This stream auto-updates
  1. Past hour
  2. Hi Chris, thanks for your reply. As you say, MSM wanted £400 and I couldn't get anyone over the phone to insure the bike because despite having the V5 and the bike taxed, their computers didn't recognize the registration number. I had an inspiration and went to the Money Saving Expert comparison site that eventually allowed me to enter the reg number manually by listing the Sincro as a 2026 Evo. I then went back to Hastings, the current insurer of my TRS 250 and added my new bike to my existing policy for £72 extra to the end of my policy in October 2026.. I'll worry about what happens next when the time comes... Bizarrely, they said that if I sell the TRS and remove it from the policy, the premium will likely increase! Cheers, Trevor
  3. Today
  4. We had the same issue with the missus' '25 EM Factor-e (now on SORN). Eventually I spoke to a human being (insurance companies don't use them any more) and we were told that the insurers do not want to insure anything for theft without an ignition key. In the end we were offered TPF&F by MSM - they are your best bet - probably your only bet to be fair. The Factor-e was not listed by anyone even the self proclaimed "specialist" idiots that advertise they specialise in electric bikes. MSM offered us cover but it was not cheap. Both me and the missus have road bike insurance and neither broker (Bikesure missus, Carole Nash me) would touch the EM. (My policy is multi bike) My last Beta went on my old multi bike policy for just a quid extra. They would not renew it however - that was about three/four years ago IIRC. MSM was well over 400 just for the EM and my GSX650F and CRF250L are just over 200 quid the pair. I wish you good luck and hope you find someone that will cover the bike. Please post up if you do I think there are a lot of us out there. Must be a problem for the enduro bikes as well.
  5. Pretty sure that after the first 2 year Bultaco models the muffler wasn't serviceable until after the rear tankers
  6. Yesterday
  7. I believe it is like the Beta enduro clutch.... There are three positions for #17 to adjust preload on the spring.
  8. new piston and rings in the mont and it runs a lot nicer now no more rattle and it feels more powerfull.
  9. Bials
    1975 Tl250
    I realize this is an old thread, but did anyone find a solution to this problem?
  10. Last week
  11. My Climbers rear shock stop bumper has disintegrated. Where can I find another one? The shock shaft is 14mm. Thanks
  12. How long have you been running them for?
  13. It looks like the belleville spring support "ring" (#15) sould be offered in different thicknesses, similar to what TRS does. They only list one so far.
  14. For what it's worth I'm running them on a 1997 Beta Techno and they work well. Harder to put on than the X11 but otherwise they are very good for the money. If you are serious get an Xlite or X11 but if you want to save a few hundred the Ibex is worth a shot.
  15. Should be close! So, just as a reminder: 1973 Ossa Explorer with late 70s Pioneer engine, Koso PWK30 carb, PVL coil. Still needs a decent silencer as that chinese crap touches the rear tyre. Just fitted the tank, air filter, tank+petcock, fuel hoses, clutch cable.
  16. Hello, Has anyone installed a Tech TS4 rear suspension on their bike? I'd like to install one, but it seems there's not enough space between the swingarm and the shock. The original is 58mm, the tech is 78mm. I ride a Beta Evo 300 4T - 2020 model. I can also test/buy a TRP. If this is a better option, please let me know. greathings, Luc
  17. Well my friend grabbed my tl125What he gave me back is mind blowingBefore Then work was done Here is the artist himself Mike Allen my friend and mentor The finished product Here she is in the house, a bike like this you don't leave in the garage
  18. Not exactly the solution I was hoping for. But yeah, I guess they are not too serviceable.
  19. See de video from a Japanese on you tube whit de new Beta...!!!
  20. Hi, Delighted with my new 250 Sincro but the factory website says there are three variables for the clutch spring tension but no info on how to change them. Has anybody tried it out yet before I take the clutch cover off? Thanks in advance!
  21. Hi All, I just purchased a Beta Sincro but because it is a new model, insurance companies haven't listed it yet. The bike is road registered and DVLA were happy to take my road tax payment immediately even though I can't use it on the road. Any thoughts please? Naturally I am particularly anxious to have the bike insured against theft if nothing else.
  22. On mine I cut a window, repacked and closed it back up with an aluminum sheet metal cover with a rubber gasket and rivets.
  23. Thank you very much! Got my two TLs today and I'm enjoying them a lot. I will check out the places you listed.
  24. I did do some parts chasing Some TL parts are shared with the XLs. I was able to get intake valves here. https://www.xlintperformance.com/ IMD was selling piston kits on ebay. They were very nicely made. The machinist who bored the cylinder thought they had the original Honda molds. Gaskets came from ebay. A China copy petcock from ebay worked after installing Honda OEM seals. A China copy 22mm carb worked well after increasing the slide cut away. It was well made and accepted OEM Keihin jets but needed the bowl seal replaced. It seems like China o-rings do not like US gas or maybe just California gas. I think All Balls sold a steering bearing kit and fork seals. These guys had the transmission output shaft that the seal runs on. https://www.davidsilverspares.com/ These guys have some general Honda stuff. https://4into1.com/?srsltid=AfmBOoqk_OxNHRz3n01ZkipB_bpjTyDPO1CO1xnau5oSRcIMlS0ChZAQ The main bearings are or were no longer available. They use some kind of custom bearing with a larger OD than anything available. Be sure they need to be replaced before pulling them off. I didn't. All Balls listed a kit but they were just a standard bearing. There are solutions but none are easy or cheap. I replaced the ignition advance mechanism with used parts from ebay. IIRC, they were from an XL125 but looked the same. As mentioned, CMSL has some things too. I could not find an intake manifold so ended up having to machine one.
  25. Yes, Chris said he might start a new class this year. Otherwise the early liquid cooled bikes are legal in the modern vintage class.
  26. I have a 2012 ST290. I looked in the service manual, and there is a reference for removing and re-packing the silencer packing fibers on the newer models However, on the 2012 model, I am not sure this can be done. It is of a different design than what is shown in the manual. On my bike, there IS a philips screw in the correct location that would indicate it is possible, but when I remove that screw, nothing comes apart. Does anyone know if the silencer tube can be removed for cleaning or repacking on the 2012 model?
  27. Bials, here are a few places that sell TL parts. Hopefully you can find what you need on them. https://www.megazip.net/zapchasti-dlya-motocyklov/honda/tl250-14857/tl250-28759/tl250-a-787928?network=x&adposition=&keyword=&gad_source=1&gad_campaignid=22419889174&gbraid=0AAAAADdym2axmanakEDnZRMjcQ5KOwMbQ&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYAyAAEgI1rfD_BwE https://www.cmsnl.com/honda-tl250_model302/?bg_source=ga&bg_campaign=16511123247&bg_kw=dsa-1465129992666-mi--pi--ppi-&bg_source_id=586686834193&gad_source=1&gad_campaignid=16511123247&gbraid=0AAAAABvnBcJu1N-OSlIKn7IozHy-M-FqW&gclid=EAIaIQobChMItNiJ08SYkgMVZg6tBh35kzofEAAYASAAEgLI0fD_BwE https://www.speedandsport.com/model/tl250/ https://www.vintco.com/shop/Honda/TL250
  28. Thanks Feetupfun, I am definitely going to look to see where the closest vintage trials events are. I might give it a try after I sort my bike out. Higher bars/lower pegs might be necessary. Are you aware of any dealers that might still have TL250 accessories? Thanks. Oh, I'm in the US, but it really doesn't matter.
  29. Thanks. I am sorta set on a TL and might branch out later on. I'll probably be doing more trail riding with my son and grandson than actual trials. I did really enjoy seeing how many difficult objects I could go over as a youngster. I could climb much more difficult terrain than my friends on their higher powered bikes. I'll see what I can do within reason at my age.
  1. Load more activity
