January 2, 201610 yr When I started doing trials I was cleaning my air filter every ride Most of the time it was still spotless clean, so now I only clean it every 3-4 trials (unless its dusty) Does anyone else do this?
January 2, 201610 yr Let's just say I don't clean my air filter as often as I should............... I agree that a pristine air filter won't hurt.
January 2, 201610 yr I run K&N air filters in all my bikes , and as long as I know they are seated/sealed correctly I don't worry about them . Unless I've been in a very dusty event , which very rarely happens here in the southeast where I live ... But I do check their condition when I remember....... Glenn....
January 2, 201610 yr We check our filter after every ride, if there really dirty or wet we clean but if there's tiny amount of dirt we will just get the dirt out and put the filter back in But we always take two spare filters to everywhere we go, so it's not s problem if we forget to do it
January 2, 201610 yr After every ride, as a 4rt rider it at least gives me something to do in the workshop
January 2, 201610 yr Depends on the conditions,lot of water and deep mud or very dry and dusty every event.Normally every 4 trials but inspected every week I use NOTOIL which seems the best and stops pretty much everything going through the filter.Also depends on the bike,some brands are worse than others for dirt getting to the filter?Beta for example the filter is at the top of the airbox so anything seen in the airbox has got through the filter and enter the engine,whereas GasGas the filter is on the side of the airbox so dirt inside the box doesn't matter as much as long as the filter stops it .A lot of engine wear comes from poor filter maintenance,it's better to err on the side of over doing it
January 2, 201610 yr Every single time the bike goes out, couple of spare filters so always a clean one available makes the job easy. also Brake pads out as well every ride. oil chain Polish That's it for a mont
January 2, 201610 yr About every three months or so but my sons bike is an Ossa and the filter is well out of the way. Now with Gas Gas and JGAS every ride. Keeping the Air boxes clean was a nightmare on those things. Going back to the 2004 Sherco and that was just a nightmare to seal. The Whole Airbox and mudguard was one unit so if you broke it the Filter was exposed.
January 2, 201610 yr Being split between dry and dusty and waist deep in mud I clean the airfilter and airbox after every trial. I also put a very fine smear of grease inside the engine side of the airbox to get anything that gets through the filter.
