- Today
Thanks for the advice. I will drain for storage. And draining between trials events probably is a good habit in season. I'd consider replacing with aluminium tank if not so pricey! Cheers.
Fantic301 joined the community
While it's probably OK to leave fuel in it, it would be kinder to the tank liner to store the tank dry over winter. Nowadays after a ride, I drain and dry out my lined fibreglass tanks if it will be more than a few weeks until the next ride. My oldest epoxy tank liner is about 20 years old now. For the first 15 years I left that one with fuel in between rides and it gradually changed from honey colour to dark brown over the 15 years. After I noticed this happening I started draining it between rides and now at 20 years it is still working fine. It may still have been OK if I had continued leaving fuel in it, but the colour change made me wonder if it was being gradually damaged structurally. For info, Caswell liner is epoxy resin
I would not leave fuel with ethanol in any motorcycle over the winter regardless of the tank material. Stabilizers may be helpful in preserving fuel but I would not count on them. Even though your tank is coated I think it is still a bit risky to ever use ethanol containing fuel in a fiberglass tank.
So We were at a National in late 2004 in the states. A friend had a 300 pro. Just after getting his score card and starting his bike he broke that case right before our eyes. Luckily Dale M. the USA gas gas importer was in line with us. Dale ran back to his trailer, pulled out the case and a gasket and handed me the parts. I had the bike back together in 40 minutes. We all finnished on time and had a great weekend. We sure will miss Dale! Thanks Arnoux for hanging out posting and helping everyone!
That’s a fantastic heads up thanks so much for that mate
Hi Pat, a tip from doing a tonne of these over the years, you will need to replace the internal bearing that is in the crankcase that supports the kickstart shaft. The GasGas part number is MT2802260067. When this gets worn over time it allows the shaft to move at the furthurest part inboard, and this then cracks the case. If you dont change that it will happen again. There is a huge amount of stress on that bearing and they need replacing over time. It has a "blind" bottom , so it is like a cup. It can be knocked out easily with a drift from the left side of the bike - yes the LEFT side! If you look from the left side just below and behind the carby area on the crankcase right side you will see it's "bum". Once you remove the kickstart shaft you can knock it out to the right with a drift. You MUST do this when replacing the case. Jim Snell's old kickstart video is a help with the technique to get the shaft out: Jim's TXT Pro kickstart video
Let me know what you find, Pat. I’d be really interested. I hope it’s not too serious and good luck!
Blanco started following Fibreglass Tank Question
I have a Caswell-lined fibreglass tank and wondering if I should, or need to, remove fuel mix while storing over the winter (Canadian) and if so, should I replace it with something or okay to leave empty. For my street bikes I just top up tank and add a bit of stabilizer. I asked my neighbour who owns a boat and he says it should be fine if it's treated/lined as it protects from ethanol. Thanks in advance.
Zeez that post is old. Can't believe it has stuck around for all these years since I wrote the article. The fix works Cello.
Hi Ron I’d a feeling I may be at fault but there’s no harm in asking the question. I’ll start ripping into it in the next few days and hopefully all isn’t too bad. Thanks for the reply mate
Hey Pat, I’m no expert but I think the crack in the casing is your problem. It was probably kicked very hard in its life and cracked. Now, it’s my guess, that the kickstarter flexes the shaft just enough so that things are not engaging properly. The kickstart pinion gear and shaft may even be damaged due to the flex. My suggestion would be to open everything up, examine the shaft and gear. I’d also get a new clutch casing or potentially weld the existing crack. Good luck!
Hey Chappo, If you look in the original parts manual from GasGas it states C3 for the bearing.
- 1 reply
- 1
PatMc started following 2005 TXT 250 starting issues
Evening folks Ive a small issue with my bike , it can be tricky to start, it feels like the kickstart is only engaging at the bottom of the stroke of it. I know this model can have a knack to start but any feedback or help would be great. Also the clutch casing has a crack in it (please see attached photo) where kickstart runs through which I’d assume would not help. What could cause this to crack ? Again any feedback and help would be greatly appreciated Cheers Paddy
mcman56 started following 1999 Gas Gas TXT 250 Main Bearings .
Hi folks, I’m just rebuilding the above engine. I’m after a set of 6206 main bearings for her. Im trying to establish if they are C3 or standard bearings that are required. I’d have thought C3 , but just making sure as it’s for a friend. Thanks everyone.
A new Michelin Light arrived this afternoon, too late for this year but I'll be ready for the spring
Don't know how to "repair" the gear lever. I could drill a hole thru and use a passing bolt, maybe, covered with a piece of hose for the time being? Or I could use two metal clamps to keep an L shaped piece attached on it?
Blanco joined the community
Thanks... makes perfectly sense. I don't think I'll be on the hunt for a Pioneer exhaust, it would probably make more power up top but I plan to use it for "semi-trial" stuff at low speed, so it's probably better to keep the Explorer exhaust with the smaller carb. I guess the cylinders are also different on the inside (bigger intake/exhaust ports)? I never worked on Amal carbs, so don't have any jet for it... hopefully the stock setting will work with the actual setup.
1973 Ossa Explorer - issues with engine transplant
feetupfun replied to Triad's topic in Classic Trials
If you are using the Explorer exhaust system, there is no advantage in using anything bigger than the 27mm AMAL. The Pioneer uses a bigger carby because it sucks a lot of air when it is on the pipe. The Explorer exhaust will mean that the Pioneer motor will suck about the same amount of air as an Explorer motor at full power. -
Artem started following Problems launching Vertigo Vertical Works 2019
Hello, could you tell me what could be the problem with starting a cold engine? I have to put the bike on a stand and kick it as hard as I can about 20 times. After starting, the bike starts right after turning off the engine, but if it sits for 2 minutes, it is very difficult to start again, sometimes even impossible. The bike has a lot of mileage (about 1000 engine hours). After purchasing it from the previous owner, I replaced the fuel filter, fuel pump, injector, hose clamps in the gas tank, ignition coil and condenser in an attempt to find the problem. After that, everything got better, but the problem remains. Direct fuel injection into the intake manifold helps; in this case, it starts every time. I read all the threads on the forum and came to the conclusion that the problem could be in the crankshaft seals or sensors. I have seen people installing small batteries in the filter block, but I'm not sure which wires to connect them to? To the capacitor or to the battery connector, which should be under the seat? I think this option should help, I'd be grateful for any help.
Artem joined the community
Ok guys, managed to find a Motoplat coil and the right kickstarter lever for this engine. Also got a tank with petcock, but they're both pretty much trash. I poured some pretty rich premix inside the spark plug hole and the engine came to life, with huuuuge surprise. Started but died after 1 second. The second time I started it, lasted maybe 2 seconds. In the meantime I tried to put the tank in place with a hose going to the carb, but ended up badly with my cursing and fuel everywhere. Today it started at first kick (!) and for maybe 8 seconds... I managed to twist the throttle a couple of times before the fuel into the bowl finished and it died... but it's aliiiive! As you can see the carb is the Amal from the Explorer engine... should I get something more modern and better for the Pioneer engine? I read it had a 32mm. The guy I got coil, kickstarter lever and tank from, kindly sent me for free a rear brake cable and a broken gear lever (I'll have to find a way to make it work).
Seen the top riders motorcycle get stolen at a 2-day national, had two nefarious individuals attend one of my events purely for the purpose of delaying and disrupting the event, now I have security at events to stop that nonsense.
Local events in my State in the US do not have pre-entry. Just roll up the day of 2 hours before start of event and sign up is open. You can sign up for AMA at the event, but honestly that is a P.I.T.A for everyone involved. Sign up for AMA on-line and either bring the new card to the event or some sort of electronic verification on your phone if the card has not arrived. Security at a local Trials event??? that's nuts. we could leave a $20 bill on the sign up table and people would think it was a collection to help somebody out and add to it. As far as I know we have only had 1 theft in MOTA in 25yrs. A set of handlebars was taken from a mobile dealer.
I've just had a stator for a Fantic rewound at West Country Windings and they seemed very efficient, not fitted it yet but my brother had the same done some years ago and its still working
Yeah, you guys are talking about two different types of events. Our local event does have pre entry, but you can sign up at the trials for the same costs. We have had portable toilets at local events for about 2 decades as the total people count is about a hundred. We are having a National next May. Already working on the sections. The Nationals thrive on having a real number of pre-entries, you can enter on site the day of the event, but costs a hundred dollars more! Security? You guys don`t live in the states. Even our Pastor at Church carries a gun under his Robe.
