nigel dabster Posted October 14, 2007 Share Posted October 14, 2007 Two things trials specific I have is the beeders (mentioned lots before I know) and a cable oiler those little aluminium things which you squirt down wd 40 or similar to oil cables. For gas gas I have a ground down 19 for the brake pivot. WHYG? Quote Link to comment Share on other sites More sharing options...
kinell Posted October 14, 2007 Share Posted October 14, 2007 I've got a 5lb lump hammer in my toolbox Quote Link to comment Share on other sites More sharing options...
paul w Posted October 14, 2007 Share Posted October 14, 2007 WHYG? the telephone number of someone who knows what they are doing ! Quote Link to comment Share on other sites More sharing options...
gizza5 Posted October 14, 2007 Share Posted October 14, 2007 WHYG? Ooooh bordering on text talk there ND Andy will ban you have you not read the rules Quote Link to comment Share on other sites More sharing options...
windlestone Posted October 14, 2007 Share Posted October 14, 2007 (edited) Looking in my toolbox, i seem to have developed an allen key fetish, i've got hundreds of the blessed things quite fond of my dog turd tool Made a tool for taking off the 4rt front pipe Edited October 14, 2007 by windlestone Quote Link to comment Share on other sites More sharing options...
barrybaines Posted October 14, 2007 Share Posted October 14, 2007 At some point all of my toolbox has been taken over by a varying degree of bent and snapped levers (Obviously not mine someone must be playing a trick on me )I think I may even have one straight one in there! Really must have a sort out and find out were all the tools have gone though? All I can find is rim protectors a C spanner and many a allen key Quote Link to comment Share on other sites More sharing options...
copemech Posted October 15, 2007 Share Posted October 15, 2007 (edited) EVERYTHING, except what is needed at the moment! Did I tell you that you are supposed to use the tools BEFORE the trial! Cannot recall how many i have seen trying to change tires and lube the linkage AT a trial! Oh, amost forgot the nails, tha gasser guys always seem to need them when their footrests are falling off, I sell them for a DOLLAR! 125 Scorpa riders beware, Nigel wants to "lube y'er cable"! ```` Edited October 15, 2007 by copemech Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted October 15, 2007 Share Posted October 15, 2007 I had a Gas Gas a few years back and needed a 16mm spanner. Not used it on anything else since. Quote Link to comment Share on other sites More sharing options...
perce Posted October 15, 2007 Share Posted October 15, 2007 Two things trials specific I have is the beeders (mentioned lots before I know) and a cable oiler those little aluminium things which you squirt down wd 40 or similar to oil cables.For gas gas I have a ground down 19 for the brake pivot. WHYG? What's the other 3 tonnes of crap in there for then? Quote Link to comment Share on other sites More sharing options...
edgas250 Posted October 15, 2007 Share Posted October 15, 2007 (edited) Cable ties. Edited October 15, 2007 by EDGAS250 Quote Link to comment Share on other sites More sharing options...
kevin j Posted October 15, 2007 Share Posted October 15, 2007 special tools, not all carried to trials. flywheel puller, clutch/sprocket holding tool, chain breaker, assorted odd thin and bent 10mm for rear brake rod adjustment, brake syringes, couple of the yamalube cable lube tools, long special tools made for disassembling fork internals, 4-5-6-8 mm helicoils, thread restoring files, k Quote Link to comment Share on other sites More sharing options...
bob abell Posted October 15, 2007 Share Posted October 15, 2007 8" length of 20mm diameter ground shafting, used to knock out the wheel bearings with the aluminum spacer. 2" length of 2-1/2" tubing to support wheel when knocking out those bearings 42mm diameter tubing to install bearings 2' length of 1-1/2" ABS pipe fork seal driver Angle grinder with cut-off wheel to open up trailer (after keys locked inside) Bultaco clutch holding tool made from vice grip clamp Bultaco flywheel puller bodged up from pipe union and nut Bultaco transmission fill pipe made from copper pipe Mr Clean Magic Eraser...does amazing job cleaning up unpainted Montesa fender...(note to self: use magic eraser on scorecard next trial) Quote Link to comment Share on other sites More sharing options...
atomant Posted October 15, 2007 Share Posted October 15, 2007 Adjustable Spanners Full set of Screwdrivers Fluke Multimeter 6mm dome head stainless bolts 6mm nyloc and standard nuts assortment of metric bolts/nuts cable ties - large/small cable connectors super glue brake/clutch levers spark plugs chain link's Quote Link to comment Share on other sites More sharing options...
jezza Posted October 15, 2007 Share Posted October 15, 2007 Short length of electrical wire with connectors either end to by-pass thermostat on the rad, should the fan fail to come on. Long cable tie just thicker than a brake disc, slip between the pads when refitting wheels to keep pads apart, once the disc is lined up and part way in, slide it out. Quote Link to comment Share on other sites More sharing options...
gjbiker Posted October 15, 2007 Share Posted October 15, 2007 Most tools for most jobs until I bought my new gasser. How dare they change the thread on the flywheel puller !!!!!! I've already got 6 different types and none of them fit, suppose I'll need to add to the collection again..... On the subject of threads, I've just added a selection of Timesert thread repair inserts available from Wurth. Much better than helicoil if anyone's interested ? Happy spannering Quote Link to comment Share on other sites More sharing options...
