This stream auto-updates
  1. Today
  2. I'm thinkin' your probably right on that, guy53! I would do my GasGas 280's steering head bearings, swingarm pivot, and linkage in the winter (once a year), and it came apart and went back together fairly easily. On most of my MX and Enduro bikes I've owned over the years, once a year seemed good enough for those bikes. My Suzuki DR200 has been done once in the 4 years or so I've owned that one, but it gets ridden very little. It's my "other bike"......... But with the kinda "special" swingarm pivot bolt they give you with the Sammy Miller footpeg relocating kit (wider/longer length than the stock pivot bolt, due to the thicknesses of the new foopeg brackets), I believe I'm gonna need to do this greasing job a bit more frequently. I don't wanna take a chance on that "special" pivot bolt getting stuck like the stock one did.........
  3. Yesterday
  4. From my experience even if you grease regularely the swingharm it still '' freese '' , I think the answer is to take the swingharm apart a couple time a year clean regrease ..... Guy
  5. I found that I could make bushings fit better compared to stock replacements and they lasted longer, ymmv. but I also rebuilt microtomes for ~40 years. It's the front end of the TY250A plus the foot-pegs, steel bars, hand controls and stock tires that need the most upgrading ... the stock TY kickstart lever was terrible and with some work can be replaced with something far superior off a period street bike. Wheel bearings are one of the highest service and replacement items on any trials bike, with 2 TRS on the go I buy SKF bearings 10 at a time. If your brake and clutch cables are old it's well worth replacing them for the performance gains at the lever.
  6. You're fortunate to own a lathe, Lemur. I wish I had one. Ran one for Boeing for 20+ years before retiring. I would probably do something like you did as well if I had a lathe. Would try to add spiral lube grooves to the i.d. as we did frequently for bushings I made, to allow grease to flow in....... How often do you take stuff apart to slather some grease in there? I hope that you don't have the problems getting stuff apart like I did on mine. No telling how long mine went without any sort of regular disassembly, cleaning, and re-greasing....... Here's a picture of my recently removed swingarm pivot bushing that shows the cross drilling. Are all TY250's inner bushing cross drilled like mine is?
  7. Considering you haven't even specified the model or year 😕 might be far more productive if you post a photo of what you have. ... or refer to the parts diagrams and service manuals available online.
  8. I have a beta 250 trails bike no spark changed every part no spark now someone is saying that the stator is in the wrong place has any got a photo showing the right place it needs to be
  9. Ok. Managed to sort it. The wire from the led was crimped to the red wire instead of the switched red/black wire. It looked like a factory crimp inside the loom. Also found a resistor in the same handle bar loom. 🤷 Not sure what that's about. But I'll leave well enough alone. It's working sweet as now
  10. Hi guys. I've got a new to me em 5.7 around 2012 (no idea how to figure out the year) Basically the green light is always on. No matter if the battery is switched off or the switch gear is off. The only way I can turn off the green light is to disconnect the wiring at the 2 amp fuse . The handle bar switch appears to work for killing the bike. But the green light remains on regardless. I'm guessing this isn't right. I'll pull the switch apart and have a look. But any advice appreciated. Cheers
  11. That is a nice picture. It looks like it has less ground clearance than standard trials bikes. Is the correct? The ground clearance looks a bit like a TL250 which I think is one or 1.5 inches less that most bikes.
  12. Take a close look at the magnets on the flywheel. They would come loose over time. They would break when the mains became worn.
  13. Stock bushings are plastic, I always replaced the stock TY plastics with sintered bronze but that's because I own a lathe. Keep in mind with the bushings made from sintered bronze or self lubricating plastics and properly fitted, the job of the grease filling the tube is primarily to preclude water from entering and creating rust on the steel parts.
  14. New piston, engine bolts, seals. Ergal swingarm axle from 95>99 Techno (original 1994 : very heavy steel one)
  15. YAAAYYYY!!!! Success!!!!!!! A combination of soaking the inside of the pivot area overnight with WD-40, my goofy all-thread "press", and Feetupfun's suggestion of some heat got things movin' outta there! Thanks so much for your help, Feetupfun! I'm grateful! Truth be told, your posts and comments in other threads have been a help to me even when ya didn't know it. Again, Thanks!!! Now, has anyone here ever used Speed and Sports' bushing kit for a TY250? I ask because it comes with the tube the swingarm bolt goes through (the tube I just had a tough time getting out........ ), as well as the bushings and seals. But in the picture they show, it doesn't appear to be cross drilled for grease to get through like the OEM tube. Can't see how grease from the fitting is supposed to get to the pivot bolt....... Maybe I'll call them tomorrow and see what they say......... I know I could cross drill it myself, or possibly re use my tube, or........
  16. The small (trials style) tank that came with this bike does not fit very well as it extends deeper into the chassis and hits the solenoid and also pushes the cables tight underneath. So I just live with it in its intended config as a Long Ride. It's ultra quiet and perfect for idling around practicing balance!
  17. Last week
  18. Well, Big Lumpy Poopy Pants! It's lookin' like your idea to heat up stuff might be how it gets done, feetupfun........ My efforts with my all thread puller didn't work out at all. Can't get that inner steel tube to even budge a tiny amount. It's the first time I can recall stripping nuts and all threaded rod without being able to get something to move. I have the swingarm lightly clamped in a vise while soaking in penetrating oil for now, hoping that enough liquid can get through all those holes that grease is supposed to travel through to do some good for me. Judging by how tight this long steel bushing is in the plastic bushings, and how tight those plastic bushings are pressed in the swingarm, I'm beginning to wonder if I should've not even bothered to remove them. It also makes me curious about how reassembly will go as well........ Any tips, words of encouragement, and facts pointing out what a Goober I am are welcomed! Jimmie
  19. I found a used Climber CDI on eBay. It should be here by Friday. When get a chance I’ll check the stator/trigger coil for resistance. Hope I figure this out before Sunday, I have a trials then. If not I’ll be on my old reliable SWM!
  20. Another great project…can’t wait to see more.
  21. I bought this bike 5 years ago maybe 6. First Owner bike. Used stickers and plastics but this bike was in very good condition. It's time to work on this bike ... one of my dream bike.
  22. It's true, capacitors can degrade over time and alter the components performance. Only way I was ever able to 100% trouble-shoot a CDI module was to have a second machine and start swapping parts until the problems appeared on the other machine.
  23. Sono curioso di sapere come procede perche' sono anche io a fare il restauro....
  24. I'm sure that your puller idea will work. In case this is your next question, the plastic bushes can be hard to get out but they will shrink and fall out if you heat them up with a flame hot enough to burn the paint off the pivot tube.
  25. Yes I gapped a new spark plug to the specs in the manual. I can adjust the timing a little bit. I’ll try that next, thanks. I did read the CDI will degrade over time and cause it to stay in an advanced timing curve, causing this issue. Was hoping someone else ran into this and fixed it.
  1. Load more activity
