Today
Choke fouled by bracket
I couldn't tell you how the bike was setup from factory, but could you just nip off the end of the choke lever leaving it a little shorter to clear the bracket? Buddy of mine had to do that on his newer TRS.
Oxford Ixion Mcc The Norton Cup Trial
Report Ken O'Brien. Fine weather greeted a host of riders from many different Centres to contest the Norton Trophy for best Pre 65 machine on the White Eased Route. Despite being primarily a Pre 65 and Twinshock event all classes were welcome and catered for. Much rain on the preceding days meant for a shortened course as waterlogged areas of the farm were a no no. Four laps of ten sections were ridden with a variety of roots gullies cambers and several Big Hill Climbs. The sun was low in the sky the temperature never rose much above zero and to these elements add four laps of ten sections with slick cambers and turns the scene was set, although time was of the essence as an amber flood weather warning had been issued by the Met office and heavy rain was due around 2 o'clock. Best Pre 65 and the Norton Trophy went to BSA Bantam mounted John Hawthorne losing 3 marks with the furthest clean tie-break being brought into play as BSA Rigid Bantam rider Martyn Wilmore also finished on 3. Section two, a hundred yard steep right-handed cambered sand and mud mix climb was harder than it looked, but many years of Trials experience shone though with both riders dabbing only once apiece on the way up, the down was equally as steep and tricky anchoring up before a snotty little turn back up towards Dean Basford who was waiting to pencil in any marks lost on the observers board. Best Twinshock on the eased White route went to Matthew Fithon whose beautifully turned out Honda TLR 250 purred around the two mile course for a loss of 11 marks, a very respectable score beings the day didn't start as expected with a 3 at the first section on lap one. This hazard Consisted a very loose fifty yard drop before lining up along an awkward camber then a seventy yard muddy blast to the ends high up the bank. Best Pre65 on the yellow Hard Route was Ben Wilmore 500cc Triumph losing 5 marks with section nine proving a tad tricky, a boggy turn around a drainage culvert before rising to a tight turn around a Briar then a hop over a fallen tree then descending though more bog before a very testing flick over a big root and out, Ben took 3 dabs out of his four visits but this was an excellent performance on the Big Twin. In the Twinshock category Hard Route David Bathe TLR 250cc just edged out Paul Hadingham 340cc ( Triggers Broom Bultaco ) 6 points to 9 both cleaning with ease where many failed section four. A fiercely steep wet sandy downward slope with a turn along a narrow ledge before a sudden drop to the Bramble bank with a couple of low growing boughs to negotiate, then the tricky bit, lining up to to get maximum drive in a high gear for the sixty yard undulating climb ending up by the fence line, these ageing Twinshocks nailed it every time. Mark Davidson put the best effort in on the 50/50 route riding modern machinery, section five was taking plenty of marks but not this Mark as he dropped the little Beta down the first of three steep banks no problem as were the three steep climbs that followed, Mark parted with 29 for his troubles. Jack Pettit Beta 125 and Tommy Goodwin 300 Evo were both having good rides in the Youth A and B classes on the Hard Route, section four was not for the feint hearted, starting in the bottom field and once though the 'begins' you were confronted with a blind turn before blasting up a forty yard extremely steep loose climb, both were excellent here as 100% concentration was required to stay on the correct line if you were planning to make it to the summit. Jack Turner 250 TRS lost 1 mark on his quest for glory in the modern bike Clubman class and in the sportsman class Simon Dowling topped the entry after a re-count and amended result. A gathered crowd were waiting at section eight Axfords Gully as it's easily accessible and a good watch, around thirty yards of continuous flowing water in an ever deepening narrowish stream before a third gear blast out and a slick ' hang on ' til the ends as water dragged up the bank requiring full pin action to make it, Simon was inch perfect every visit so an great ride. Many thanks to all who helped on the day...... Next trial is on the 27th Dec at the farm.
Results Norton Trophy 2026 V1.pdf
Last week
TY250 Mono Rescue
ScottDownSouth started following TY250 Mono Rescue
Aprilia Climber 280 1993
I have a little lathe. So I machined steel parts in titanium or 7075 alloy. For the rest, I order in china. It's easy to save weight on older bikes because some solutions came during the 90's. The Climber is a heavy bike and it's nice to upgrade it. I try to respect the decade. I don't want to equiped a 90's bike with 2000 2010 or 2020 parts.
2027 Beta Sincro
Any input on the upcoming Beta 2027 sincro Trials bike
TYupandover started following 2027 Beta Sincro
It’s amazing to me that you find all those titanium parts for those older bikes. There’s only one place that I’ve found titanium for my 2033 Gasgas and it’s only for bling than anything else and is very limited. I can’t afford it anyway so no big deal.
John41 joined the community
ad02gray changed their profile photo
Just bought a 2000 gasser 200txt, i have noticed that the carb isn’t sat correctly in the rubber port. When it’s pushed in and located correctly the choke lever is then fouled by the engine mounting bracket. Has anyone had this problem and solved it? As the bike is 26 years old I’m expecting something to have been fitted incorrectly or maybe something missing. Have added some pictures to help. Many thanks, Ad
ad02gray started following Choke fouled by bracket
ad02gray joined the community
7075 alloy make a big difference.
X-Trial Predictions Competition
Prediction entries are now open. If you haven't joined already, check out the rules at https://mototrial.co.uk/predictions/rules.php and then join here https://mototrial.co.uk/registration/join.php. All the usual suspects will be there: Toni Bou, Jaime Busto, Gabriel Marcelli, Harry Hemingway. They will be joined by Matteo Grattarola, Arnau Farré, Miquel Gelabert and Sondre Haga.
Kenda ibex rear tyre?
Had my first ride on an Ibex today & really impressed with how it performed, I rate it as better the the Dunlop Geomax
Titanium rear axle (110gr less) 2x titanium bolt -25gr
Award in the high court
So no SSDT next year?
- GAS GAS JT25 1995 overhaul
Titanium swingarm axle and fresh sachs alloy shock.pauham9 joined the community- Fuel pump issue on 301rr
Brand new 25 301rr, sounds like a cracking find to me 👍- Hot start issue
Have a micrometer available when you set the valve clearances, use the micrometer to test feel your feeler gauge first, that gives you a more accurate setting when you adjust the valves. The valve adjuster screw has a square head that is the same size as a red (#2) Robertson screw head, you can improvise a valve adjusting tool using a short stick of wood and a Robertson screw.- Fuel pump issue on 301rr
In 2024 there was a recall issued by Honda in regard to faulty pump impellers. You should not be too worried about recalls, those are issues that have been identified and in theory resolved. The biggest ownership problem with the fuel pump system is that the high pressure filter canister is not a replacement item and only offered as an entire fuel pump assembly. Don't drop the bike in a lake or you will be looking at an expensive repair.- Fuel pump issue on 301rr
There was a problem with a manufacturing process with one of the materials used in fuel pumps, the issue wasn’t exclusive to 4rt’s but appeared on many Honda products. Hopefully the affected parts have been removed form production by now.- Hot start issue
Agree with Lemur, most certainly the valve clearances. Get a workshop manual for the bike. There is a step by step walkthrough for everything. I’m sure there is also some advice on here. Not a hard job, but quite fiddly- Fuel pump issue on 301rr
From a dealer? Maybe ask if he stocks a replacement fuel pump and the cost, if he says no then it should give you a hint how often they need replacing.- Fuel pump issue on 301rr
I am picking up a brand new, 2025 301rr next week. It will be my first. I seem to be unaware of what the specifics are related to a fuel pump issue, other than there seems to be one. Is there anything I should ask from the dealer either before I buy or when I pick up about this? What should I look for in terms of this problem and what has been the resolution?Kschwartz started following Fuel pump issue on 301rr- old but new
There are lots of alternative components or circuits that can do what needs to be done to regulate the power output from your alternator such that it does not over-power your lights, all they are doing is to limit the voltage spikes produced by the alternator to around 7 volts. Robust is the function of the components ability to dissipate excess voltage in the form of heat, so whatever you use it should have a way to sink the heat.- 2022 gas gas txt 300 jetting
If you are talking to me, I've been searching for a bit crisper response plus a cure to the erratic starting issues. At the moment I am running a 42 pilot, stock needle and clip position and a 122 main. And as it has always been, regardless of jetting, sometimes it fires right up, then its 6-8 kicks. Hot or cold. Actually seems to start OK more often when cold- 2022 gas gas txt 300 jetting
Sorry for the late repsonse, haven't been on. When I was in the process of buying the bike, and was shopping for the best deeal, I talked with Mike, the owner of Trials Superstore. His shop is one of if not THE largest Gas Gas trials dealer in the states. He does not sell any other types of Gas Gas bikes. Anyway, in one of our talks he mentioned that the 23 - 24 model year bikes were blowing up trannys. I think he mentioned this happened more with expert/pro riders but warned me none the less. Said he had ZERO issues with the 25s. So I looked in the online parts fiches, found the parts that were different and ordered accordingly. I believe one of the shafts, main shaft I believe, plus a couple of gears. I haven't had any issues so far other the all of the metal shavings but I wanted to get the parts while still available, in case there is any issue in the near future - GAS GAS JT25 1995 overhaul
