- Today
Here's the OSSA cush drive puller photo
Yes, quite impossible. "Fingers" on a puller made to fit in there are not strong enough for the job by a large margin. The puller needs to pull on the whole surface. The Montesa primary drive crankshaft gear of the same era as the OSSA cush drive is also on a taper and is also impossible to get off with a universal puller so it is not just OSSA who did this back in the day. I'll post a photo up later when my cloud storage is talking to me
Ok guys, can we just stop & have a reality check here ? Is this another answer to a problem that never was ? This modern world is full of ‘em and somehow the world and his dog get drawn in. Electric starters on bikes are an unnecessary luxury item in most cases IMHO, perhaps acceptable on a large road bike, but small capacity machines of any type just don’t need them. FFS if you’re riding trials then you’re likely to have got legs and are reasonably fit. And the next thing they sell you are titanium bits to save weight !!! Wake up people, just buy a bike with a kickstart, I can guarantee that a few minutes rest will recharge your leg, without needing to carry a backpack with anything at all in it. If your bikes got a fault & doesn’t start then pushing it back to van/paddock will be easier without an extra 2kg of starter and a another 5kg backpack. Sorry but my getting old, ‘Victor Meldrew’,(That’s a uk comedy reference, look it up) good old times syndrome just overcame me 😂
You sure you want to hone a plated barrel 🤔 don't think you are suppose to do that.
I guess they do, but they probably already have the puller? Is it absolutely impossible to get the cush drive out with a standard 3 arms puller?
I'm not exactly sure when it was (mid 1980s maybe) that street bikes began to lose the kicker. Old-timers lamented the loss. Nowadays, no street bike has a kick-starter — and for logical reasons. Bump starting became a possible (and sometimes necessary) workaround. But it's very difficult to bump-start a trials bike — although I have done it. Personally, I would keep a spare battery or lithium-ion jump-starting pack with the tow vehicle.
If you plan to ride in cold climates the first thing you will want to add is a jump start port so you can carry some extra battery power, e-start on my TRS bikes is very seasonal. If it has a sprag bearing in the starter you might even want to pack a spare motorcycle.
DavidinDK joined the community
Oil won't hurt the throttle body. The fuel injector is after the throttle body and that is where fuel residue would start to be apparent, if anywhere. Race fuel is a very aggressive solvent if you have been running poor quality fuels and will be going through the injectors. Crankcase ventilation is critical to preventing oil going places it should not, like past the intake valve seals for example. Spray solvent can dissolve the blue silicon insulation inside the main electrical connector, use only air if it gets water condensation in it. If any flame gets past the 4-stroke valves the filter could ignite unlike the 2-stroke 315 model, hence the addition of a flame screen is required. .
200 Euros labour plus parts sounds quite reasonable to me and even cheap if they have to source or make a special puller. Do they know what's involved?
Didn't really find it with my google search... I'm in Italy, BTW. I tried to find a mechanic willing to do it... some say they won't open the engine unless it's for a total check of all the parts. Another guy asked for €200, not sure how long it takes but seems a bit on the steep side, maybe? I should also take the engine out and pack it to ship it to his shop (and of course have it picked up after the job).
RonH started following Keihin PWK 28mm Carburetor (left side adjust) $249
Time Left: 26 days and 11 hours
- FOR SALE
- NEW
Keihin PWK 28mm left side carburetor (genuine, not an Amazon Chinese copy) $249Nearly new with only 12.5 hours use.Just cleaned and inspected, good o-rings, clear jetting, no stripped screws, ready to install.Includes new S3 idle and air adjusters ($30). Make it easy to adjust while sitting on the bike. Original adjusters included.Also comes with 17mm float bowl wrench.Came stock on my new Gasgas trials bike. I never had a problem with it. I simply upgraded.Cash only or Venmo!NO VALUE SPECIFIED
Just an update on this. I’ve had my 4rt bought new for about a year. The inside of the throttle body does in fact need cleaning. I’ve found the inside of the body, around the butterfly value had a light coating of oil. This is either air filter oil residue sucked from the filter, blowback from the engine (I guess that’s why the air filter has a fire proof mesh) or both. I easily cleaned this out with carb cleaner. As a note DON’T DO THIS! The solvent in carb cleaner affects the throttle body air pressure/temp sensor. It was a bitch to start at my next trial until I flushed enough air through the throttle body. Use specialist throttle body cleaner, which is designed not to effect the sensor.
I had an identical issue with my brand new 301RR. On laps 3&4 of a trial, where I wasn’t stopping to look at sections, the gear change was terrible and at times the bike felt locked into one gear. I couldn’t find neutral with the engine running while waiting at sections and if I stopped the engine, I couldn’t start it again when it was hot. I adjusted the tappets which cured the hot start issue (these really do need doing after the bikes first run in and every 6 months after). I did the washer adjustment on the rear of the clutch basket which massively improved the gear change, especially when the engine was hot. The washer needs adjusting every few months and I’m yet the find a way of stopping the free play (it’s only about 2mm) but it massively affects the gear change.
some pictures of the damage
Any pictures of rhat Jon Bliss mod?
Hello my name is Lee and I live on the Big Island Hawaii. I just purchased my first Bultaco model 92 Sherpa T 350. I bought it as a basket case for 500 bucks with some new parts . Seat, grips, tires, tubes, and exhaust and a powder coated frame . The guy I purchased it from brought it over from Oahu. He purchased it from a guy who worked at the Pearl Harbor naval station ship yard. I got to meet the original owner when I was stationed at Pearl Harbor as a dock master. I used to own a Bultaco Metrala 250 El Tigre and a Matador mk4 250 5 speed when I was a teenager. This should be a really fun project.
LeeRN joined the community
Yes it's not easy but are you saying you can't find where to buy the special puller from?
Uhm... gotta say the videos of guys pulling the cush drive with a handmade puller didn't really make me think it was easy. I tried to get in touch with a few mechanics here, specialized in old enduro bikes, but for now still no luck. Not really too excited at the idea of doing it myself, this bike is definitely way different from what I usually wrench on...
Perhaps it has something to do with it being your first post here? Perhaps it has something to do with Kenda being sold on the website (albeit with a spelling error) you promoted above?
Hey, I finally opened the 301 engine and my friend the mechanic was right piston was worn quite badly. No big damage to te cylinder wall just needs a light hone and an new piston and rings. Will fit a new distribution kit too now the engine is in bits. Bike has been well serviced and i use good full sysntethic oil. Maybe previous owner didnt serviced it enough?
Seems legit 🤣
If you ride in mud or slick conditions stick with Dunlop or Michelin. If never touching mud then ride a clapped out used one of the above. Using an ibex or Shinto is cool only if you need some rubber between the rim and you. Riding in Australia once was great but traction was every where. Riding in mid west us, Central Europe and north east us has me loving tire engineering from the pros. I use irc on only tubed rears because the bead wants to roam and not stay where it's told. --Biff
TacticalTrials joined the community
I think you can get a clear float bowl for that carb, makes it easier to diagnose 🤓
