This stream auto-updates
  1. Today
  2. Yesterday
  3. Post up a picture of this rare motorcycle.
  4. Anyone working on or have knowledge about a 1966 montesa with kickstarter on left side ( sitting on the bike) . Trying to replace spring can’t see original, or where it should be. Any help would be greatly appreciated.
  5. Rear wheel finished. New spokes & bearings. New chainwheel.
  6. Last week
  7. Pre 1999 Montesa Cota 315R came fitted with Paioli forks and the service manual covers their service in great detail 👍
  8. Hepcats , Sinners , Brats , Sunshine. This is a resurrection for you. Resurrection Joe. Luckily Ryan Young lives on. https://shercousa.onshark.com/docs/ You better look at it quick before Drumpf has it deleted.
  9. I would still like a copy of the 2003/2004 manual for anything else. I can only find later models.
  10. Thank you for your quick response, The website is full of valuable info, a lot of it goes beyond my current knowledge of the argument. I was hoping to find pouch cell with equivalent features of the original, and have some technician swap the cells and keep all the rest as original. Yet It sounds like this is difficult to achieve and may even be better to find a new BMS and new battery cells . Il would be great to hear of someone has successfully done it, and with which specific BMS/cells. I will contact Enepaq and see if they can provide suitable cells, their BMS seems a lot better than the original one
  11. Close; it's because the light weight, right-handed, senior citizen type rider tried using their left leg to start the silly backwards bike and found they simply could not start it.
  12. I don't get why so many people advocate using the right leg for a left-hand kickstart. Is it that right-handed people think the left side of their body doesn't work? How do you think left-handed people get on with right-hand kickstarts. Unless you have a particular injury or disability, use the leg the bike was designed for.
  13. £1500 should do it, though the bike will be quite old so you check it out very thoroughly. Normally I would say £2k will get you something trouble-free and ready-to-ride.
  14. Glad to hear you found something useful on the website, Fabio. My understanding is that the 2019 5.7 was EM's first use of the siliXcon controller. I assume the controller is password protected, like all later EMs. But if that's not the case, the 2019 would be quite valuable. The battery is always a source of concern. However, the 5.7's pouch cells do seem to be more “reliable” than cylindrical Li-Ion cells that are now being used. I have heard of several 5.7 batteries being rebuilt using cylindrical cells. Of course the BMS also would need to be replaced. Battery technology improves quickly, and it would be likely you could now achieve 2x the energy density of the original 5.7 battery. I have begun researching BMSs for such conversions: https://www.electricmotiontech.com/home/ev-tech-101/ant-bms
  15. It’s better to stand to the side and use your right foot—it’s more comfortable and helps you maintain your balance.
  16. I read with interest this topics and what a great amount of info you shared on your website! Thanks Konrad! I am deciding if to purchase or not a Motion Escape from 2019, the bike comes at a good price but i am worried that the battery will not last long or that will lose efficiency very quickly.... Kokam it out of business...so i started looking online for Pouch 3.7v 25Ah lithium ion batteries to regenerate the battery without having to change or reprogram the BMS .... Do you know any specific brand/models that could be good for the job, just swapping the cells and be good? Thanks Fabio
  17. Rear shocks to suit a TY175 would be suitable for the Cota 247. Forks are rebuildable, you just need to get some high pressure rotary seals of matching dimensions from your local supplier.
  18. I'd be checking your countershaft sprocket before pulling anything apart, if its worn it might be catching the chain. Next thing would be as JRSUNT has said and take the chain off and run it in gear and see if noise is affected by the clutch, which means you will have to dig further.
  19. Only in that the owner in New England passed away, and the son sent them to Mike to sell them.
  20. Thanks now I have 5W oil so will start with 300 and then measure.
  21. It is unusual for the pump to fail, particularly the older style, they were pretty reliable. Yeah that pump should do the job
  22. thanks bud much appreciated, yeah im capable of stripping it etc just more on the lines of cba lol looks like a strip down it is 🤦🏻‍♂️ thanks again
  23. Practical approach Measure the original spacer from the TLR250 F (if you still have the old one) and make an exact copy,If you don’t have it, use a vernier caliper to measure the distance between the inner bearings in the rear fork. You can then calculate the length of the spacer:
  1. Load more activity
