Reliable low maintenance bike
On 1/29/2022 at 7:36 PM, TimDH said:
Currently have a 4Rt which I've lost all confidence in brake wise so I'm looking for another brand.
I don't want to be fettling all the time but I've no idea what would be a good choice.
Budget isn't an issue and I'm excluding GasGas as they are frankly rubbish quality.
Just buy some AJP calipers and master cylinders from the earlier 250 4RT version (2005-2012/13) if you are riding a 260 4RT model
Never had an issue with AJP brakes, plus there is a multitude of Nissin options from H&D or that man in Spain, for later 4RT's
Edited by johnnyboxer
  • Replies 32
  • Views 12.2k
Most Popular Posts
  • trapezeartist
    trapezeartist
    I think you're asking the impossible. All modern bikes are reliable, in the sense that they rarely break down. If you get yourself stranded, it's far more likely to be because you broke something.
  • You should have been around in 2011 with formula brakes on the new models. Most brake problems are self induced and almost all trials bikes use the same parts.
  • I was thinking he same thing !     I think this nice gentlemanshould not call gas-gas brand trash.  They have a new factory. with ktm-s help they will be around long time i hope.  TimDH should just go
17 hours ago, magnapoxy said:
My advice to you is to not have such a smart mouth when a member is joking & suggesting to learn how to repair a simple brake issue--
I assume you're the resident forum troll,every forum has one.
You're sorrt are best ignored I think.
Edited by TimDH
Mine has AJP brakes.
I'd still like somebody to suggest the most reliable modern manufacturer though,somebody must have a decent model.
I would have to suggest that all mainstream brands are reliable, I would have no problem riding any modern bike way out into the woods. Fuel capacity is the only thing to hold these modern bikes back and that can be solved mostly with a few fuel bottles. I have never been stranded on any of my bikes, broken clutch cable once, not stranded, took the easy way back to the truck.
All modern bikes also have a few niggles at times. Conventional wisdom says that Montesas are the ones that give you "Honda quality", although the Montesa sub-forum seems to show as many problems as other manufacturers. Typical problems across all makes are bleeding brakes, thermostat failure, dodgy ignition.
Don't throw out the baby with the bath water. If you have a good bike with a single problem (which it seems you probably have), solve that problem. Ask in the relevant sub-forum for specific advice.
On 1/30/2022 at 8:56 AM, TimDH said:
A quick search of this forum suggest otherwise,just saying 🤣
My guess is that if you dont have a problem (99%) then you arent going to post " my brakes are fine" ?
Honda/montesa probably, but read the answers above.....
What a ridiculous thing to say.
2 hours ago, section swept said:
Oh dear, and only 17 posts and its looking decidedly problematical.
I was thinking he same thing !     I think this nice gentlemanshould not call gas-gas brand trash.  They have a new factory. with ktm-s help they will be around long time i hope.  TimDH should just go and buy a 3 wheeled tricycle. one with handle bar grips that have baby doll heads on the ends of the grips-- custom !!    He did say in his 1st post that $$$ was no issue after all ---
If it's a contest for reliability without performing maintenance, I would vote for the 4RT.
If it's a contest for the bike that will let you ride in the most competitions, then I'd vote for whichever one has the best after-sales support where you live because riding in trials you are going to break things.
My thoughts exactly, asks for opinions, yet has the opinion gasgas are rubbish, while probably having never owned one
Edited by faussy
I like my gassers, I get good parts support for them, if money was no object I would likely move on to try something else. I'm still not stranded in the bush, bikes are still much more competent than I.
Am I missing something? Can anyone elaborate on this....
Elaborate on budge not an issue or Gas Gas being rubbish?  I think the budget one is clear so...
Gas Gas is well known to having had more issues with things like the transmission, water pump, kick start gears, and a few other things than most other brands and a good number of the issues cause the case to need to be split.  The newer bikes are a lot better but even then when they are used hard they still are more prone to having issues than some of the more robust models available.
I make this statement based on a combination of experience with my daughters Gas Gas, some friends with them as well as others I know well who I trust who have had them in the past.
Even then, its just my 2 cents so take it for what its worth.
