- Past hour
onefunride started following 1974 TY250A - Does the Shedworks Tank/Seat Combo work?
I really like the looks of the Shedworks Tank/Seat combination; however, I can't figure out if it is compatible with the 1974 TY250? I struggle to understand what is compatible with the rear fender that uses the fiberglass seat pan. In all the pictures I see it seems the models are later versions, with a different rear mudguard and I can't find this other mudguard for sale (I have the short mudguard where the air box is part of the rear mudguard). Is a different rear fender needed for this to work? Is the stock air box compatible with the Shedworks setup? I also see majesty style aluminum tanks that look good, they seem to use a different rear fender as well. I am trying to cut weight, have a more "sleek/narrow" look and feel to the bike. Thoughts? Which would be considered better, or is there another option to clean up the bike? Thank you Glenn
mcman56 started following Return of the “what transmission oil”
- Today
Gauss Gauss, brilliant! Wish I had thought of that! PM system says you cannot accept mail. Intentional, or full mailbox?
So nothing has changed? Assume you mean Dex 6, not Dex 11? Might try some D6 before spunking on elf.
My son runs elf. I run dex vi Go figure.
Nishijin started following Return of the “what transmission oil”
Hi all, Bought a 2016 300rr and the dealer put 10w40 tranny oil in it. Not Elf. Took for a practice. Felt fine until hot-hot and then refused to find any gear except the one it was in, had to turn off or wait until cool. Prefer not a light-switch clutch. What was the decision after the past decade since people chatting GRO?
Do Jotagas / JTG still exist. G2 Grup?
ChrisCH replied to bikerpet's topic in JGAS (Formerly Jotagas)
I like the Mecatecno but they do not (as best I can see) do much marketing. I have only ever seen one - the one at SW Trials and it was there for a very long time. It is a big leap of faith to buy something at the top end of prices without a test ride and when you do not know anyone that has one. They don't have a demo fleet with the importer like EM. That was what I meant by not cutting it. I am sure the bike is a good bit of kit. -
The market has changed big time - you are right. Was the Mechatecno the SW Trials one? It was a couple of years old IIRC but unused. People are still buying bikes and are buying new bikes but I think the cheaper stuff was massively overpriced for a while and some sellers still kite flying. -
https://www.clasicasdiaz.com/tienda/en/porta-numeros-and-handlebar-protector/1674-handlebar-protector-ossa.html https://mmgracingstore.com/en/motorcycle-accessories-and-handlebars/107693-handlebar-pad-ossa.html that's just two I saw when I googled it with that pic...........
mattslinger started following Jotagas JT300 2013
Time Left: 27 days and 16 hours
- FOR SALE
- USED
Jotagas JT300 trials bike, 2013 model. UK bike, road registered. In great original condition, standard bike apart from Ohlins rear shock and S3 bars, foot pegs, head and exhaust. Comes with headlight, V5 and some spares. Well looked after, runs and rides perfectly. Owned by myself for the last 10 years. The bike has been used infrequently for practice only. £1650 ONO. No swaps or part ex. Located in FY6 0DZ. Call Matt 07884253169 for info.1,650.00 GBP
anachronism replied to bikerpet's topic in JGAS (Formerly Jotagas)
Curious on your definition of not cutting it. They are egregiously expensive. - Yesterday
In the UK cheap second hand ICE bikes are not selling , the prices are dropping by hundreds and still no sale , Adam Raga dumped by TRS , a Mechatecno on Ebay dropped from 9,000.00 to 5,500.00 and still no sale after months. Sherco makes a budget ICE model for the market. Personally I do not see any room for any type of trials bike in the market certainly not something that costs 10,000 just to faff about on a Sunday afternoon.
Flash1 started following Ossa tr280i bar pad
Hi, does anyone have one of these bar pads they will sell
mattslinger joined the community
I think there is room in the market for another electric as well as EM. Mechatecno are not cutting it (much as I like their bike). I thought Gasgas might have a model out by now but the parent company's financial problems probably explain why they have not. -
JBROWN started following 2016 vertigo 300 won’t start
bikerpet replied to bikerpet's topic in JGAS (Formerly Jotagas)
Maybe they need to consider e-jotagas for a resurrection. With the offset shock it seems they'd have better options for mass distribution than a conventional shock. That's where my interest originally arose. - Last week
konrad replied to bikerpet's topic in JGAS (Formerly Jotagas)
I had a nice conversation with Clay at Jotagas of America this morning. Unfortunately, Jotagas was killed off by COVID-19 which resulted in the factory's inability to source parts. Although the brand's owner is still enthusiastic, the likelihood of a resurrection is small in Clay's estimation. The Jotagas of America website remains mostly due to inertia. -
JBROWN joined the community
Hi I’ve just bought a 2016 combat 300 that won’t currently start (bought with an intermittent starting issue). What does the powerbox part number V-0533 do within the ignition system? thanks
bikeskint started following Kickstart intermediate pinion removal
Hi all .. I've managed to almost resolve the clutch issues.. but I've noticed the back cog for the kickstart gear ⚙️ is very damaged And no longer meshing looks like the circlip was never replaced 🤦♂️...how do I get it out? It's behind the gear selector finger ! Do I have to remove the whole gear selector shaft or is there an easier way..
EM 5.7 Retrofitted with Modern siliXcon SX Controller
nostroke replied to konrad's topic in EM (Electric Motion)
Oh, OK just read your link, thanks. Looks do-able but there are probably a lot of parameters that I would need from motor mfgr. Due to the lack of any serious ramp programming on this Alltrax golf cart controller I used here, I made an audio taper (log) potbox so you have great slow precision on an otherwise sketchy throttle and you get the big splat energy when you wick it open. Almost as good as a clutch overall but way easier to ride IMHO for medium skill level riders (me). Speed (voltage) mode does not have that time lag that a torque (current) mode has so response is instant. And I 'll certainly dig deeper into your experiments. Thanks for all that . -
Yes. Generic controllers are available, but lack some of EM's features. https://www.electricmotiontech.com/home/em-5-7/sx-controller-experiments -
Is it likely that the controller is available direct from siliXcon unprogrammed? Also, I should add that the Perm/ Alltrax package I used, while pretty crude by today's standards, does not use a feedback device although a brushless could emulate that with its feed back loop I suppose. I'm not a EE but have dabbled with EV controls forever. -
Maybe, maybe not. EM uses custom siliXcon firmware, and the speed loop routine may have been removed to make space for other code. https://docs.silixcon.com/docs/fw/modules/esc/driver/command/driver_pid_modes -
Just curious if this is possible, within reason. I have an old relationship with Phillipe at EM from 2 decades ago and am trying to rekindle that relationship for both humanitarian and access reasons. -
All of EM's siliXcon controllers are password locked, so only torque mode is possible. Back when we first got the 5.7, I experimented with the Kelly controller's "balanced mode" (somehow incorporates both torque and speed modes). I found it most unintuitive compared with ICE trials bikes, so I did not bother to try speed mode. See: https://www.electricmotiontech.com/home/em-5-7/5-7-controller -
nostroke started following EM 5.7 Retrofitted with Modern siliXcon SX Controller
I'm curious about some of the programming used on these bikes. I just got a 2024 pure sport with diaphragm clutch and the 3 mode settings. But I'm used to a bike I built and posted here years ago that uses a Perm brushed motor and an Alltrax 48V 400 amp controller. I am comparing the EM throttle response and general feel to my old 'Digit' I built. The Digit, because its a brushed motor, is by nature always in speed mode, so throttle command is proportional to the motor rpm as opposed to most brushless motors that typically (the EM) operate in torque mode where the throttle command is proportional to the current. My Digit does not have a clutch but throttle response is very crisp and both splats and wheelies are very predictable and easy to control. The EM however feels really mushy response-wise and its harder for me to control since I'm used to speed mode modulation. Has anyone programmed an EM to operate in speed mode? I also build street and road race electric bikes and have done so for many years (I'm old). On street bikes, torque mode is more intuitive but for off road use and on my EM, I think that speed mode would be better. Anyone know what I'm babbling about? -
Time Left: 24 days and 19 hours
- FOR SALE
- NEW
HAVE A NEW PAIR OF WULFSPORT NEW MODEL TRIALS BOOTS. STILL NEW UNUSED IN BOX.BLACK/BROWN. SIZE 8/42. THEY WERE BOUGHT READY FOR A NEW SEASON OF WOBBLING, BUT HAVE HUNG UP MY CRASH HAT AND RETIRED FROM COMPETITION, HENCE NO LONGER NEEDED. CAN BE COLLECTED FROM HORSMONDEN OR RYE, OR AT THE FORTHCOMING ERITH & DISTRICT CAMPING WEEKEND AT JACKSONS WOOD.130.00 GBP
By pre65wobbler
