- Today
frankie422 started following ossa mar 350 help
hi will a ossa gripper 350 cylinder liner work in a ossa mar 350 cylinder .
simon0116 started following Yam ty200 majesty - electronic ignition
No just changed stator plate and fitted kill switch cdi etc that comes with it..
Check that displaced wadding hasn't blocked the exhaust
Plymouth started following ‘74 Montesa won’t run!
Hi all! I just joined recently to see if anyone might have a potential solution to my problems with my Montesa Cota 172… hopefully I’m in the right place. The bike has been in my family since new, my older brother was the last to use it 20 odd years ago. I got it with the intent to get her running, here’s a list of what I’ve tried to do to get it going; 1.Replaced crank seals 2.Checked spark (bright blue and consistent with a brand new spark plug, verified coil is working correctly) 2.Verified timing (hasn’t changed since new) 3.Rebuilt the Amal 620 carburetor (tickler works as intended now) 4.Cylinder leakdown test passed I’ve tried various fuel mixes ranging from 32:1 to 50:1 like my Yamaha Ty250, but no luck. ALL of this and she will only sometimes give me a bang once and a while! I’m completely at a loss, I’ve used up all of my mechanical knowledge here. Any advice would be appreciated, thanks!
Plymouth joined the community
It should start easily at 2-3mm BTDC. Did you do anything else at the same time as fitting the new ignition?
Fitted a electronic ignition as instructuons say. Now ty will only start by putting a drip of petrol down bore. Good spark, new petrol, clean carb, reeds look ok. Timing is 2-3mm measured with strobe. Once running rev/ rides fine. Kicks back up ok. Only tried it for 10mins running Any ideas before i put old ignition on to prove a point, or is 200 majesty timed diffent to a ty175 Thanks
dirtbikeFinder joined the community
Ritz007 joined the community
You need the old out of production ALPINE STARS NO STOP BOOTS I would recommend going for 1 or 2 sizes bigger for toe comfort if you find some on ebay ...... they come on fairly regularly normally almost new in condition in the UK . The soles are not very flexible compared to other boots.
JKN308 joined the community
Thanks everyone , looks like I can do better than the forma boots I already have
Dewi joined the community
ChrisTlM50 joined the community
Hi I am looking for the measurement of the width of a TLR250 rear hub including brake plate and spacers, for getting an alloy rear swinging arm made. So I am looking for the distance between the inside of the swinging arm for a tlr250 twin shock. I already have a tlr250 rear wheel with braking plate but I am not sure whether my spacer is the right length. Thanks in advance.
I suspect it is a steel shank sole you are looking for and I think that is something found in enduro and MX boots but not so much in trials specific boots.
Forma is stiffer than Gaerne and alpinestars
mcman56 started following trials boots that are stiff
I find that Forma has the same wide fit as Gaerne but are much stiffer. Once broken in Gaerne boots feel like bedroom slippers. The Forma soles are much more durable and do not get chewed up by the foot pegs either. They are slightly taller if that makes a difference. I tried on Alpinstars but the fit was way too narrow.
Id say possibly the alpinstars followed by the sidi. Absolutely NOT gaerne!
betaflaxton started following trials boots that are stiff
Hi all sufferer of plantar fascists, so I need a stiff sole on a trials boot , which brand has the stiffest sole in the arch area
I would say there is a lot to do with technique rather than outright strength. If you are "at based" and have a bike stand with you, kick it on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height I would say there is a lot to do with technique rather than outright strength. If you are "at base" and have a bike stand with you, kick it whilst on the stand, both feet on the pegs to get good purchase to kick it. If no stand, but there is a wall, go with that. Someone I ride with also had issues before moving to a TRRS with e-start. Right side rather than left but the principle is the same, he would stand on anything with his none kicking foot - such as a rock. Again, additional height gave enough purchase and the ability to use gravity + body weight as an assist. If its cold, don't be afraid to flick the choke on to get it first started. It should be easy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the technique down and its still not firing easily, check nothing is amis. I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down. gave enough purchase and the ability to use gravity + body weight. If its cold, dont be afraid to flick the choke on to get it first started. It should be asy to start, my almost 10 year old Evo will still start first kick when warm, maybe two from cold. So if you have the techniqure down and its still not firing easily, check nothing is amis (I appreciate you're not saying its a pig to start, just adding for reference as they are not hard to start when you have the how down.
Appreciate the feedback. I have the contact of a "local" trials suspension company. Given the local labour costs I am curious what kind of price pont we would be talking for such work.
Tips needed for new Beta 300 with left side kick starter
faussy replied to Starting's topic in Trials Training And Technique
Dont have a beta but ive kick started a lot of maicos and they are on the left. My technique for them is to stand on the left, lean the bike towards you slightly and with opposite steering lock. You may find once you get the hang of how the bike starts you can kick it with your left. -
mcman56 started following Evo Shock Service - Beta Evo Factory 250 2017
If it is like mine, it can be serviced but needs a valve installed so it can be refilled with nitrogen. You also have to measure or search to find the proper oil volume. I have changed the oil and valving but have not had to buy parts. Possibly here: https://www.ktechsuspensionusa.com/
user7743 started following Evo Shock Service - Beta Evo Factory 250 2017
Hi all, Looking for a bit of info the shock and serviceability of it. I have an Evo Factory from 2017 (250). Its not had anything done to the shock in a while. How serviceable are these units? Maybe I am remembering wrongly but I seem to remember reading once upon a time that they are not very serviceable. I know a lot say its not worth upgrading the standard shock if you're not a top flight rider but what would you recommend - investing in a full service or replacing with something aftermarket? For reference, I am far from top flight - definite Sunday wobbler. Thanks all.
RonH replied to Starting's topic in Trials Training And Technique
I’d second that opinion. I’m a small person, also 65, and it was extremely hard to start my Gasgas but after I reduced the compression with a 1mm head spacer the world was much rosier. Replacing the head insert or adding a head spacer will make it much easier to kick over. https://trialssuperstore.com/products/beta-evo-s3-low-compression-head-insert-300?srsltid=AfmBOorOsQLwFqYdzcC2hekw1AWgZSnGvXZNEch3bDhi56zw0dxAfsnV -
kurtas replied to Starting's topic in Trials Training And Technique
I kick mine left footed fine but it does have a bit of compression. I would recommend that you remove the high compression head which is fitted to the factory model and put on a low compression one like they fit to the standard model. -
wyn joined the community
- Earlier
Now, the bike is very nice. Crisp engine sound and light feeling. What a bike !
