This stream auto-updates
  1. Past hour
  2. Disagree. Not everyone is wanting to go win their local trial, and I guarantee if I put the Kenda on I would still beat 90% of the riders using michelins
  3. Yesterday
  4. Michelin , Dunlop D803 GP , IRC Rear . Anything else is not a serious tire/tyre for the sport at this present time
  5. Restoration of a pair of original 4RT 32-spoke wheels. Sandblasting, painting, and polishing of the hubs, SKF bearings. Cleaning and treatment of the spokes. Deglazing of the discs. The weight saving on the front wheel is 700 grams less than 315R wheel! Spokes nipples are aluminum, brake disc, different hub, and four fewer spokes... a significant weight reduction.
  6. RonH
    Hello
    Welcome! That’s great to hear about your sons. Would love to see some photos of them doing their thing. I can’t get my son interested. How’d you do it?
  7. We were on the right track. Took the bike to my local dealer, got instant service. Traced the issue to a lack of fuel pump pressure. The control relay was somewhat corroded. Replace it, fuel pressure back to normal, problem solved. Happy days.
  8. Time for a new rear tyre. I got to see side by side the Michelin X11, IRC, and kenda Ibex and the ibex was definitely a nice gummy compound, softer than the other two. I assumed the downside of them must be the wear rate but talking with the vendor and googling it doesn't appear to be the case (weirdly the opposite in fact). There is a suggestion the ibex side wall may be slightly stiffer than a x-light but that's all. I can't really seem to find a negative thing about them. So why would I buy a £140 tyre when an ibex is half that? Looking for input from anyone with firsthand experience with them...
  9. Hi, new to the group. I have joined as this looks like the place for everything trials related! I used to trial myself around the mid-90s as a young teenager. Now my sons have shown an interest so I have supported them into trials. They've been on Osets the past year as an introduction to the sport and my oldest (13) just upgraded to a Gasgas 125.
  10. Non-powerjet. If you want an OKO, the model is K-100 and people usually run a 26mm or 28mm
  11. Thanks for the reply , I must admit without taking the carb to pieces once again I'm not sure it has the tang plate fitted! From memory just two floats which rise up and down on two vertical steel pins and a little plate that connects to the needle valve.......I could be wrong I frequently am these days
  12. Last week
  13. Sorry to resurrect a 6 years old topic but... was it the model with or without the "powerjet"? I just fitted one of the chinese PWK clones on my 250 Pioneer engine with Explorer exhaust... the stock jetting seems to be too lean (38 idle jet, 120 main). I just replaced the idle with a 45 as the bike tends to die even with the air mixture screw totally closed. Not sure the 120 main is big enough, we'll see.
  14. The cap is on there to make the fuel pump work better. The cap is small compared to the one on a Montesa, personally I think I would double up on the cap, that would be cheap and easy, might even give immediate results if the cap on it is lacking.
  15. Ok, thanks. It has a tiny capacitor for the ecu, but not for starting. I do have a local shop with excellent technical knowledge, maybe i will just take it there. I bought this bike from the owner and he has been extremely helpful on issues that pop up. If I can't sort it out, it may have to go.
  16. From what I've seen there is a lack of consistency in design and execution in their production bikes, so you are best to reverse engineer what you have purchased. Wiring diagrams that I have seen are sketchy and incomplete. One of my riding partners owns two of them now, he bought the second bike in the hope it would be a better starter and is still struggling with starting and lean fuel operation issues. Some have a battery and some have a cap but to be honest I expect it needs both. Capacitors charge relatively fast off the kick starter compared to a battery that stores a lot more electricity, but the solid state battery really lacks power in cold temps and your alternator needs to be operating at peak efficiency to generate sufficient power to both run the engine and charge the battery / cap to charge operating capacity so personally I would start right at inspecting the alternator and scope test everything on the wiring harness down stream of that. A boost or charge port for the battery is the best way to troubleshoot the battery and is a good add to any Fi or electric start bike imo.
  17. That sounds like a very good start. I have been told to try cracking the throttle a bit at the end of the kick travel. That doesn't seem to do anything. Where do I check the fuel pump voltage? Not sure if even have a wiring diagram. Can you point me to one? Also it was recommended to richen the tps setting. Not sure how to do that yet. Any more specific tips are welcome. By the way, once it starts it runs fine and does generally re start fine. Thanks.
  18. I'd be checking the fuel pressure and if your bike is fitted with a capacitor in addition to the battery, she won't start without fuel pressure and it can not achieve fuel pressure unless the electrics are fully functional to support it. Checking the battery voltage at the fuel pump and not at the battery terminals is a good start because you may have voltage drop from bad connections before it reaches the pump or with poor grounding. Hope this helps some 👍
  19. My 2022 Vertigo Nitro JB replica with battery, is extremely difficult to start. As the temperature drops more kicks are required to start it. In the garage at 10c it took 70 kicks to start it. Battery is good 13.3 volts, throttle body just cleaned and mass air flow cleaned, new plug. Took so long I thought it was broken. Suggestions please.
  20. I did get one and install. It does feel more lively and seems to absorb more for a more cushioned ride.
  21. I don't know for sure but I have heard the welding on the seams of the aluminum tanks is poor.
  22. All credit to the Hell team in Australia. Link to the library of GasGas information and you can poke around and find it. https://www.thehellteam.com/technical-support/gas-gas-parts-and-service-manuals or this may Link to the 1999 parts book https://drive.google.com/drive/folders/0B0Mfile5AhnmY3ZVUGs5Z1BMTTA?resourcekey=0-Mu7q122qaYNUoKRk-3aVVw
  23. Thank Arnoux, is that parts manual stored in a way you could send it to me. Or tell me where I can find it. C3……. great help .
  24. Thanks for the advice. I will drain for storage. And draining between trials events probably is a good habit in season. I'd consider replacing with aluminium tank if not so pricey! Cheers.
  25. While it's probably OK to leave fuel in it, it would be kinder to the tank liner to store the tank dry over winter. Nowadays after a ride, I drain and dry out my lined fibreglass tanks if it will be more than a few weeks until the next ride. My oldest epoxy tank liner is about 20 years old now. For the first 15 years I left that one with fuel in between rides and it gradually changed from honey colour to dark brown over the 15 years. After I noticed this happening I started draining it between rides and now at 20 years it is still working fine. It may still have been OK if I had continued leaving fuel in it, but the colour change made me wonder if it was being gradually damaged structurally. For info, Caswell liner is epoxy resin
  26. I would not leave fuel with ethanol in any motorcycle over the winter regardless of the tank material. Stabilizers may be helpful in preserving fuel but I would not count on them. Even though your tank is coated I think it is still a bit risky to ever use ethanol containing fuel in a fiberglass tank.
  27. So We were at a National in late 2004 in the states. A friend had a 300 pro. Just after getting his score card and starting his bike he broke that case right before our eyes. Luckily Dale M. the USA gas gas importer was in line with us. Dale ran back to his trailer, pulled out the case and a gasket and handed me the parts. I had the bike back together in 40 minutes. We all finnished on time and had a great weekend. We sure will miss Dale! Thanks Arnoux for hanging out posting and helping everyone!
  1. Load more activity
