If the spur gear is made of much harder material file small v or half round groove into the gear first, then clear the holes to size with a drill through the softer material.
Once a spur gear like that spins in a press fit the only sure way is to pin it in one or more places.
I wasn’t aware of this happening, perhaps it’s more prevalent on the 300’s and 301’s due to the extra power. Maybe this is what was happening to Andy12343 in a recent previous post. Mitani do know their stuff and do quality products, I’ve used them for many years. Mark at H&D Racing knows their products well. He may have come across and fixed these before
Did not see your earlier post saying you pressed it on using some loctite. As that is the case you know what your options are so its a closed case. I am talking to myself of course.
I know who you are and that you are a serious rider on Honda machinery and therefore know what you are talking about but Mitani who have pretty good knowledge of the Honda motors engineering wise reckon this movement can happen in approx 1 year of use. With the amount of torque the motor produces and the abrupt use of clutches in trials sections ,as happens, then an interference fit steel part in a softer aluminium outer part is going to start twisting and enlarging the alloy part in the same way that the rivet holes on the clutch bell elongate in the end and give rise to slop. I am happy to go with Mitanis' view based on engineering.
Shouldn’t have come apart like that. A new one won’t be cheap but a 2nd hand one may be worth a try. I would think Richard Allen trials spares would have some. If you’re really stuck I have one on a spare engine.
I think the rules in the UK are very clear. The rule is NO STOP with stop allowed. Watch this years SSDT , a trial that is marked under the no stop allowed rule , and the top riders were stopping and then hopping the back wheel sideways about a foot before setting off again at certain sections .That in my opinion is not stopping , stopping is when you have not moved for more than about 5 minutes which is still not really stopping it is a brief lull. I hope that clarifies the current system. If stopping was stopping Doug Lampkin would have had quite a few more marks than he did along with plenty more of the field of riders. Rolling backwards is OK as long as the observer on duty thinks that it is. Remember , as long as the observer follows his own set of rules and applies them exactly the same to all participants , then it does not really matter what the actual rules are.
I can see the arguments for both no-stop and stop allowed. I'm inclined to the idea that stop allowed is necessary at national and international level but not a good idea for club riding. Both systems leave a lot of grey areas that really need to be clarified by the rules. It would really help if the ACU and AMCA (in the UK) would publish rigorous rules about stopping so that riders are no longer marked at the whim of the observer.
