What Does A Jotagas Really Weigh?
With all oils and fuel, do they really only weigh 64kg? Are they the lightest full sized trials bike you can buy?
  • Replies 35
  • Views 15.2k
Most Popular Posts
  • You were caught naked in the bathroom with your 4rt wernt you ? I'm just weighing it you said !
  • Strip naked, pick It up and step onto bathroom scales. Put it down and stand on scales second time. Subtract your weight and ta dah.. Kids, don't try this at home with your 4RT.
  • 67.5 kg at the start of a trial- 65kg at the end after all the bits have broken and fallen offf
Im more than happy to weigh mine fully filled with fluids. Ive only one set of bathroom scales.
I suppose i could put a plank on the scales the zero the scales off . Then roll the bike on. The trouble is the scales are analogue so not really accurate. Any better idea?
If you weigh each wheel separately and add the weights together you don't need to bother balancing a plank across the scales. For accuracy I like to put a piece of wood under the wheel not being weighed so as to keep the bike level.
I put my 240 on the trailer and went to the local truck scale ... Weighed bike on and bike off ... Scale is certified to be accurate .
And my trusty 240 pro came out at 168 lbs full of fuel .!!!!
Edited by axulsuv
That's less than my 4RT :o
Edited by ross brown
Pick It up and step onto bathroom scales. Put it down and stand on scales. Subtract your weight and ta dah..
Do bathroom scales go that high!!!!!?
{I put my 240 on the trailer and went to the local truck scale ... Weighed bike on and bike off ... Scale is certified to be accurate .
And my trusty 240 pro came out at 168 lbs full of fuel .!!!!}
Sorry Glenn, A CAT scale in that weight range is accurate to +,or minus 20 lbs.
I'll try to get the weight tonight or tomorrow latest. It's covered in Butser chalk mud at the moment getting ready for the first trial there in 23 years on the 1st December. 4 routes including expert and one 1988 World round section resurrection :)
I can tell you it is certainly lighter than a 2011 GasGas and a 2014 Sherco When I lift it onto the Bike Rack!
My 2012 GasGas TXT 280 Racing weighs 68,6 kg or 151,2 lbs (bathroom scales)
Edited by guys
I'll try the bathroom scale method then I guess ... :) A hernia may await !
