Gas Gas Txt Pro Clutch
  • Replies 60
  • Views 23k
Most Popular Posts
  • Right, I am glad to report that my clutch is absolutely perfect!    Glenn.
  • Probably because Jim Snell did extensive testing and determined ATF to work better in the PRO motor.    I have never seen a trials service Manuel but if it is ANYTHING like the Enduro Manuel Id throw
  • biffsgasgas
    biffsgasgas
    I have used GM Autotrack, Dex/Merc3 and Type F ATF fluids in my gasgas. I change it every 3-4 rides and never had a problem. Once you go with a fluid stick with it. Don't try experimenting between one
Glenn.
You could of saved all that sanding just by burning that clutch in. Fourth gear against a tree and give her hell. Test, and give it another good burn. 5 minute job.
Do you mean slipping the clutch while reving or just only keep throttle? Because i've wasted much time with sand paper too..
I RESIST, I WILL USE AUTOTRAK II
(2 reasons, it is what the bike came with when I bought it and don't want issues with changing fluid.
and it's blue just like the plastics on my bike       :D )
Autotrak2 oils have pretty much been stated cause swelling of clutch materials.  this was back in 08 or sometime in history, just sayin, everyone else has moved away from it.
  • 3 weeks later...
I've just replaced the clutch pack on my 2014 Racing as the lever was very stiff. Got a Surflex clutch pack with 5 steel plates and picked 2 that got the pack to 9.8mm. Put it all back together with new Putoline Light Gear Oil (as recommended by Factory Kev at GasGasUK) and now its lovely and light.
However, it was slipping in 5th and 6th gear when I tried it today. What could cause that? There was possibly slightly too much oil in as it was about 2/3rds of the way up the sight glass rather than midway. Could that do it?
I've made sure there's lots of slack at the lever.
Any ideas before I pull it all apart again ?
2/3rds vs half way up the glass is probably about 20ml of oil. It would make zero difference.
Not sure about the slipping on a new clutch. I'd have to guess something went together incorrectly.
The plates are under more pressure when fitted than when measured with a vernier or other gauge. Brand new plates will also bed in a little, just taking high points of the fibres could easily make 0.1mm difference.Just been through this process myself and I measured the pack at 9.75mm. However although it didn't slip the clutch wasn't fast enough when trying to jump across stuff. When I took it back out its now less than 9.7mm after one trial.
Well I remeasured the finger height and it's spot on.
Normally I can be a little bit heavy handed when doing nuts and bolts up. I'm thinking I may have been a little too cautious when I replaced the plates and not tightened the retaining bolts up quite enough. Have re-tightened them all. Also checked the bearing, washer, replaced the clutch cover gasket and put it all back together. I'm hoping its now sorted but I don't have a trial until 22nd so I won't know until then.
Edited by smarty156
The newer pro`s required the thickest friction plate to be installed first. At the same time the newer bikes have the light spring.
All the Surflex friction plates are the same thickness. It's the metal plates that they give you different thicknesses of (1.3mm, 1.4mm, 1.5mm and 2 x 1.6mm).
