Ossa TR 280i hard to start
  • Replies 356
  • Views 152.9k
Most Popular Posts
  • canada280i
    canada280i
    I would agree with Borus here, I had some starting issues when running map 12 which were rectified by applying map 13, I also got a nice quicker tickover from 13 as well. The odd occasion that my bike
  • did your dealer set your tick over at 1400 rpm and tps at .6v after loading map 13? this is a new procedure, should only have to be done once, sorry to tell you but your starting issues are not normal
  • It's not user adjustable, your dealer sets both the idle and tps with the diagnostic program. 1400 rpm is a good healthy idle, (you will see) anything less on map 13 and you will have trouble starting
On a high compression 2stroke This sounds too good to be true :rolleyes: .... Can you please give us some clue as to how this will be done?
Best of balance.
Neo
Hi Mate
Decompressor maybe ? but you;ll need your hand to pull the lever...
<_<
Paul Mac
quote name='B40RT' timestamp='1315518684' post='279510']
Depends whats connected to the hand !
Don't think I want to know :unsure:
Edited by paulmac
..a small electric motor,perhaps? :rolleyes:
Key component - get the latest map loaded from the dealer (12 I think) - this addresses the hard start, and speeds up the tickover a touch.
No throttle
Neutral from cold
Wear Boots
Kick from the very top like you mean it
It gasps a little for the first few seconds
I now can't blame the bike when I stall in sections and it starts in gear first kick easily when warm.
the 2012 bikes seem ok to start, from cold you give
it 3 or 4 lazy kicks to prime it and them one like
you mean it and its off, when hot just the one like
you mean it and its fine.very nice bike to look at
and even better to ride
cant wait to get on it again
jsp
Mmmm have you tried the GasGas or Beta this is not an issue
Not surprising either as both of those engines have been kicking around (with minimal update) for donkeys years :lol:
Best of balance.
Neo
Best of balance.
Neo
And they run carbs that don't require a large dose of electricity to start the fuel moving.
Once you're used to any bikes starting ritual such as preloading the kickstart on a gasser to protect the mechanism it all becomes second nature
i also think it will get alot better as the motor
loosens up mines only been been riden once. the
dealer told me once it had run in it will be 2 kicks
to prime it and one to start, in his words when you
kick it to start it kick it like a 300 gasser and
so far so good
jsp
My bike after 1 month run in, still map 11 . But it is better now only 1 or 2 kicks to start ... May be the computer learns themselves
had my second ride yesterday and its got better already,
it seems to be other people that arnt used to it that
struggle to start it.
what a bike im more impressed after each ride
has anyone got any tips or things to check after pressure
washing
jsp
Edited by jsp
