This stream auto-updates
  1. Today
  2. Forma is stiffer than Gaerne and alpinestars
  3. I find that Forma has the same wide fit as Gaerne but are much stiffer. Once broken in Gaerne boots feel like bedroom slippers. The Forma soles are much more durable and do not get chewed up by the foot pegs either. They are slightly taller if that makes a difference. I tried on Alpinstars but the fit was way too narrow.
  4. Id say possibly the alpinstars followed by the sidi. Absolutely NOT gaerne!
  5. Hi all sufferer of plantar fascists, so I need a stiff sole on a trials boot , which brand has the stiffest sole in the arch area
  6. Yesterday
  7. It’s all down to technique and practice so keep at it, getting off and using right foot is ok but a bit of a faff esp when out riding, my factory 300 evo likes to demonstrate its compression for sure whilst my rev3 is a lot more user friendly.
  8. I would say there is a lot to do with technique rather than outright strength. If you are "at based" and have a bike stand with you, kick it on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height I would say there is a lot to do with technique rather than outright strength. If you are "at base" and have a bike stand with you, kick it whilst on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height gave enough purchase and the ability to use gravity + body weight as an assist. If its cold, don't be afraid to flick the choke on to get it first started. It should be easy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the technique down and its still not firing easily, check nothing is amis. I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down. gave enough purchase and the ability to use gravity + body weight. If its cold, dont be afraid to flick the choke on to get it first started. It should be asy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the techniqure down and its still not firing easily, check nothing is amis (I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down.
  9. Appreciate the feedback. I have the contact of a "local" trials suspension company. Given the local labour costs I am curious what kind of price pont we would be talking for such work.
  10. Dont have a beta but ive kick started a lot of maicos and they are on the left. My technique for them is to stand on the left, lean the bike towards you slightly and with opposite steering lock. You may find once you get the hang of how the bike starts you can kick it with your left.
  11. If it is like mine, it can be serviced but needs a valve installed so it can be refilled with nitrogen. You also have to measure or search to find the proper oil volume. I have changed the oil and valving but have not had to buy parts. Possibly here: https://www.ktechsuspensionusa.com/
  12. Hi all, Looking for a bit of info the shock and serviceability of it. I have an Evo Factory from 2017 (250). Its not had anything done to the shock in a while. How serviceable are these units? Maybe I am remembering wrongly but I seem to remember reading once upon a time that they are not very serviceable. I know a lot say its not worth upgrading the standard shock if you're not a top flight rider but what would you recommend - investing in a full service or replacing with something aftermarket? For reference, I am far from top flight - definite Sunday wobbler. Thanks all.
  13. Last week
  14. I’d second that opinion. I’m a small person, also 65, and it was extremely hard to start my Gasgas but after I reduced the compression with a 1mm head spacer the world was much rosier. Replacing the head insert or adding a head spacer will make it much easier to kick over. https://trialssuperstore.com/products/beta-evo-s3-low-compression-head-insert-300?srsltid=AfmBOorOsQLwFqYdzcC2hekw1AWgZSnGvXZNEch3bDhi56zw0dxAfsnV
  15. I kick mine left footed fine but it does have a bit of compression. I would recommend that you remove the high compression head which is fitted to the factory model and put on a low compression one like they fit to the standard model.
  16. Now, the bike is very nice. Crisp engine sound and light feeling. What a bike !
  17. Check all of the above suggestions first. Then: Has it had a big bore kit fitted? 143cc or 163cc? If the ticking is unusually loud then it could well be that the balancer weight (part 9 in the attached schematics) is hitting either the skirt of the new barrel, or, less likely is hitting the skirt of the new piston, when this balancer weight is near TOP dead centre and the piston is at BOTTOM dead centre. If you look closely at this weight it has a small flat spot on the left hand side of the weight. It is this which hits the barrel's skirt, unless the skirt has been shortened by 2 or 3 mm at that point. The same for the piston, when it is at bdc and the balancer weight is near tdc. Make sure that you reduce both sides of the piston by equal amounts. https://www.cmsnl.com/yamaha-ybr125ed-2006-3d94-england-1e3d9300e1_model43811/partslist/0003.html
  18. Just picked up a brand new Beta EVO 300 Factory with kick starter on left side of motor. This is a new one for me. Being 65 years old my kick starting oomf aint quite what it once was. Tried to start it today, no luck. I am looking for some tips. Is it better to stand over it and use right leg or stand off it and use right leg? Thank you
  19. I've not had to work on the steering bearings on my 348 yet, but 1970s Spanish bikes usually have a light interference fit between the stem and the yoke. I just went and looked at mine and it looks the same as yours, which looks like there is a head on the bottom end of the stem. For an interference fit stem, clean up the surface of the stem above the bearing seat. Set up some way to push the stem downwards through the yoke (press/vise/leverage). Heat up the yoke and the bearing. Yoke to just over 100 degrees C. The bearing can be made hotter but be careful to avoid overheating the aluminium. To maximise the effect of the heating to loosen the fit, minimise the heating of the stem. Push the stem down through the yoke and the bearing.
  20. Hi I could do with some advice please on how to remove the steering stem from the bottom yoke.348 mont. Thanks Martyn
  21. Ps You can take off the flywheel cover. Grab a hold of the flywheel to feel any movement. If you feel any up and down movement, you need new main bearings and seals.
  22. The jet tower gasket can leak and cause all kinds of poor behavior. That`s the piece inside the carb with torx security screws. The original gasket can shrink. The mating surfaces are not very plumb. Some people have good luck filing the surfaces flush. Sometimes just a new gasket fixes the issue. You can also search you tube for ways to test your carb.
  23. I believe they’re in the UK. Their website only states where the copyright originated. “registered at Companies House in England and Wales. Registered at CPM House, 10 Works Road, Letchworth Garden City, Hertfordshire, SG6 1LB, UK” it also states that the prices will include “VAT”…so, I’m guessing the UK again.
  24. Ron, Thank you for the information on this paint supplier. Are they in the UK or somewhere else? Also, a US Bultaco parts supplier, Hugh's Bultaco in New York state, thinks the correct paint color is what he calls "Hugger Orange." I believe I will order the smallest quantity of the Bootlace Yellow and see what it looks like sprayed out.
  25. Yes completely suitable for an adult to ride, the difference between the Majesty and Mini-Majesty is a slightly longer top tube with a slight rearward bend to the two downtubes in front of the cylinder. You might choose to lower the footrests as like most bikes from that time they are too high. Good luck they are a good bike.
  26. Thanks for the responses and the reassurance. I may well be the owner of one of these shortly.
  1. Load more activity
