- Today
44Dwarf joined the community
Good quality gear oil to suit a trials bike. Moving the lever location on the bars so you are pulling further out on the lever. Depending on how low low hours is 2017 is also old enough you might want to consider filing any ridges that exist in the clutch basket tabs from wear with the clutch plates.
Dirt-preacher joined the community
Hello friends. I recently purchased a 2017 Evo 300 with low hours. I love the bike but would like better slippage on the clutch. It does slip but is mostly on/off engagement. I’m new to Trials bikes. Is there an adjustment for this? Thanks for your help.
OudeCota_NL joined the community
Glad you found it helpful. I should also mention something about all emulators that may not be readily apparent. 1. You must enlarge the compression hole in the damper rod enough that it's no longer an effective restriction. The emulator then controls the compression-damping orifice. If you ever want to remove the emulator, that enlarged hole must be welded or brazed and re-drilled to its original size. 2. The emulator sits on top of the damper rod. It must be removed from the fork to make any adjustments.
Thanks Konrad being new to trials, twinshock mods can be a minefield
mcman56 started following H&D Montesa Suspension linkage ?
How much do these links raise the bike? Does it provide a softer ride? The H&D description is hard to interpret. I'm not a trick rider but would like something more compliant so easier on an old body. The Montesa rear suspension also feels quite dead compared to my Beta 4T. "uprates the soft rear end and aids the ability to 'trick' ride and hop around the rear end by providing an even more progressive shock."
I have experience with YSS emulators. They provide the same benefits as Race Tech's emulators -- variable compression damping. I was unfamiliar with HFS Expert, and had to do a search. https://suspensionhfs.com/en/ https://suspensionhfs.com/en/ This appears to offer the benefits of a modern cartridge fork, which is a huge advantage over damper-rod forks. I would not hesitate to try them. Being 155 pound in your riding gear means you will want their light springs. (I'm about the same weight.) If you go with YSS emulators, you will still need to source softer fork springs. Whatever you choose for the rear, make sure there are springs available for your weight -- especially if you have softer than standard springs in front.
Hi guys could do with some opinions please. Over the last few years I’ve lost abit of weight and fitness, im now 155 with kit on. It’s got it’s downsides this getting old malarkey Anyhow, I’ve decided I’m going to go full on with a refurb starting with the suspension F/R on my Fantic 200 So opinions please on … Front - HFS Expert or YSS Emulators Rear - Falcon or Rock Shocks Or feel free to say if you think there are better options?
Are we going to get an early water cooled class in EVT?
Took the Climber to our vintage trials last weekend. Worked great 👍 Fun bike!
New Trials Rider in Denver, CO - 2004 GasGas TXTPro Raga 300
RonH replied to mostexcellentdude's topic in Introduce Yourself
Nice looking bike! -
thanks it was spark plug indeed!
Hello everyone, My name is Eddie and I just picked up my first trials bike. I live in Denver, Colorado. Have experience riding a KTM 300 on mountain and desert singletrack, but never ridden trials before. Excited to get started! If anyone wants to show a newbie the ropes or suggest places to ride, let me know!
Spark plug
robson started following hiccups while on throttle
my gasgas 300 txt developed hiccups while on throttle, idle is fine where to look first?
Thanks so much! I was happy to have found them both. They are very original machines that have not been abused. Well, not yet
- Earlier
Restoring my one owner 1976 TY175C Yamaha purchased in Japan. I am installing a new piston & rings tomorrow. 80% done
I love all three of your beauties! Your TY looks fantastic (so does the Honda), it still has the tail and headlight on it along with the original plastics. Plus, I can see that awesome, pristine saddle you didn’t know you had. Thanks so much for the photos!
Hey gasaxe You DO NOT need to split the cases. You do not need to remove the engine. You can check, and fix, this quite easily with just the removal of the clutch side cover and the clutch pack. Under the clutch pack you will see were the shift shaft comes right through into the clutch case. On the end of it you will find a top hat shaped piece and spring (see link below for image) https://www.thehellteam.com/gearbox-selector-spring-assy It is more than likely this is the only piece that will need replacing, but even if the shaft is damaged (less likely) from 2012 GG made the bikes so the shaft could be removed with the removal of a small retaining screw and washer, and the hole thing can be wiggled out the right hand side. If you are stuck please feel free to PM or email me for help. Paul. The Hell Team
Sure thing! I also picked up this little beauty the other day! By the way, they both have titles!
Hey guys thanks for your advice. I will split the case before my son takes off and see if I can't get him to bring the parts home with him in mid November. My summer starts soon and I want to be riding asap.
https://trialssuperstore.com/collections/engine/products/gasgas-shift-shaft-center-locator-and-spring This is the first part to check. that little thin piece of metal is designed to shear. The spring is included and zipped tied as it`s hard to install the spring. Its possible to weld this back together, just the spring is hard to deal with. Good luck, it`s probably one of these parts have failed. The top hat is the easiest to fix.
Shaft Shaft MT280238043 https://trialssuperstore.com/products/gasgas-pro-gear-selector-shaft But the shift drum may be damaged as well. Shift Drum MT280238031 https://trialssuperstore.com/products/gasgas-gear-selector-drum I would disassemble and inspect prior to buying any parts. Trials Superstore is only one example vendor. KTM dealers can also sell those parts.
gasaxe started following Gas gas TXT 250 shifting gear box problem
New member. I wish I had found this form years ago. I have a 2012 TXT 250 I ride near every day. Went to town for milk and bread and when I tried to gear down to 3rd it would not click in. I rode home in forth and drained the oil. It was clean. Topped up the gear oil and went for a short ride. 3rd 2nd 1st now work but no 4th or 5th. It's now parked. I'm in Central America. Parts are limited. My son is going to California in a week and thought maybe he can get what I need to fix my gym on wheels. This bike keeps this old man healthy and fit. Any advice much appreciated. I'm thinking this is the problem in the screenshot attached
you mean this is problem or not because i dont uderstand can u help me if u have same problem?
