miner Posted November 18, 2017 Share Posted November 18, 2017 As above.... anything obvious to check? Following on from my thread about a cracked rear rim on the Gas Gas sub-forum, my wheel has been rebuilt but it's not holding pressure. When I went to pick it up the tyre was pumped up to 17psi to set the bead on the rim, so I dropped it to 5psi when I went to take it for a short run to check everything, seemed ok. However it's not holding pressure, been checking it and its going flat within a few hours. Rim is going back to the shop but as above... anything obvious? Checked the tyre, edges of the rim and nipped up the valve... anything else? Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted November 18, 2017 Share Posted November 18, 2017 Have you put the assembly in to water to see where the bubbles come from (a good argument against doing away with the bath)? Quote Link to comment Share on other sites More sharing options...
miner Posted November 18, 2017 Author Share Posted November 18, 2017 You mean it's for more than throwing dirty washing in these days? Not tried it, might give it a go actually... tyre shops usually have a trough for that. Bath / trough? Same same Quote Link to comment Share on other sites More sharing options...
faussy Posted November 18, 2017 Share Posted November 18, 2017 Rim tape, if your wheel has one Quote Link to comment Share on other sites More sharing options...
miner Posted November 18, 2017 Author Share Posted November 18, 2017 New rim tape for rebuild... something as simple as the placement? Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 18, 2017 Share Posted November 18, 2017 What tire? Quote Link to comment Share on other sites More sharing options...
miner Posted November 18, 2017 Author Share Posted November 18, 2017 Pirelli MT43 Quote Link to comment Share on other sites More sharing options...
tony27 Posted November 18, 2017 Share Posted November 18, 2017 Tyres can definitely be an issue, some brands really struggle to maintain lower pressures. IRC are well known for it & your tyre being of an older generation may also be the problem Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 18, 2017 Share Posted November 18, 2017 Likely rim tape either incorrectly fitted or damaged. If it's a flanged late type rim it's likely the tire. Chuck mt43 in the bin 2 Quote Link to comment Share on other sites More sharing options...
paul heys Posted November 18, 2017 Share Posted November 18, 2017 Will be leaking through spoke nipples rim band buggers to seal Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted November 18, 2017 Share Posted November 18, 2017 They are. The old ones were tricky with a seperate valve, but I could always get them to seal Quote Link to comment Share on other sites More sharing options...
faussy Posted November 18, 2017 Share Posted November 18, 2017 13 hours ago, miner said: When I went to pick it up the tyre was pumped up to 17psi to set the bead on the rim, Or maybe to make you believe the tyre was holding air..... At high pressure a badly fitting rim tape is forced against the rim and seals, low pressure less force so it leaks. 1 Quote Link to comment Share on other sites More sharing options...
miner Posted November 19, 2017 Author Share Posted November 19, 2017 Maybe.... main mechanic is co-owner and pretty handy but he's recently brought a few guys in... couple of my mates have got tyre dollys but taking it back on principle. Quote Link to comment Share on other sites More sharing options...
rabie Posted November 19, 2017 Share Posted November 19, 2017 mt43 aren't going to set the world alight as the best trials tyre but there is no reason why they shouldn't hold air. Most trials tyres now come marked "TT/TL" ie both for tubes and tubeless - they will create a seal with the rim to hold air. as many have said above check the rim tape, ideally with a water bath of soapy water (bubbles = leak). I've seen guys go around with the inner part of the wheel with silicone on every spoke top, then strips of duct tape to make a better seal.... 1 Quote Link to comment Share on other sites More sharing options...
miner Posted November 30, 2017 Author Share Posted November 30, 2017 Wheel back from the shop.... flat overnight again! Leaking at two of the spokes, one quite badly... they'd sent me a video of the valve in the water to show it was ok as well.... clearly not looked that hard for the rest though. It's going back again... but any suggestions on how to rectify? Quote Link to comment Share on other sites More sharing options...
