This stream auto-updates
  1. Today
  2. French site www.trial-club.com Interview with Marc Teissier owner of SHERCO/SCORPA. Watch it on Youtube not the site , on you tube you should get a proper audible spoken translation in good english.
  3. Yesterday
  4. I dont even watch it any more. Participation is at all time low in my local clubs, so the manufacturers have got to be feeling it and I imagine WTC is their largest expense. IMO WTC needs a total redirection. I lost a lot of respect for Toni a few years hearing him talk about the direction he thinks trials should go, appealing to spectators and not to people entering the sport, so im not sure who is going to lead the charge. Maybe the manufacturers
  5. Trialworld in Spain is reporting trs vertigo ( gas gas already) EM quiting the championship will look for link
  6. Search for pictures. Hmm yeah it does seem high on my 23 and I usually hate that, several bike recently I've readjusted down. But never noticed on TRS. Odd. Your pegs are quite worn.
  7. Last week
  8. 16 years on from the last post! Just bought a mint Fantic 200 Trial, rear kick. 1982 (according to the date stamp on the tank). Sprockets are 11/52. Rode it in two Trials this week. It is a little bit quick in tight sections, so I have ordered a 10 tooth front sprocket to slow it down a bit.
  9. I have a set of purple mudguards. Just need a white 2k paint job and stickers. And a amazing new seat !
  10. Magpie joined the community
  11. Hi all, Anyone out there riding a 26 factory Sincro 250. Just wondering how they run in comparison to the superseded evo. My bike seems very rich and gassed up on the first part of throttle, cleans up nicely on quarter throttle all the way up but very fluffy down low. Leaned the pilot circuit right out on mixture screw but still not as clean as I’d like. Anyone else finding the same
  12. ahell replied to ahell's topic in Montesa
    New head, perfect condition.
  13. Seanrv125 joined the community
  14. Wanted Beta Rev 3 Long range kit
  15. Rjz11 posted a topic in Introduce Yourself
    Hi all, newbie here from South of England just starting to rebuild a honda tlm50 so may be asking for advice
  16. Rjz11 started following New member
  17. LewSur joined the community
  18. Rjz11 joined the community
  19. Tried one of the slab back protectors and don't like it, replaced it with a Troy Lee Designs back and chest vest which is way better 👍 Thinking about purchasing a second Troy Lee vest in a different model to wear over the first one so they cover any missing areas. Nothing is cheap to buy any more. ... model is a UPV something
  20. I think I might try 3D printing one. It will be a bit soft of course but I always warm my hub with a hot-air gun so it shouldn’t need much hitting.
  21. Hi guys I’m looking for chest/back body protection for trials. trying to get a jist of what my fellow riders are using and what they think of them Some look bulky and others look to bloody flimsy and they’re not cheap Tia!
  22. Thought I’d post here rather than the beta specific forum hoping for better exposure / someone who has knowledge on the subject. recently purchased a 26 250 Sincro factory. Noticed the bike seemed rich off the bottom particularly rolling off a bank etc first pick up on throttle motor really gassed up doesn’t clear easily. Best describe it like an SWM or bultaco from 80’s, actually sounds like that on the ear. Immediately thought of going to a 45 pilot jet to clean it up, worked well on my last evo but does make the transition onto the slide slightly weak so didn’t bother. Removed the fly wheel weight which helped and and fitted the extra fast throttle tube used on the TRSGOLD thinking I would almost bypass that problem part of the revs. It’s better but not perfect. Beta uk said a thinner base gasket helps and I’ve also been told a MP fabricated header helps low rpm response? Any Sincro owners experienced this or anyone know of someone that has fitted an aftermarket pipe etc or how they have overcome the problem? Any advice would be greatly appreciated. Thank you in advance.
  23. Ignition timing is usually slightly advance to TDC typically 10 to 20 degrees before and the black box is what alters the spark advance more if the engine even has that feature, it might not. I found a parts manual online for that bike no problem no luck with a service manual. Faulty bottom end seals destroy the engines intake vacuum more then anything else (symptoms would be poor compression test, hard starting and not a crisp pop pop pop sound on the engine). Your CDI trigger coil should show some resistance, more resistance than the primary ignition coils typically have. The clearance distance between the stator coils and the flywheel magnets should be as small as possible for the best spark intensity. One of those coils is likely for ignition and the other is for lights or horn. Only way I know of to test the black box 100% is to have a second working bike and swap parts to troubleshoot.
  24. Good Day , I have a 350cc Merlin Cagiva which has pretty much overnight developed an engine issue. It will now not fully rev. The engine sounds muffled when revved, like if the exhaust silencer was blocked ( which it is not). I have checked the carb, cleaned the jets, tried different jets and even tried a new carb. This did not solve the issue. I checked the coil and tried a new coil. This did not solve the problem. I checked the stator and tried various advance and retard positions. This did not solve the issue. For my sanity, can anyone explain to me how the CDI works? The engine when was running fine, the stator was pretty much on TDC. Does the CDI then deal with the timing of the spark when the engine revs are increased. Not having an useful specs for the engine, I assume that TDC is correct. Whilst taking the flywheel on and off, I did detect some movement in the main shaft. I doubt if the main bearings have ever been changed! If the bearings are faulty and subsequently the main seals may be faulty, could this possible be the source of the problem ( taking in air or pushing out fuel ). The engine is not smoking excessively, but maybe that is due to bearing/seal failure only being on the flywheel side. I have approached Rex's Speedshop for advice, but before I part with a small fortune on a new ignition system, I thought I would ask you knowledgeable guys for advice. Kind Regards Bruce
  25. Google claims 500cc
