Hydraulics, Do We Need Them?
Since its been implied I am a luddite (regarding EFI) and the number who have problems with hydraulics I thought I would start tis thread.
Do we need hydraulic brakes and clutches on trials bikes?
I have never had to retire from an event either trials or MX because of a cable failure. I have had retirements because of damage to hydraulic parts as do several others I know. Quite a few seem to struggle with brake hydraulics in particular, but I would think most could fix mechanical systems much easier.
  • Replies 88
  • Views 19.3k
Most Popular Posts
  • Do we need USB, SS, drives?  What was wrong with floppy disks or punch tape you might ask?   All academic. A solution to a problem that up until now has never been asked.   Respective the past, em
  • Wow... I nominate this for "old fart thread of the year"!   Seems like a moot point to me. New bikes use hydraulics. They aren't going to go back to cables, so what are we debating?
  • I like the look of drum brake wheels, just like I like the look of the motorbikes they come on. Not many things mar my enjoyment of the aesthetic appeal of a motorbike, as much an old bike that someo
Hydraulics done properly are lower maintenance than cables - pistons that don't jam when the pads get low, bleed nipples and passages to them where the air naturally rises, dust seals etc.
love disc brakes, but could happily live with cable clutch, think they were for the people who caned the clutch so much the adjustment went (originally)
I have an NEB speedway clutch with 3 rather than 6 springs on my Ariel, it handles the power, the bite point is ultra reliable and it is as light as my modern bike ( I have had it for about 5 years and still on the original plates running dry.
Yes it is extreamly simple and I imagine far cheaper than a hydraulic system but I do not see how the same could be applied to brakes, remember moped cable disc brakes putting your feet down was an easier way to stop !
I have experienced an SWM clutch that would stand comparison with a modern one, so it can be done.
Thank you !
Without a doubt the best clutch I ever tried was on a Fantic 307. Remembering that is what drove me to sort the Beta which is damn close now but I never want to go back to the terror of a drop in with wet drum brakes. I suppose there are cable disks for bicycles but I don't know how well they scale up to motorcycle size.
I like stopping.
I like one finger clutch actuation.
But I love my Bultaco.
Same here
Main advantage to a hydraulic clutch i think is that the bite point doesn't change when you turn the bars. We could live with a cable clutch really but i don't want to go back to drums, early disc brakes are bad enough compared to modern stuff.
Amazing how back in the day we managed to ride these old twinshocks with brakes that were just for show and never even thought about clutching.
Now the sections are a shadow  of what they were good brakes and a superlight clutch are essential.
Can someone explain this?
