What Did You Do To Your Gas Gas Today?
I love it, Andrew!!! :thumbup:
If I had a TY, I'd want it to be one that I knew was solid mechanically, and then I'd ride the wheels off of it........ Not too concerned about "cosmetics".....
Jimmie
Thanks Jimmie!! :beer:
  • Replies 599
  • Views 149.9k
Most Popular Posts
  • is it just me that walks in the garage and pumps the clutch lever a few times then walks back out?
  • Today on my 280,which i'm rebuilding,took the crankshaft to Grampian Motors in Liverpool along with the BE bearing,rod and pin kit . Bruce walks out,i gives him the rod kit, crank and a sheet of paper
  • orkney_will
    orkney_will
    I bought it My first bike. Txt Pro 2004 250cc. Bit of haggling and I got it for £850. No helmet yet as I'm waiting for it to be delivered still, but took it for a slow ride round my field just bec
At last got home!so today on my GasGas fired it up till it got hot and fan cut in then had a quick blast round the garden.
Then to my mates GasGas, i spent 2 hrs bloody cleaning it.
He bought this 03 250 Edition blind,even though i told him not to . If he spent a grand on it, he still wouldn't have a neat bike.It's rattling it's tit's off and quite frankly ain't worth a blow on a Rag and Bone Mans trumpet ! He paid £900 for this thing and every metal surface except the fork legs are goosed.post-16629-0-90946300-1391879357_thumb.jpgpost-16629-0-38757200-1391879319_thumb.jpgpost-16629-0-73941100-1391879280_thumb.jpg I know i'm choosy but check out the spray painted body work and how corroded the engine cases are .
The back shock is leaking and the linkages have more play than soft Mick! Chain and sprockets worn past reliable function. Funny though the front brake works a treat. My self even if i'd traveled to Outer Mombasa to view this bike i would have walked away.If the person who owned this bike is reading this you want stuffing for passing this sort off trash of as Good condition for age . To my Mate,well i told you so!
Edited by shyted
looks like its been ridden in sea water, or just maybe kept out side.
TLTEL
TLTEL
For the state of it tltel i'd agree but i think it look's like it's just been hosed over with a power washer with some sort of de-greaser and left wet , but whatever it's a mess. Glad it ain't mine!
I cleaned the carb after two years standing and i cant wait to ride it but i cant find quikly an atf oil for the gear. Wondering if i can use any other oil.txt pro 280 2008.
Edited by giorgoskilkis
There have been several times my bike came loose from the tie downs and fell over after driving on a bumpy dirt road so I made a brace to keep it secure. Simply drilled a hole in the fender and fork brace, stuck a dowel in, and no more bouncing bike. A thin metal curved sheet is placed between the tire and fender to keep the dowel from damaging tire.
http://www.flickr.com/photos/52067707@N05/12803899423/
I think a plastic (toy) ball between the fender and the bottom fork triple clamp works better: no need to drill holes...
This fork brace has been giving me good service for about 12 years now:
Jon
Ah jse good to see a nice tidy workshop with propper equipmentand clean work space.
Also if you built that tool well done.
I've made braces for all my bikes since the 70's. Here's the one I use for my TY 350s.
Today for mama GasGas,i collected the cases from Triple S coatings in Bingley .
They look mint in reality,they're actually metallic.
Edited by shyted
Been practicing at our lokal trial club grounds, GasGas rode wonderful until coolant came out of the radiator cap hose. Than I noticed the fan didn't work.
Damn, back to the van, removed the fuel tank, checked the connectors and now the fan won't stop running when the engine's on.
Oh bugger, knowing my luck probably a broken relais or temp. switch
Edited by guys
Funny you should ask about what i did today to my GasGas,as on my new 250, i nearly had a baby on discovering a water leak! Just a little speck on the bash plate. I haven't ridden this one in anger yet as iv'e been stuck away from home yadder yadder . Other day ran it up, no problem. Yesterday just before dark noticed the drip on the bash plate . Had a quick peek, revealing water under the water pump unit.On this occasion, i held back on tearing in to it and mailed Kev at GasGas U.K should there be a recognized fault.Bit like the leak from the rear brake hose at the caliper. Any how there isn't .But this is what i found,see the pic'spost-16629-0-38053400-1394449729_thumb.jpgpost-16629-0-52192400-1394449800_thumb.jpgpost-16629-0-77283400-1394449841_thumb.jpgpost-16629-0-06956600-1394449877_thumb.jpg
Not that clear,pic one, but there's a substantial amount of uncleaned casting on this spigot on both sides.Pic two is after i filed it back,
pic three shows how the factory have finished the spigot with the yellow dot .
The last one is so you can see that i did both sides.
So should you spring a leak for no apparent reason,give this a look see.
Ted.
Edited by shyted
