This stream auto-updates
  1. Past hour
  2. Yesterday
  3. It should start easily at 2-3mm BTDC. Did you do anything else at the same time as fitting the new ignition?
  4. Fitted a electronic ignition as instructuons say. Now ty will only start by putting a drip of petrol down bore. Good spark, new petrol, clean carb, reeds look ok. Timing is 2-3mm measured with strobe. Once running rev/ rides fine. Kicks back up ok. Only tried it for 10mins running Any ideas before i put old ignition on to prove a point, or is 200 majesty timed diffent to a ty175 Thanks
  5. Last week
  6. got it started this week thnx
  7. Suggest you contact the dealer and ask him why he didn’t recommend the 250 Super smooth model?
  8. You need the old out of production ALPINE STARS NO STOP BOOTS I would recommend going for 1 or 2 sizes bigger for toe comfort if you find some on ebay ...... they come on fairly regularly normally almost new in condition in the UK . The soles are not very flexible compared to other boots.
  9. Thanks everyone , looks like I can do better than the forma boots I already have
  10. Hi I am looking for the measurement of the width of a TLR250 rear hub including brake plate and spacers, for getting an alloy rear swinging arm made. So I am looking for the distance between the inside of the swinging arm for a tlr250 twin shock. I already have a tlr250 rear wheel with braking plate but I am not sure whether my spacer is the right length. Thanks in advance.
  11. I suspect it is a steel shank sole you are looking for and I think that is something found in enduro and MX boots but not so much in trials specific boots.
  12. Forma is stiffer than Gaerne and alpinestars
  13. I find that Forma has the same wide fit as Gaerne but are much stiffer. Once broken in Gaerne boots feel like bedroom slippers. The Forma soles are much more durable and do not get chewed up by the foot pegs either. They are slightly taller if that makes a difference. I tried on Alpinstars but the fit was way too narrow.
  14. Id say possibly the alpinstars followed by the sidi. Absolutely NOT gaerne!
  15. Hi all sufferer of plantar fascists, so I need a stiff sole on a trials boot , which brand has the stiffest sole in the arch area
  16. It’s all down to technique and practice so keep at it, getting off and using right foot is ok but a bit of a faff esp when out riding, my factory 300 evo likes to demonstrate its compression for sure whilst my rev3 is a lot more user friendly.
  17. I would say there is a lot to do with technique rather than outright strength. If you are "at based" and have a bike stand with you, kick it on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height I would say there is a lot to do with technique rather than outright strength. If you are "at base" and have a bike stand with you, kick it whilst on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height gave enough purchase and the ability to use gravity + body weight as an assist. If its cold, don't be afraid to flick the choke on to get it first started. It should be easy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the technique down and its still not firing easily, check nothing is amis. I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down. gave enough purchase and the ability to use gravity + body weight. If its cold, dont be afraid to flick the choke on to get it first started. It should be asy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the techniqure down and its still not firing easily, check nothing is amis (I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down.
  18. Appreciate the feedback. I have the contact of a "local" trials suspension company. Given the local labour costs I am curious what kind of price pont we would be talking for such work.
  19. Dont have a beta but ive kick started a lot of maicos and they are on the left. My technique for them is to stand on the left, lean the bike towards you slightly and with opposite steering lock. You may find once you get the hang of how the bike starts you can kick it with your left.
  20. If it is like mine, it can be serviced but needs a valve installed so it can be refilled with nitrogen. You also have to measure or search to find the proper oil volume. I have changed the oil and valving but have not had to buy parts. Possibly here: https://www.ktechsuspensionusa.com/
  21. Hi all, Looking for a bit of info the shock and serviceability of it. I have an Evo Factory from 2017 (250). Its not had anything done to the shock in a while. How serviceable are these units? Maybe I am remembering wrongly but I seem to remember reading once upon a time that they are not very serviceable. I know a lot say its not worth upgrading the standard shock if you're not a top flight rider but what would you recommend - investing in a full service or replacing with something aftermarket? For reference, I am far from top flight - definite Sunday wobbler. Thanks all.
  22. I’d second that opinion. I’m a small person, also 65, and it was extremely hard to start my Gasgas but after I reduced the compression with a 1mm head spacer the world was much rosier. Replacing the head insert or adding a head spacer will make it much easier to kick over. https://trialssuperstore.com/products/beta-evo-s3-low-compression-head-insert-300?srsltid=AfmBOorOsQLwFqYdzcC2hekw1AWgZSnGvXZNEch3bDhi56zw0dxAfsnV
  23. I kick mine left footed fine but it does have a bit of compression. I would recommend that you remove the high compression head which is fitted to the factory model and put on a low compression one like they fit to the standard model.
  24. Now, the bike is very nice. Crisp engine sound and light feeling. What a bike !
  25. Earlier
  26. Check all of the above suggestions first. Then: Has it had a big bore kit fitted? 143cc or 163cc? If the ticking is unusually loud then it could well be that the balancer weight (part 9 in the attached schematics) is hitting either the skirt of the new barrel, or, less likely is hitting the skirt of the new piston, when this balancer weight is near TOP dead centre and the piston is at BOTTOM dead centre. If you look closely at this weight it has a small flat spot on the left hand side of the weight. It is this which hits the barrel's skirt, unless the skirt has been shortened by 2 or 3 mm at that point. The same for the piston, when it is at bdc and the balancer weight is near tdc. Make sure that you reduce both sides of the piston by equal amounts. https://www.cmsnl.com/yamaha-ybr125ed-2006-3d94-england-1e3d9300e1_model43811/partslist/0003.html
  27. Just picked up a brand new Beta EVO 300 Factory with kick starter on left side of motor. This is a new one for me. Being 65 years old my kick starting oomf aint quite what it once was. Tried to start it today, no luck. I am looking for some tips. Is it better to stand over it and use right leg or stand off it and use right leg? Thank you
  28. I've not had to work on the steering bearings on my 348 yet, but 1970s Spanish bikes usually have a light interference fit between the stem and the yoke. I just went and looked at mine and it looks the same as yours, which looks like there is a head on the bottom end of the stem. For an interference fit stem, clean up the surface of the stem above the bearing seat. Set up some way to push the stem downwards through the yoke (press/vise/leverage). Heat up the yoke and the bearing. Yoke to just over 100 degrees C. The bearing can be made hotter but be careful to avoid overheating the aluminium. To maximise the effect of the heating to loosen the fit, minimise the heating of the stem. Push the stem down through the yoke and the bearing.
  1. Load more activity
