This stream auto-updates
  1. Today
  2. Thanks for the offer but Australia is a bit far to pick up. I’ll hoping someone will come up with a motor for me in England.
  3. Hello everyone, I have a problem with a 2005 Cota 4RT. After 10/15 minutes of riding, the bike shuts down, it seems to be a lack of fuel supply. As soon as it happens, I remove the spark plug and find it dry. After this, the bike starts up again immediately but then shuts down again after a few kilometers. I have replaced the fuel pump and filter, but with no results. When the engine is about to shut down, if I pull the clutch, it does not shut down, so in neutral position the engine runs well without issues; as soon as I shift into gear and increase the revs, it starts to misfire until it shuts down. Has anyone ever had a similar problem? Thank you for the help!
  4. Hi everyone, I'm a new member, writing from Italy. I own a Beta Rev and a Cota 4RT.
  5. I've got a model 49 250 Sherpa T motor and a Campera 175 motor available. Both require overhaul. Location Gladstone, Queensland Australia
  6. Yesterday
  7. THANKS FOR RESPONDING, IT IS HARD TO BLEED W/MY HARBOR FT PUMP WHICH MAKES SENSE IF THE PLUNGER IS NOT ADJUSED RITE
  8. THANKS FOR RESPONDING, ILL GIVE IT A SHOT CANNOT FIND ANYBODY IN B'HAM THAT WILL LOOK AT A 2001
  9. Hello, Fortunately, I noticed my Mountain Cub (1965?) trials conversion bike stopped pumping oil before it got too hot. I assumed it had a bad oil pump. I found a new NOS pump for $50, so I went ahead and bought it and installed it (not a fun job). Unfortunately, my bike still isn't pumping oil. Although I'm not a triumph cub engine expert, I have rebuilt, from the crank up, three motors and they have ran great after my rebuild, so I do know my way around the motor. I was very careful to install the pump correctly and it was spotless when I installed it. Could the "dry" sump not have enough oil in it? If so, how would I add some oil? To note, I haven't pulled the copper lines that go to the rockers yet and checked for blockage. Note - the bike had been sitting for about six months prior to me noticing it wasn't pumping oil. Thanks for any input.
  10. I had a bear run across a section of the loop trail I was on once. Small black bear so not sure how risky it was, still unnerving, but was interesting to get a glimpse of one on the ride for me and my riding buddy.
  11. Last week
  12. It could be also that you need to adjust the screw on the lever that presses on the master cylinder piston. If the piston is not in the correct position, when pressed or opened, it effectively blocks fluid flow and won’t drain and it won’t allow fluid to flow from the bottom up either. Screw it out a turn and try again. Turn the screw, little by little, until you can pump fluid.
  13. Any Sherpa T or Alpina engine would fit straight in. Some had different exhaust pipe fittings onto the barrel but the engine mounts are the same.
  14. Adjust, repair or unplug the master cylinder so it lets fluid up into the reservoir when the pads are pushed apart, no flow back means you have a problem.
  15. HELP. USED VACUM METHOD HELD 25 INCHES COULD NOT DRAIN MASTER CYCLINDER TRIED PUMPING FROM THE BOTTOM UP..NO RESULT. ANY SUGGESTIONS
  16. I think you narrowed it down yourself, the problem manifested after you used a pressure washer on it, so you now have water somewhere you should not have water and you need to dry it out. Fortunately water evaporates so dismantle the electrics and dry them out and they will likely function again. On a Montesa that would be the big plug with all the pins that connects to the black box, look for similar connection on your machine. ... and avoid using pressure washers they destroy motorcycles as fast as they clean them.
  17. I have a 175 Bultaco Sherpa with a very poorly engine that apprears to have eaten its 'self in pieces. If I can find the parts I would like to rebuild the original engine at some point but does anyone have a 250 or 325 engine for sale that would fit straight in to get me riding again? Any help would be much appreciated!
  18. Hi guys, how do I remover the black plastic inlet fitting from a grimeca rear master cylinder? I'm rebuild it and I think there may be a leak from it. Thanks
  19. 24’ mc 250. Bike ran fine last time i rode it, pressure washed it and now when the bike is off the fi light is on and solid along with the hour meter (hour meter runs if I don’t disconnect battery). Every 2 minutes or so while the bike is off and lights are on, it sounds like the fuel pump starts up for a second then will do it again in another 2 minutes.But the bike starts and runs fine. Only an issue when it’s off and sitting. Anyone ever have this happen? Any tips ?
  20. I find this counterintuitive, but if you blip the throttle, the clutch will release better. I've only ever noticed this on trials bikes. If anyone has an explanation or theory, I'd love to hear it. I've also found that dimpling the clutch steel plates has a very positive effect on clutch release. But this is a well-know trick, that I probably first saw on circa 1970s Suzuki OE plates.
  21. Hi I reverse bled the clutch however it still surges a bit when I select a gear although I find it weird that with the engine running in gear and the clutch pulled fully I can push the bike forward and back but if I stop the engine it won’t freewheel
  22. Here are some footpegs that i cobbled together. They are crude and heavy but allow me to try different peg placement, they are about 1/2 inch (12-13mm) forward and lowered the same amount. I also did away with the forward slant of the stock pegs. They are much more conducive to sitting on the seat and transitioning between sitting and standing, they affect ground clearance very little. They are a big improvement for me, I hope to have a nicer set made, I'm happy with the forward position but I'd like them another 5-8mm lower.
  23. I think you have only one choice nowadays that is the set made by SURFLEX approx £130.00 from a Trials specialist.
  24. Time Left: 23 days and 7 hours
    • FOR SALE
    • USED
    Tech Forks, Reiger Shock, S3 Titanium front pipe, Recent linkage service, Recent Genuine Handlebars and Dominoe grips, Recent S3 footrests, Recent genuine rear brake pedal, recent rear master cylinder, Recent sprockets. Regular oil changes, filter cleaned after every ride. Road registered, ready to ride.
    2,000.00 GBP
  25. Hi all, I have a pair of TY250 mono forks model 38V, but the left fork leg doesn’t have a thread cut into it for the axle bolt, the plain hole is small enough diameter to tap a thread into. I’m just wondering why it wouldn’t have had the thread in it already?. Has anyone come across this before? thanks
  26. IP booking now open. https://experience.inchperfecttrials.co.uk/em-test-ride-selby-trials-park-wimborne-dorset-bh21-3qz/ Don't forget to bring your bike and have a ride with us as well.
  27. '98 TX270 purchase last week. I removed the clutch cover to add oil and found the fiber squeezing out the side of the pressure plate. Remove the pressure plate and found the fiber in four pieces. Any aftermarket brands recommended for this model? I'll begin my Google search after posting. Thank you all in advance!
  28. Hi thank you I will have a look again tomorrow, when I pull the lever I would estimate the salve cylinder is moving 3-4mm
  1. Load more activity
