- Today
Be a good idea to inspect the o-ring grooves in the back side of the head for cracks. The exhaust mount bolts to the head stay and if the suspension is bottomed out it tags the header pipe and levers against the cylinder head , have seen it fracture the head in the mentioned location ..hopefully yours is okay
There is a few different types of Stators for the BOY50 so make sure you order the correct one for your bike. The real early ones were much simpler construction, o easy to distinguish visibly. We have the Leonelli ones in stock. https://www.thehellteam.com/stator-flywheel-boy
https://moto-classic.com/gas-gas-boy-flywheel
Please check emails i need help 😂
matt1990 joined the community
Hi all. Don't suppose anyone has a stator for a 2005 txt boy? Little boys is messing around. Doesn't spark unless you kick it over really fast for ages then it will spark fine. It's the internal rotor stator
Hi, Thinking of fitting a PWK 28mm on the old Gripper. A common mod by all accounts, however I’m struggling to find the basic start jetting for these carbs. Does anyone know and willing to share? I have an 28mm OKO already but I guess it’ll need jets/ slide/ needle to suit the gripper. TIA Brent
Since Triumph bought Oset, they are not supporting older models. Even with current models parts are not available. I have been trying to buy a TXP 24 rear tire but they don't have any with no ETA. Triumph doesn't seem to care about trials.
Silicone has a higher heat tolerance than NBR, so if you can that would be better. Both will tolerate the Glycol.
Joda76 started following Head gasket change on Ossa TR280i
Hello good people. I bought my self a cheep defective Ossa. It is in a rather good shape, only inner head gasket is blown. After cranking it pops like a champagne when opening a radiator cap. Coolant that I have drained smells on gassoline. As I can see 4 side bolts will be the problem to torque with my Nm torque wrench because of a frame interference . Should I use some special tool , or release engine in front and pivot it a bit to make some clearance? One more thing. I read that inner oring is better to be silicone than NBR one, any oppinion on that? Many thanks !
Joda76 joined the community
Nickvb1 joined the community
Thank you for taking the time to explain it Ron! I'll have to look into this now
Thanks, found out the rev 3 shouldn't have a shim at all exept the bearing washer
That's a really great tip! I knew mine was original, so I figured if it wasn't leaking now it would be soon so I didn't bother testing it.
Had the same jet block leak on my Beta. I diagnosed it like this...
Thank you
It won’t reset. They only let you load a certain amount unless you become a paying member. The other way to load pictures, without the limit, is to use a photo sharing site that stores the photos there instead of on Trials Central. I use Flickr but there’s others. Somewhere on here is a description of how to do it but I always have a hard time finding it. You can also just include a link to the photos for wherever you have them stored. Good luck! I found the direction to uploading photos: https://www.trialscentral.com/forums/topic/43691-posting-photos/
Wondering if any regulars of this forum would be able to give me a little insight, as I was posting pictures before it said the file size limit was 3.5mb, now it is telling me its 2mb which is too small for the resolution of the photos I currently have, is this something that resets or if anyone has any input I would appreciate it😊
Thank you! I wish I knew more about the pictures but there was nothing written on them. I am actually not sure who the gentleman in the yellow Jacket is as my Uncle is the man in the 2nd picture leaning on the 1 bike smoking a cigarette with the M49 closer in frame
Looks like I've reached my attachment limit here on the forum so no more pictures unfortunately. Not completely satisfied with the idle on the bike, it's slightly erratic. Suspecting possible leaking jet block gasket - got one from Jetsrus.com so I'll hopefully get that installed tonight.
Rear sprocket guard also installed... any of the newer sprocket guards from the pro models will also fit these older bikes in my experience.
Front brake rotor guard from TheTryalsShop in New York is installed....
https://www.trialsuk.co.uk/parts-accessories/levers/front-brake-clutch-levers/Apico-ELITE-Forged-SHORT-AJP-Lever-With-Coloured-Play-Adjuster
Thank you. I'm going to try them or the ARC levers.
A Full face MTB helmet is safer to your teeths and more ventilated. But, yes, too light for motorcycle helmet? They have MIPS technology and people in bike take serious jumps at much higher speeds than us.... The truth is: Trials helmet stopped on time and innovation is required by users for sure. Who will fill the gap???
Check if Trial solutions has them for Beta.
If the same as mine, where they go into the hub they are M6. Bear in mind though that they are special shouldered bolts
