What Did You Do To Your Gas Gas Today?
  • Replies 599
  • Views 153.3k
Most Popular Posts
  • is it just me that walks in the garage and pumps the clutch lever a few times then walks back out?
  • Today on my 280,which i'm rebuilding,took the crankshaft to Grampian Motors in Liverpool along with the BE bearing,rod and pin kit . Bruce walks out,i gives him the rod kit, crank and a sheet of paper
  • orkney_will
    orkney_will
    I bought it My first bike. Txt Pro 2004 250cc. Bit of haggling and I got it for £850. No helmet yet as I'm waiting for it to be delivered still, but took it for a slow ride round my field just bec
No, think well about where it normally should be! ;) Putting it back in the frame or shock makes you need to take it back out again etc with putting it back together. So you put it in some other part...
Edited by crazybond700
 The damn exhaust hole. Shheez. :wall:
 I have a air lift bike stand. That I have had about thirty years. I have a certain placement for most parts. If it`s not there, I`m lost!
Edited by lineaway
Haha, yes! Took me (too) too long
Had my first competition with the bike again and it all runs smooothly. Still some things on the list to do's though. (something with time and lack of it)
Also yesterday added new sprockets chain and wheel bearings.
Still to do:
Weld and paint frame (and add guards)
Put on new tanksticker and airbox side stickers
Rehaul front suspension
  • 2 months later...
Well the Old BAGG (Bad Ass GasGas 2003 300 pro) had a slight rattle in the top end.  I was thinking wrist pin bearing.
This is her.  She ain't exactly pretty but sure is fun to ride............... ;)
So tear off Top end and discover I need Piston, Rings, Wrist pin and Wrist pin bearing
I discovered another problem when I drained the Gear oil................... a tooth stuck to the drain plug.  (magnets, how do they work?)
So pull Clutch cover off and investigate.  ALL the gears under clutch cover are in great shape, they have all their teeth.
I did find out I need a new Clutch Throw out bearing. 6 of the rollers are unaccounted for.  My fear is they went into the gearbox and broke a tooth off the gear.  I will find out when I split the cases.
When I realized that I did not have the correct flywheel puller, I gave my good friend Biffsgasgas a call and met him for a   :beer:.  We chatted trials, cars and railroad ties.  Then parted ways so that I could use the flywheel puller he had just loaned to me.  After splitting the cases I found the gear that is in need of dental services.  On initial inspection I cannot find any other damage inside the gear box.  I will look at the rest of it closer upon disassemble to get the broken gear off the shaft.  (that is not rust on crankshaft, just some icky oil residue)
Oh well, at least you'll know what to do on these cold winter days.  :P
Are you gonna do a complete rebuild now the cases are split?
New gear, put together, oil in it and ride!
Altough its not really much work to put new bearings in her now she is open. (still old setup on the 2003)
Sad thing is that it has not been that cold here.  Actually got up to 40F this past weekend, I wanted to go riding..  :(
I am not doing a total rebuild but the bearings on the countershaft (? sprocket goes on) sound/feel a little crunchy, and the bushing with the O-rings under is worn, so I plan to replace those parts as well.
Everything else looks good.  I think I got lucky that there is not more damage.
