This stream auto-updates
  1. Today
  2. Manual specifies SAE 80, or any modern light gear oil will work. 1 litre, but 900cc for an oil change as not all of the oil drains out 50:1 is ok with modern synthetic or semi-synthetic such as Castrol Power 1
  3. tlr-evolution.co.uk email: gary@tlr-evolution.co.uk. Trial Tube have a video titled Trial Tube Best TLR's you have ever seen ! - Classic Bike Reveiw . That is if you have not seen it already of course. TY Off-Road built one of those TLR's with an alloy swing arm and it has a TLR 250 brake drum . TY Off-Road is now TLR- Evolution same people who built the bike I just mentioned .
  4. I have flat feet and find the AplintStars Tech T to work well for me. I haven't had a set of Forma's so can't say they are better or worse but I will say if you like toe room go a size up on the Tech T's. Good luck.
  5. ok thank you , do you also know what gearbox oil they take and what premix ratio i was told 50/1 .thanks
  6. Yesterday
  7. Are you trying to start it with the Carby choke on? Will it start once it has been started and warmed up? I would also check the plug lead is screwed in properly, if that was changed with the electronic ignition.
  8. Does the plug get wet? If not, as it has been left for 20 years, a blocked pilot circuit in the carb is a possibility, if a pilot jet or aiway is blocked it can be vitually impossible to start a bike. Put fuel down the plug hole or spray easy start into the carb, if the bike runs but quickly dies, chances are it's a blocked pilot circuit, try having the carb ultrasonic cleaned You mentioned the ignition timing, check that the woodruff key hasn't sheared when you've been kicking it and the flywheel moved out of position
  9. The only similarity is the bore size, the porting is completely different in either cylinder
  10. hi will a ossa gripper 350 cylinder liner work in a ossa mar 350 cylinder .
  11. No just changed stator plate and fitted kill switch cdi etc that comes with it..
  12. Check that displaced wadding hasn't blocked the exhaust
  13. Hi all! I just joined recently to see if anyone might have a potential solution to my problems with my Montesa Cota 172… hopefully I’m in the right place. The bike has been in my family since new, my older brother was the last to use it 20 odd years ago. I got it with the intent to get her running, here’s a list of what I’ve tried to do to get it going; 1.Replaced crank seals 2.Checked spark (bright blue and consistent with a brand new spark plug, verified coil is working correctly) 2.Verified timing (hasn’t changed since new) 3.Rebuilt the Amal 620 carburetor (tickler works as intended now) 4.Cylinder leakdown test passed I’ve tried various fuel mixes ranging from 32:1 to 50:1 like my Yamaha Ty250, but no luck. ALL of this and she will only sometimes give me a bang once and a while! I’m completely at a loss, I’ve used up all of my mechanical knowledge here. Any advice would be appreciated, thanks!
  14. Last week
  15. It should start easily at 2-3mm BTDC. Did you do anything else at the same time as fitting the new ignition?
  16. Fitted a electronic ignition as instructuons say. Now ty will only start by putting a drip of petrol down bore. Good spark, new petrol, clean carb, reeds look ok. Timing is 2-3mm measured with strobe. Once running rev/ rides fine. Kicks back up ok. Only tried it for 10mins running Any ideas before i put old ignition on to prove a point, or is 200 majesty timed diffent to a ty175 Thanks
  17. got it started this week thnx
  18. Suggest you contact the dealer and ask him why he didn’t recommend the 250 Super smooth model?
  19. You need the old out of production ALPINE STARS NO STOP BOOTS I would recommend going for 1 or 2 sizes bigger for toe comfort if you find some on ebay ...... they come on fairly regularly normally almost new in condition in the UK . The soles are not very flexible compared to other boots.
  20. Thanks everyone , looks like I can do better than the forma boots I already have
  21. Hi I am looking for the measurement of the width of a TLR250 rear hub including brake plate and spacers, for getting an alloy rear swinging arm made. So I am looking for the distance between the inside of the swinging arm for a tlr250 twin shock. I already have a tlr250 rear wheel with braking plate but I am not sure whether my spacer is the right length. Thanks in advance.
  22. I suspect it is a steel shank sole you are looking for and I think that is something found in enduro and MX boots but not so much in trials specific boots.
  23. Forma is stiffer than Gaerne and alpinestars
  24. I find that Forma has the same wide fit as Gaerne but are much stiffer. Once broken in Gaerne boots feel like bedroom slippers. The Forma soles are much more durable and do not get chewed up by the foot pegs either. They are slightly taller if that makes a difference. I tried on Alpinstars but the fit was way too narrow.
  25. Id say possibly the alpinstars followed by the sidi. Absolutely NOT gaerne!
  26. Hi all sufferer of plantar fascists, so I need a stiff sole on a trials boot , which brand has the stiffest sole in the arch area
  27. Earlier
  28. It’s all down to technique and practice so keep at it, getting off and using right foot is ok but a bit of a faff esp when out riding, my factory 300 evo likes to demonstrate its compression for sure whilst my rev3 is a lot more user friendly.
  1. Load more activity
