This stream auto-updates
  1. Past hour
  2. Hey, I finally opened the 301 engine and my friend the mechanic was right piston was worn quite badly. No big damage to te cylinder wall just needs a light hone and an new piston and rings. Will fit a new distribution kit too now the engine is in bits. Bike has been well serviced and i use good full sysntethic oil. Maybe previous owner didnt serviced it enough?
  3. Today
  4. If you ride in mud or slick conditions stick with Dunlop or Michelin. If never touching mud then ride a clapped out used one of the above. Using an ibex or Shinto is cool only if you need some rubber between the rim and you. Riding in Australia once was great but traction was every where. Riding in mid west us, Central Europe and north east us has me loving tire engineering from the pros. I use irc on only tubed rears because the bead wants to roam and not stay where it's told. --Biff
  5. I was given the opportunity to get the first set in AUS from Kenda Australia to test, I'm about 50 hrs in and have just rotated the tyre to give it a sharp edge. I didn't have high expectations of this tyre due to its price point BUT im extremely impressed with these tyres. The only downside is they do have a softer sidewall than the other 2 major brands. To combat this i would run them 1 PSI higher than usual. Performance is top notch! it grips just as well as a Michelin has good response and feedback. We tried a set of TL01 dunlops and found they where absolute rubbish. miles apart from the D803GP!! The only down fall is the front tyre does get a bit of understeer. Nothing a bit of body positioning can't fix. Would i use them again??? 110% YES!! the price these days for Michelins are going up and the Kenda fills the gap perfect for 99% of riders. www.tacticaltrias.com.au * Trialsolutions * M4 racing products * Rock oil
  6. Yesterday
  7. I think you can get a clear float bowl for that carb, makes it easier to diagnose 🤓
  8. Start it in neutral is the obvious one as Pro clutches have a tendency to drag no matter what type of oil or ATF you put in. If the bike has a KEIHIN PWK 28 then take the Jet metering block off and clean the tiny holes you see of any gunge then put a new jet block gasket in before putting it back on. Make sure the jetting is not too rich as it just soots the plug if you are not thrashing the motor regularly causing bad starting/running. In my experience the standard plugs are better than the NGK platinum in the 125 and they are better with a bigger gap like 0.7. Do not over oil the air filter and 80:1 in the tank is plenty of oil , you do not need more to be safe unless you are running it in a trial with lots of road work. Take the reed block off and put some new standard reeds in to make sure its all as it should be and be scrupulously clean while doing all the work and make sure gaskets seal properly.
  9. Last week
  10. Triad, if the primary drive crankshaft sprocket has a cush drive, then it is an easy job to change the crankshaft seal, but you need to buy a special puller for the cush drive. These pullers are available from vintage OSSA parts suppliers in the UK and USA. Buy a primary drive cover gasket and crank seal holder gasket while you are at it.
  11. Hello guys, sorry to resurrect an ancient thread... I have an Ossa engine requiring new crank seals as it's drinking gearbox oil. I'm kinda skeptical about doing the job myself as I never worked on such an old bike and I don't have the pullers. Is it hard? What kind of pullers do I need? The engine should be from a late 70s Pioneer, has the coarse teeth levers and runs, so the Motoplat rotor is good and has good compression. I'm in Italy, can't find a shop willing to tackle the job for me.
  12. There always seems to be a focus on fuelling and I recognise there's been some success with playing with it but I don't know what it is particularly but I like the idea of weak spark being a culprit. Especially in this case where the OP has gone to great lengths to prove it (apparently never solving it tho). I fully understand the fuelling has to be right, and 2 strokes are renowned for clogging jets etc so I get where the focus on fuelling is coming from. But the fact gassers are so well known for poor starting even on very new machines would point to something else at least not helping. Went to the Reg Bowker yesterday and watched in awe as the riders jumped on their bikes after refuelling and with just one kick we're off again! Even gassases! No magic dance or superstitious routine. So it is possible to achieve.
  13. Assuming there is not an electrical problem, making the starter jet richer can help. Does it have a Dellorto? If so, they have replaceable starter jets. When I did not want to wait for jets to arrive for my old TXT321, I just enlarged its original #60 starter jet hole from 0.023 inch to 0.028 inch (making it approximately a #70). Much easier to start! Figured I had nothing to lose, as I could just solder up the hole and re-drill to original size if it made things worse. The jet number is the approximate diameter in millimeters, so a #60 would be about 0.60 mm in diameter. When I drill a jet, I obliterate its original markings so the next guy is forced to measure. But I also always supply a full set of note with any bike I sell.
  14. In the 5 years since this post went cold, has there been any development on improving poor starting?
  15. Had my first "cold" ride today. (It's not actually cold, maybe 8°C) but i did get both hands drenched within the first 20 minutes. Anyway, heated grips are absolutely amazing. I went with this kit from splat shop https://www.splatshop.co.uk/heated-grip-kit.html I binned of the resistor and switch for high/off/low And just wired it into my headlight wiiring instead of high beam. So now i just use the pre-existing switch on the handlebar. I rarely ever ride at night so thats no issue, but it's just the swap of 2 spade connectors to return headlight to normal.
  16. Tr1AL
    SINCRO
    https://youtu.be/9TH3osNOdBY?si=QsjThBvRpJ9lP
  17. Ok another trial last weekend which was harder. I was pretty switched on for some of the first lap. Then got progressively worse. Think I'll try the kit but need to get past Christmas and cash flow issues. I could just take money from family account but I expect the wife to keep to a budget for play money account so I probably should. . .
  18. Thanks. Yes, I saw the spaltshop review but was just treating it with healthy skepticism given they're flogging them so it's good to hear your take. I think I've come to the conclusion the tyre might be good but possibly too new to the market (6 months ish?) to have any long-term feedback. I think we'll quite possibly give it a try in the new year
  19. had one when they first came out, slightly harder side wall than an x-light (I've split 2 of those so wont buy again), plenty of grip, and no downsides for me, I ride on rocks/streams, and lots of mud and very pleased with it. look up splat shop in the uk for a review.
  20. Gotgas, I would try the Kenda IBEX trials specific tires in a heartbeat. I’ve read several reviews stating people love the tires. Kenda also has an exceptional reputation in the tire industry. The only problem I have with them is they aren’t available locally for me. Go for it and don’t worry about it.
  21. Earlier
  22. Evening mate. No didn't get any reply so stuck with the standard plug but will try a 4 soon
  23. 32 spokes rear wheel, 750grs less than 36 spokes wheel. Dry weight : 71.5kg (- 6kg)
  24. It's a radial rear and it's stamped for 'trials competition use only' right on the sidewall, I'm guessing it's a trials tire worth a try. It's not like a rear tire lasts any longer than one season anyway. + If they are any good you can bet the price will increase.
  25. Yes faussy I agree .He could also try the MITAS PRO and the PIRELLI MT43 , I have not tried them but they look like Trials tyres. At club level I do not think tyres make much difference. That is also true of the bikes that people use , regular competitors know that a old Fantic 125 twinshock will beat a 300 Vertigo with the right rider on board. It makes one wonder why people bother at club level with all the expense. There is a review on instagram by an competent Australian rider and the Kenda IBEX gets a good review all round , the only exception being that the tyre folds when pushed hard.
  26. I did not know anything about the Ibex, but it's a great name for an off-road tire. A quick search revealed the Ibex endurocross tire. I would not ride that in a trial! How could faussy be so wrong? Turns out, there is a trials-specific Ibex, the K7104F and K7105. https://powersports.kendatire.com/en-eu/find-a-tire/motorcyclescooter/mxoff-road/ibex-trials/ Yup, that looks like a trials tire. But the durometer of the rubber would still be a big consideration for me. See: https://www.electricmotiontech.com/home/trials-tires
  27. Disagree. Not everyone is wanting to go win their local trial, and I guarantee if I put the Kenda on I would still beat 90% of the riders using michelins. FYI, I haven't even tried one yet, but I know just by looking at it, its a decent tire
  28. Michelin , Dunlop D803 GP , IRC Rear . Anything else is not a serious tire/tyre for the sport at this present time
  1. Load more activity
