New Honda 260 4 R T For 2016
They've got more than 1 gear????
I know, but the Mont will tend to ride stuff in first that 2 strokes simply can't, I use first often for most sections apart from big hills or bogs.
  • Replies 73
  • Views 30.3k
Most Popular Posts
  • shedracer
    shedracer
    New fuel pump, more power, new fuel maps, new silencer outlet, new Showa rear shock. All sound good to me. Honda not quite ready, to commit to the all new model. ;-)
  • johnnyboxer
    johnnyboxer
    Why add weight with a battery? Bike's electrics & starting is fine as it is, thanks
  • the addict
    the addict
    Dadof2, to be blunt and please don't take this personally but your talking bollox mate, the 4rt works just fine as it is, its not everyones cup of tea but it does what it says on the tin - end of.
I also tend to get left behind fairish in 2nd and third unless I'm concentrating pretty hard, pull your arms off most of the time.
Obviously when Honda developed the 4Rt they were looking for something to compete with 2Ts at the highest level and just as in MX this means making a 4t that can rev. Building an engine that can rev compromises its low rev performance (unless you add the complexity of V.V.T. and lift). I can quite happily rev a 4T very highly and have done so in MX, but when it comes to trials my formative riding years were when you rode clutch out in as higher gear as possible to maintain grip and stability. It would probably increase its appeal to a number of riders, myself included if a 4Rt could be set up to be ridden in this manner.
It does ride very well traditionally, 1st gear covers just about everything, whether its pulling slowly off the bottom end or holding it flat until the valves bounce and launching it into obit.
I have 1 particular section which was a 3rd gear jump on the 2 stroke, the 4rt manages it in 1st
Edited by jrsunt
[quote name="guys" post="398501" timestamp="14333
Excellent, few tweaks no drastic changes, why fix what isn't broke.
Edited by the addict
Hadn't seen the different exhuast outlet. May make it easier to add a spark arrester where they are required.
I noticed the photos are also showing the ECU mode switch next to the left grip. Maybe the 2016s are coming standard with a 2-stage (progammable) TB/ECU.
Also claiming further reduction in engine braking... #190 orifice to something bigger? I never really noticed much difference due to the earlier change.
Footpeg position moved back. Can't tell if this is from different brackets or the new 10mm set-back S3 pegs.
Radiator fan cage redesigned so pebbles can drop out easier and not jam fan blade. I had the blade jam once due to a pebble, damaging the fan blade beyond useability (melted plastic around steel hub) and the fan motor got hot enough to discolor. Must be that others had that happen too.
Edited by sportsawyer
The Race Replica certainly has the 2 maps.
On the 2014 and 2015 you could also use 2 maps, you only had to mount a switch in the right place.
Here we go.
RR, sounds interesting, my crystal ball was working well
Edited by jj65
  • 6 months later...
How can you do this on a 2015?
