Cota 247 - 1969
Found in the dark of an old parking in Cordoba, southern Spain, this same week. This 1969 Montesa Cota is completely original, never restored, even with the original tyres and the best of all... road registered and now mine !!!!
This beautifull Montesa will be my project for this 2012.
And hope this will be the result after some work...
  • Replies 99
  • Views 46.1k
Most Popular Posts
  • We should start a MK1 Cota owners club.... The one I have is a big hub one with frame and engine number 21m1241 - I think,its a long time since I looked at it.The reg number is about 15 or 20 away fro
  • Here´s how the bike is 3 months later. Still not 100% finished as I am working to fix a chain tensioner as this model did not have it. The engine had to be rebored, new piston, clutch, bearings, seal
  • Hi Triple_X. I think Montesa Cota 247 models Mk1 & 2 are one of the nicest trials bikes ever. Mine is still in bits. Only the frame blasted and painted in white is ready. Working slowly with the
Beautiful bike Greeves! all original parts are there. it will make a beautiful restoration. I have the same bike...I think it is a 1971 mk2. what is the frame number?
Edited by for artie
Wow you must have very lenient road registration rules .... but looks great and I look forward to the finished product
Great project. Keep us up to date with pictures.
You are very lucky, Greeves!!! The bike looks very complete and original. Good and easy project.
the small hubs are the give away, '69 should have the ginormas brake hubs, it may have been upgraded at one time since it has the non-shouldered front rim, I've also got the same bike, everything looks the same as mine except the brake hubs, I upgraded mine in 1984 with '74 wheels and the more slender '74 tank, still have the orriginal stuff if I ever want to go back to orriginal, It has been many years since I rode the thing, rod bearing has a little rattle, so I stoped riding it, plan to restore mine some day, it's my dream to have it going and compete when it has it's 50'th birthday, also my kick start is not the correct one, I got one a few years ago off feebay, neither are the front forks, the forks came from the same '74 doner bike
Edited by MotoVintage
Hi: At last I got the papers !!!
It is definitely a Montesa Cota 247 MkII from April 1970
The front rim is not the original, but I have already found the one to restore it as original as possible.
About the papers, here in Spain if a vehicly is road registered, the registration owns to the vehicle and can not be changed to any other vehicle, which makes it quite easy. The big trouble are bikes that never were registered when new, something very common in the Spanish 70
Even the paperwork has gone rusty, where did you find this one Greevesman in a river.
Here is my 1969 Big Hub 247. She is a "rider". Only improvements are modern tires and Betor shocks. I like to keep it close to stock.
MotoVintage I would encourage you to get your old 247 going again and put the big hubs and tank on. As you can see I have a soft spot for the old Cotas. Your 247 seems to be pretty original, you even have the valanced front fender.
Edited by Martin Belair
Yes, early Cotas had white frames.
I have two, first year 123's with the 17"/20" wheel combo. One has a white looking frame and the other has a battle ship gray looking frame. What color should the frames be? I want to get them repainted.
