Today
- Heatsheat
Heatsheat
3M Ultra High Temperature Double sided Tape 9077.
Heatsheat
My gp2022 exhaust burned down in andorra event. I totally stripped and cleaned it now so will rebuild it to fresh. Only my heatsheald is loose now. What kind of glue will work for this?
Beta 240 TR34 1988 pure dirt bag.
Bike for parts ! Nice to finish this project !
PaulP joined the community
Yesterday
Made a wheel bearing removal tool out of wood.
You’ll find everything but the main shaft in the screenshot. The shaft itself isn’t critical and neither is the length. There’s some guessing involved but close is enough. Just make sure the diameter of the 17mm and 20mm tip is correct. Good luck!
RonH. Now I'm being lazy I know, but what were the dimensions you used?
Merlin Cagiva problems
Hi There, I have done a bit more checking with my trusty multimeter. I have tested the resistance on the hall sensor/pick up coil. It measured 23,5 ohms. But what I do not understand is that I get this reading with one probe of my multimeter on the wire from the sensor and the other probe going to earth. Is this correct? In my simple brain the pulse from the sensor/coil will not go to the CDI, but straight to earth. I have also discovered that the damage to the lighting coil was done by my flywheel puller. Thks Bruce
Sammy70 joined the community
New to trials and need some advice to join a club near edinburgh
Not an expert on trials in Scotland but you could maybe try Lothian trials club, they seem oriented towards the beginner. Unfortunately most clubs have more presence on FB than having a proper website these days so you're probably best bet is to contact the clubs on FB. https://www.lothiantrialsclub.co.uk/newpage Some phone numbers there you could try
I assume it is running fine at Idle? What happens when you rev it out in Neutral? What happens when you try and rev out under load/in gear?
Last week
This site is back by great demand . By the lack of response to questions etc I am not sure by who. Any way here we are . www.braapscotland.co.uk , https://www.sacu.co.uk>get-involved>starting-trials , https:// themotorcyclingclub.org.uk>the-edinburgh-trial
Hi There, I did notice that , but there is no problem with the strength of the spark, it just seems to be firing at the incorrect time. This points me ( no pun intended ) towards the CDI or the Hall sensor. I think I have a long journey ahead. Chrs Bruce
NoTraction started following Classic Trials
NoTraction changed their profile photo
Looks like you have damage on the lighting coil?, potentially also damage to the ignition or pulse coil or even the damaged lighting coil is affecting the other coils. Have you got the resistance values for the various coils?
Hi ...... a complete newbie to trials here. Just purchased a 2022 Beta 2t EVO 200 ..... putting ink to paper tomorrow. Delivery in a coupl of weeks. I stay in edinburgh and understand that I need to join a local club in order to obtain my SACU membership. I have looked at a couple of facebook pages etc but can't seem to find a way to actually apply for membership to these clubs. Im looking for somewhere thst catets for complete beginners with beginner type trials. Can anyone point me in the right direction. As mentioned, my bike wont be here for a couple of weeks at least but I'd like to pop along in advance and meet some folks and see what goes on. I work away mon to friday ( Orkney ) so weekends would suit best. Many thanksin advance for anybody who can respknd with some suggestions. Cheers toto
toto started following New to trials and need some advice to join a club near edinburgh
Hi guys. Would any of you happen to have a Merlin, who could maybe tell me what the complete part number is on the Kokusan CDI. I do know that Merlin used two systems, Kokusan and Dansi. As you can see from my photo, I only have CU 21. There are more digits or numbers after that. Thks Bruce
TRRS ONE RR 80CC 2024
I had the same problem. After 3 cracked clutch cases, failed waterpump seal, and a very unstable idling engine all within 10 hours of driving I had enough of it. Although everything was very well taken care of by the dealer i wanted a bike without problems. It was my daughters bike and she couldn't drive for several months or we had to share my trs one 250. So i traded it in for 2024 125 one rr. Flawless, no issues, just driving and cleaning....
I miss my '18 125, never should have traded down for this perpetual problem. Not liking any of my options from this point, fix it, flog it, replace it.
greenall started following Introduce Yourself
greenall joined the community
Had this problem in the first month 3 times... Got rid of the 80cc and bought a 125. Never had a problem with 125cc...
Update # 3: Cracked clutch case between the kick starter & fill plug @ 155 hours. Gear box oil everywhere, cutting the ride & the season, short. I am amazed it lasted that long based on others experiences & the # of times I have to kick to light the fire (3-7, cold or warm, in neutral). TRS has "updated " the part for 2026, same part # 03031MT100. KTM part # 47030001100 is interchangeable.
Wtc finished?
I disagree. He's spoken out numerous times that the FIM's attempts to try and lower the difficulty of trials is not the direction trials needs to go. He's said that outdoor trials need to become more like the indoor events, a show, more dynamic and shorter duration. People listen to that and the WTC has evidently went that way the last couple of years. Does he genuinely believe this or does he want trials to continue on the direction that suits him, so he can win another 40 titles? He's said that kids entering the sport want this modern style of trials and that non stop was outdated. I disagree with everything he says, I think he is very far removed from grass roots trials, and ultimately WTC does have an effect on the sport at grass roots.
New uk member
If you'd like to PM me your direct e mail adress I can send you an e mail by We transfer Cota 247 Mod 21M Ver1971MKII -1975 Ulf Carlson-.pdf
New uk member
Maybe ebay is the best bet ?
Aprilia Climber 280 1993
Pictures with some new plastics
New uk member
Hi thank you. But that engine is coming out as I have the original to replace it. I also have another spare engine. I need original forks for it though if you know of any?
New uk member
I would suggest moving the kick start lever back to the original vertical position. The moving of the lever more clockwise to give more purchase always ended in disaster as there is a stop built in to the kick start shaft which eventually punched a hole through the crankcase.
