This stream auto-updates
  1. Yesterday
  2. Look at your wheels, they have date and year like 10-19 then you have a MY20. 03-20 is stil a MY20 but 08-20 is a MY21.
  3. Last week
  4. keihin settings update 48/120 Rotor -10mm (around -500grs) Alloy footrest Xlight tyres Resurfacing the brake discs Dry weight : 72.9kg (stock : 77.2kg dry) Better handling, brakes, clutch, reving ... this 315R is way easier and fun !
  5. Fujigas Replica mudguards flat tank gold wheels
  6. Thanks to François Glineur (on the Beta Techno Owners Facebook group) for reproducing the sticker. Sprido paints (reference: SP00159).
  7. Too easy, sandpaper the shiny parts off, those are the high spots, eventually the entire pad material will be in contact with steel and you will have full braking again.
  8. Mike Komer at the Tryals shop in Locke, NY may be helpful with ideas on the rear brake https://tryalsshop.com/
  9. Hmmm!. try as I might I cant find anyone near me (Westchester, NY) who can do this..the one warm lead turned out to be a guy who only works on Harleys. none of the machine shops wanted to know So, with that said- would that brake arm extender make any kind of difference at all, or is it just a waste of time? i did indeed check to see the shiny bits on the pads that are in contact with the drum..and yeah, it aint much! lol. is there anything else i could do? bike only has 1700 miles on it.
  10. Apologies for not closing this out sooner! Thank you all for help, it was pretty easy as you said it would be! definitely helped me grow in confidence as its another thing Ive now learnt to do. The hardest part was trying to get the valve stem back through the hole! Appreciate you all.... now to the anti judder clutch kit.... lol
  11. How old is the battery? How many charge cycles? Conduct your experiment again while measuring voltage across the battery. If the battery voltage drops precipitously just as the wheel touches the ground, the battery is probably bad. You will have to be quick to observe the drop because the controller will be likely to cut the power due to an "under voltage" condition (and the battery voltage will bounce back immediately).
  12. Thanks, that circuit link is very helpful, there is a lot of other good information in those pages as well. Also, your https://www.electricmotiontech.com/ has been a valuable resource. The logging would indeed generate a lot of data. I could try to pare it down with triggers. I could also set up a GPIO button on one of the scope's inputs so that I could manually signal when something odd occurs. The best is to catch it happening while not riding. Great suggestion of taking off the front sprocket. Yes, I keep thinking there is a connection or wire break somewhere, but the tapping on the right side of the motor seemed to indicate the encoder. But it could be something else.
  13. I have had a TRS80 for about a year for my son. Prior to that I had pretty much every juniors bike available, among which 3 beta 80, vertigo 50s, beta 50s, ty80, multiple osets, on top of that I have experience with beta, vertigo, EM, sherco, montesa, so while I’m not a great rider by any stretch, I have dealt with pretty much every brand in trials. initally we had some problems but were all taken care by trs which acted in conjunction with the importer in an impeccable way. TRS shipped a crate engine across the globe in 5 days so that my son could compete in the Nationals, and my son did compete and won on it. speaking from experience, problems happen with all brands but not many send an engine across the world so that a little kid can ride a race, I can name names and do multiple examples of the opposite behaviour but best to stick to TRS merits here. the new side case took a bit to be available but transformed the bike and the reliability has been excellent since and on par with the bigger bikes. not only, but we installed a bigger bore cylinder and the engine took it no problems and the reliability hasn’t changed. we live on an acreage and my son uses his bike every single day, and every single day this bloody thing starts first kick, hot or cold. compared with those bored out 50cc by beta with no linkage and concrete suspensions, this bike goes like an airplane. not to mention we installed a gold super fast throttle. today I took it for a ride and had my 3 year old standing on my feet, so probably close to 100kg weight and this bike was just chugging along in third up and down hill at trials speeds. the suspensions are perfect, we added a compression adjustor to the forks to make it a bit quicker but to be honest it wasn’t needed, the shock is absolutely standard. my son (12yo, 35kg weight) hops this thing left and right and rode this bike in T3 in local club trials. I don’t know what else to ask to this bike, it’s been a rocky start yes but turned out absolutely great. While I respect the experience of others, I feel that TRS with us worked in a professional manner and this bike satisfies all our needs. is it perfectible? Of course! A proper ktm engine or a small expansion chamber would be killer. Some components should drop the chinesium but it does what it promised. and I repeat, a beta 80 is not even close, from a geometry point of view, and from a engine power delivery point of view.
  14. Switched the starter button to the left side because for me it makes it much easier to restart without loss of control over the throttle and clutch.
  15. Congratulations on getting a 'scope. That's what the waveforms should look like. The siliXcon controller input circuit shows a pull-up resistor to +5VDC: https://docs.silixcon.com/docs/hw/esc/ax1/IO/#sin-cos-sensor-connection I don't think general-purpose data logging would be practical. Notice that your 'scope is sampling at 100kS/s. You could sample slower than that and still make out waveshapes, but the sample rate needs to scale proportional to rpm. Riding speed and duration will result in a massive amount of data. Even if you could store it, you would have to sort through it visually. Try heating the sensor with something like a hair dryer while testing. But honestly, I doubt that will reveal anything. I think the most likely problem is an intermittent connection somewhere. But I can't think of a failure mode that would produce your symptoms. But EM keeps changing the firmware, and all I really know is my 2021. P.S. Try running the bike on a stand and monitor the sin/cos signals at normal running (and varying) RPMs. When I do things like that at high speed, I like to strap the bike to my trailer so it can't get away! P.P.S. Another thing I have done to promote safer stationary testing is to remove the front sprocket.
  16. It depends... 125 rearwards kick is the "old" Minarelli engine, earlier frame. 125 Professional FM237 forward kick was little brother to the 240. Engine mounts were the same but the 240 had an additional loop on the lower frame rail to protect the wider flywheel. Happily, the 156cc barrel & piston from the "old" 200 fits the forward kick motor, giving you a 200 Professional.
  17. @konradI ended up getting an oscilloscope since the multimeter wasn't helping me. I found out that I had to connect the encoder to the controller and tap into the sin/cos/ground wires while the bike was powered up. Bench testing the controller off the bike with a power supply didn't work, apparently the sin/cos lines need some sort of termination circuit. But with the encoder hooked up in the regular way, turning the wheel by hand gives reasonable sin/cos curves. I didn't see anything odd taping on the encoder while gathering data. Attached is a screenshot of the capture. I'm going to think about setting up gathering data while riding. But any input would be appreciated.
  18. Sadly my index finger doesn't have the power or another joint so I've had to start riding with my middle finger doing the work. Nice moccasins. My electric button is on the right. Any reason for the left?
  19. yambits in the UK have oversize pistons
  20. Thank you. They do sit better that way but I just wanted to confirm. They are listed on the In Motion website as Pursang only so no idea how they got to my gearbox.
  21. Many thanks to yo both much appreciated with the information given regards Andy
  22. Hi, If you are in the UK try contacting Westwood Liners. They have a website and are located in the West Midlands. They have a postal service and they will remove the old liner and refit a new one.
  23. Shorty levers moved way in on the bars, slack adjusted to provide comfortable bend and range for the clutch finger, gives you the most leverage and friction range possible and your lever will never crush your grip fingers 👍 3rd gear pulls from zero to biggest thing I can ride so I ride almost exclusively in 3rd but that really depends on the terrain you ride.
  1. Load more activity
