- Past hour
Sounds like it would do the trick, I'll give it a try - thank you!
- Today
Yes, flattening the ID. I also increase the ID slightly
Hello Chaps, 20 years on AI or eeeehhhhh iiiiiiiiiiii - up north. Cinco de Mayo 2026, The shirt still fits. Cheers Chaps,Motosinge83,
Interesting, thank you. So it's possible to grind the beads to a different shape? I assume that means flattening its inside diameter?
Sounds like a tube type rim with a tubeless type tyre. The sealing beads on a tubeless tyre have nothing to hold them onto the bead seats of a tube type rim and their shape actively pushes the bead off the bead seat. There are lots of options if this is your situation. Tubeless rim Tubliss device Tube type tyre Reshape the beads on your tubeless tyre
I forgot about this bike and it’s great to see the progress. The black scheme is awesome!
After more than a year, It's time to work on this bike! Meanwhile, the motorcycle was assembled and stored with Morad wheels in poor condition and a Showa fork. The shock absorber needed servicing, etc. So, I installed a machined top triple clamp from the HRC Repsol kit. New Tech gold forks, fresh DID wheels, new Galfer discs, new S3 black handlebars, all new Braktec front brake and clutch, carbon fork guards and swingarm. And a restored Showa absorber with stiffer grey spring. The entire chassis is new or overhauled. To do: Some titanium bolts and welding on my Future flat tank. The engine still needs to be opened up.
mcman56 started following Name this 4 piston rear brake!
Here is a bad picture of the rear brake on a 2001 Rev3. If I recall correctly it did not match the front caliper. It did work very very well.
Hello. rare and rocking horse category. If you fancy looking for an alternative then the beta REV3 had a twin pot rear caliper that consisted of a mounting bracket that held , I think a strandard FRONT AJP Twin pot caliper of which there are spares and possibly new AJP calipers currently avalable. Also NEW calipers are available from BRAKTEC made in Spain that should fit the REV3 bracket as they have the same dimensions as the AJP caliper, These bits MAY fit , I AM NOT SAYING THEY DO FIT. Might be worth a look. Regards Alan.
Wow - I think you got it! Lucky me - the PO replaced the relatively uncommon rear brake with an even *more* uncommon one. 🙂 now, where to find seals…and a new rear disc too. Knowing what it came off of might help a lot - thanks! sam
@SamStoney BETA SYNT 1994.
Exit the original footpegs, replaced with a wider, almost contemporary (around '97) model from the Climber. Blasting and a fresh coat of paint on the levers and brake pedal. Adjustment of the fork height in the triple clamps. A short ride in the garden to get a feel for the bike and continue bedding in the brakes. The riding position is pretty good after the final adjustments. Steering angle is very good. The weight distribution puts a bit of weight on the front. It's a bike that feels quite "glued to the ground," even though it can be moved around. The fuel mixture is a little rich at low revs.
millertee started following Munslow frames
Does anyone have any info on frames made for Bantams by Paul? Munslow
SamStoney started following Name this 4 piston rear brake!
OK, it’s obviously Grimeca, but what did it come from and where can I get pads and seals? It came off my well-used Beta TR35, at least that’s what I think it is after a lot of research. But I can’t find any reference to a 4 piston caliper/mount combo like this on *any* Beta parts list from the 88 to 92 era, at least. It fits my (steel) swingarm like it was made for it. The pistons measure 25 and 22m. Everything is in good shape except for the dust seals, which have completely disintegrated. Short term I can reassemble w/o them, but I’d much having them there, obviously. thanks for any pointers, Sam
Did you buy a 434 or a newer model ? I always take the heavy fiberglass '' pan '' and replace it with a minimal seat. you should be able to find a lot of exemple on the net. Guy
Add another rim lock right where the tire pops off the rim bead, if the rim actually has a bead. Guessing it is a steel rim with no bead, guessing you are running a tubed type tire on it. In my experience there is only one adhesive to safely use in tire applications and that is Fish glue. The up side of Fish glue is it's non-flammable and water soluble and re usable, the down side of Fish glue for your application is that it's water soluble. Fish glue is a fast drying, cold set, highly flexible adhesive largely used in woodworking.
bike4fun started following EM (Electric Motion)
I'd be checking the thermostat since you are having trouble with the timing of the fan. Coolant expands when its hot, so if you have brimmed the tank when its cold it will eject some and come to its natural level after you have used it.
thanks in advance for any help
rustycloe started following Best Gulf of Mexico T Shirts for Bikers: Where Do You Buy Yours?
Hey everyone! I've been searching for the perfect Gulf of Mexico themed t shirt to wear on my next coastal run and I'm having a tough time finding quality options. I want something that captures that deep blue water vibe, maybe with a vintage nautical or highway feel to it. Do any of you have recommendations on where to find the best Gulf of Mexico t shirts made for bikers? I'm looking for durable fabric that holds up on long rides, great graphics, and a relaxed fit under a jacket.
willy_westwood changed their profile photo
willy_westwood started following 2023 Nitro Coolant Issues
Hi everyone, new to the forum so hopefully I've posted this in the correct place. I'm also new to the Vertigo club and unfortunately, I've had nothing but trouble with it. Initially it had a faulty relay, which prevented the fan coming on, and the bike over heated, boiling off a lot of coolant. I changed all 3 relays just to be on the safe side, problem solved. Ironically, now the fan is on too much. Once the bike gets up to temp, the fan comes on and doesn't turn off - So much so, that I think it's causing the battery to drain. (it's brand new and already down to 2/6 bars) I can probably add 40 - 60ml of coolant after every ride. I must have done this 5 times. My question is, where is the coolant going!? Or is it simply really hard to bleed the coolant system? I've had the front wheel up high, bike side to side, all that stuff to try and bleed it. There doesn't appear to be any smoke in the exhaust, it's burning very clean. No leaks that I can see, no puddles under the bike in the morning. I might get a couple of drips out of the overflow valve after I brim it, but doesn't look like anywhere near what I can put in (to my untrained eye). I'm at a bit of a loss, if anyone can point me in the right direction I'd really appreciate it. Thanks, Will. (photo of dog and bike for attention)
mcman56 started following Rear Tyre becoming unseated
I had that issue with a vintage bike. It looked like it unseated in the area of the rim weld. The weld did not look that bad but I took a file and smoothed it out as much as I could. That eliminated the issue.
Rear brake : new gaskets everywhere, pads, bolts and yellow plastics
Thanks for the advice, did not think of that.
I have a recurring issue with the rear (tubed) tyre becoming partially unseated. There's no problem with getting it to seat initially - a bit of lube, inflate it to 60 or 70 psi and it pops on nicely, all the way around. The problem occurs after I deflate it to my normal pressure (4 psi) and ride it. A section of the bead slips off its seat, about 250mm in length. I can reseat it easily but when I deflate it back to riding pressure and ride the bike it happens again. The rim looks fine, as does the tyre itself - both are fairly new. Suggestions? Superglue and self-tapping screws?
Include a photo when you’ve got it back together. Best of luck!
