This stream auto-updates
  1. Today
  2. new piston and rings in the mont and it runs a lot nicer now no more rattle and it feels more powerfull.
  3. Bials
    1975 Tl250
    I realize this is an old thread, but did anyone find a solution to this problem?
  4. Yesterday
  5. My Climbers rear shock stop bumper has disintegrated. Where can I find another one? The shock shaft is 14mm. Thanks
  6. How long have you been running them for?
  7. It looks like the belleville spring support "ring" (#15) sould be offered in different thicknesses, similar to what TRS does. They only list one so far.
  8. For what it's worth I'm running them on a 1997 Beta Techno and they work well. Harder to put on than the X11 but otherwise they are very good for the money. If you are serious get an Xlite or X11 but if you want to save a few hundred the Ibex is worth a shot.
  9. Last week
  10. Should be close! So, just as a reminder: 1973 Ossa Explorer with late 70s Pioneer engine, Koso PWK30 carb, PVL coil. Still needs a decent silencer as that chinese crap touches the rear tyre. Just fitted the tank, air filter, tank+petcock, fuel hoses, clutch cable.
  11. Hello, Has anyone installed a Tech TS4 rear suspension on their bike? I'd like to install one, but it seems there's not enough space between the swingarm and the shock. The original is 58mm, the tech is 78mm. I ride a Beta Evo 300 4T - 2020 model. I can also test/buy a TRP. If this is a better option, please let me know. greathings, Luc
  12. Well my friend grabbed my tl125What he gave me back is mind blowingBefore Then work was done Here is the artist himself Mike Allen my friend and mentor The finished product Here she is in the house, a bike like this you don't leave in the garage
  13. Not exactly the solution I was hoping for. But yeah, I guess they are not too serviceable.
  14. See de video from a Japanese on you tube whit de new Beta...!!!
  15. Hi, Delighted with my new 250 Sincro but the factory website says there are three variables for the clutch spring tension but no info on how to change them. Has anybody tried it out yet before I take the clutch cover off? Thanks in advance!
  16. Hi All, I just purchased a Beta Sincro but because it is a new model, insurance companies haven't listed it yet. The bike is road registered and DVLA were happy to take my road tax payment immediately even though I can't use it on the road. Any thoughts please? Naturally I am particularly anxious to have the bike insured against theft if nothing else.
  17. On mine I cut a window, repacked and closed it back up with an aluminum sheet metal cover with a rubber gasket and rivets.
  18. Thank you very much! Got my two TLs today and I'm enjoying them a lot. I will check out the places you listed.
  19. I did do some parts chasing Some TL parts are shared with the XLs. I was able to get intake valves here. https://www.xlintperformance.com/ IMD was selling piston kits on ebay. They were very nicely made. The machinist who bored the cylinder thought they had the original Honda molds. Gaskets came from ebay. A China copy petcock from ebay worked after installing Honda OEM seals. A China copy 22mm carb worked well after increasing the slide cut away. It was well made and accepted OEM Keihin jets but needed the bowl seal replaced. It seems like China o-rings do not like US gas or maybe just California gas. I think All Balls sold a steering bearing kit and fork seals. These guys had the transmission output shaft that the seal runs on. https://www.davidsilverspares.com/ These guys have some general Honda stuff. https://4into1.com/?srsltid=AfmBOoqk_OxNHRz3n01ZkipB_bpjTyDPO1CO1xnau5oSRcIMlS0ChZAQ The main bearings are or were no longer available. They use some kind of custom bearing with a larger OD than anything available. Be sure they need to be replaced before pulling them off. I didn't. All Balls listed a kit but they were just a standard bearing. There are solutions but none are easy or cheap. I replaced the ignition advance mechanism with used parts from ebay. IIRC, they were from an XL125 but looked the same. As mentioned, CMSL has some things too. I could not find an intake manifold so ended up having to machine one.
  20. Yes, Chris said he might start a new class this year. Otherwise the early liquid cooled bikes are legal in the modern vintage class.
  21. I have a 2012 ST290. I looked in the service manual, and there is a reference for removing and re-packing the silencer packing fibers on the newer models However, on the 2012 model, I am not sure this can be done. It is of a different design than what is shown in the manual. On my bike, there IS a philips screw in the correct location that would indicate it is possible, but when I remove that screw, nothing comes apart. Does anyone know if the silencer tube can be removed for cleaning or repacking on the 2012 model?
  22. Bials, here are a few places that sell TL parts. Hopefully you can find what you need on them. https://www.megazip.net/zapchasti-dlya-motocyklov/honda/tl250-14857/tl250-28759/tl250-a-787928?network=x&adposition=&keyword=&gad_source=1&gad_campaignid=22419889174&gbraid=0AAAAADdym2axmanakEDnZRMjcQ5KOwMbQ&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYAyAAEgI1rfD_BwE https://www.cmsnl.com/honda-tl250_model302/?bg_source=ga&bg_campaign=16511123247&bg_kw=dsa-1465129992666-mi--pi--ppi-&bg_source_id=586686834193&gad_source=1&gad_campaignid=16511123247&gbraid=0AAAAABvnBcJu1N-OSlIKn7IozHy-M-FqW&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYASAAEgLI0fD_BwE https://www.speedandsport.com/model/tl250/ https://www.vintco.com/shop/Honda/TL250
  23. Thanks Feetupfun, I am definitely going to look to see where the closest vintage trials events are. I might give it a try after I sort my bike out. Higher bars/lower pegs might be necessary. Are you aware of any dealers that might still have TL250 accessories? Thanks. Oh, I'm in the US, but it really doesn't matter.
  24. Thanks. I am sorta set on a TL and might branch out later on. I'll probably be doing more trail riding with my son and grandson than actual trials. I did really enjoy seeing how many difficult objects I could go over as a youngster. I could climb much more difficult terrain than my friends on their higher powered bikes. I'll see what I can do within reason at my age.
  25. lineaway
    Conrod
    Connecting rod comes as a kit. But it is 400 dollars more for a complete crank.
  26. Thanks for the reply. I will still ride my CRF and will probably ride more trails than trials. Ha! I plan to sit plenty of the time on the TL! I broke my tib and fib about 2 years ago on my XR650 but I'm doing pretty well now. It did take almost a year to get back close to normal though.
  27. At 69, I agree that tall bars make things easier on old backs. The TL250 is a heavy beast. I had one and it weighed 250 lbs without gas. It was also a bit short of ground clearance compared to other bikes. It did have a very nice fork. I find that the TY175 is the easiest bike to ride by far. It is maybe 60 or 70 pounds lighter than a TL250, not a whole lot more than a 4rt. It kicks easy, starts easy and turns very tight. Power is slow and very easy to control yet it easily lifts the front wheel to go over things. For a mid 70s 175, It is quite surprising what kind of hills it will go up in 3rd gear. It is not as capable as a modern bike but easier to ride because you are not constantly working the clutch and brakes. Even with modern shocks, its primarly weakness is suspension. When going up a rocky creek bed like they seem to do all of the time in the UK, you feel like a ball in a pin ball machine. But, that may be true of most twin shocks. If you don't do a lot of that, you may really like one. If you are set on a 4 stroke, a Honda Reflex is also much easier to ride than a TL250.
  28. mcman56
    Conrod
    When I bought a con rod kit for a Beta 125, it came with the big end pin. Don't they all? It is basically the inner bearing race. (unless I'm confusing termonology) Beta USA told me people were just buying complete cranks. IIRC, the price was about double but you did not to pay someone for the crank building work. The 125 crank was a little tiny thing with lots of plastic for filling volume. It looked like you needed some specilized fixturing to support it in the press. It was not mine so I took it to a specilized shop. The guy who did the work did not want to tell me or show me how he supported of held it.
  1. Load more activity
