This stream auto-updates
  1. Past hour
  2. Thank you both. I looked at the eBay item and it was in bad shape. There is substantial damage to the fiberglass and the actual seat is in very poor condition. I have seen the covers and I may have to go that route if I can’t find something better.
  3. Thank you. You get it, don’t just settle for what the docs say. Never forget the power of exercise and fresh air in regard to health. Challenging ourselves with new activities is powerful medicine.
  4. Today
  5. SlowDave, keep showing the doctors they’re wrong. I had an accident (electrocuted) when I was a kid that kept me hospitalized for an entire year. The doctors said I wouldn’t be able to run or ride my bike anymore and that I’d be in a wheelchair in my 50s. Well, I did run again and even skied competitively in college. I’m 65 now and still going strong. Doctors don’t know everything. Also, I had a 1974 TY250 myself that I rode in high school after I was released from the hospital. I’m looking for one now myself. I loved that bike.
  6. You can get reproduction seat covers for cheap and all you have to do is replace the foam. https://www.ebay.com/itm/152173175811?_skw=Yamaha+TY250&itmmeta=01KPVB8X7K75DWFQGXEMP05ASF&hash=item236e3a6403:g:m4UAAOSwxWxg~5Mx&itmprp=enc%3AAQALAAAA8DKQclQvzFwZQpmMrsO4LurgsYX0OYtwnOHG1FqA1%2F4kKnkmO1Tf1vVMAj8S58n4mC%2BLYnlfInRqXIScPwtyzkobh23jam4E7Q9g2reOSh52rFIaNN4L0M9qqSfHPPaW4PSPqfenXRfb2Viv0owk1jo04zzjMlCGznp54xmySvlN4lXY%2BBlFCwrt9aEl1ky0oFIORYTYoP7KkHCURS5NmD%2FvEPsuFzic575YGiyrrX4VpKejiPf4A8dt5HADBGxFVo8pnWJt4rsvnQTq4lAzQPHqi%2FVzqGrbzzJi7qdb7bXYpPBWn%2BbHe%2BztGNRCHkB4sw%3D%3D|tkp%3ABFBMyNSj67Zn
  7. Is it like this? ebay.com/itm/365822976402?_skw=1974+Yamaha+TY250&itmmeta=01KPV5YX13M48FFR2BAG0ZVDFH&hash=item552cbfa192%3Ag%3ATYAAAeSwHcRorLmO&itmprp=enc%3AAQALAAAA0DKQclQvzFwZQpmMrsO4LurGqnycjbd5VkwylZMszIT7wKNntaYRkyc%2FYW8%2BcCnFT7EcmHMszpbwyKBSBChJZICvqQBQh9nSxjEaS7YQFEroUjCgoYMax4z4eKyNTaBA4K%2FRcHticXdmDZmB3iWm%2BfBE5MzgZWWAbKzVmPH0a%2FmCIvXOsBKUmgm5OKS3VeoDvFAyiS94z3rQIelBzQFVpj4uTEeglymppCI9RADj5faRJCqGn4zN%2FejPVOWkTjSUBrAtjm8RhhJL4HVUlaC3mPU%3D%7Ctkp%3ABk9SR-jQ--W2Zw&fits=Year%3A1974%7CMake%3AYamaha%7CModel%3ATY250
  8. Recently I purchased a beater ty250 and I am looking for a seat. They appear to be unavailable so I guess I am going to have to have one made. Have any of you done this? Any recommendations as to who can make it? I do have the fiberglass base but no seat. I have made my own seat pans in the past but I would rater not reinvent the wheel if there is a supplier out there. I am located in the US. Thanks
  9. Hi All, I am new here and new to trials. I recently purchased a beater 1974 ty250 that I am starting to go through. I have 3 other bikes, Husky FE 350s, BSA B50 MX and a BMW r75/5. I have a bad habit of slowing down and falling over. I figured working on my balance is a good idea, a good excuse to buy another bike anyway. 25 years ago I was diagnosed with a rare neurological condition like MS and I was told I had a wheelchair in my future. I have been working hard to prove the docs wrong ever since.
  10. Jetting seems on the rich side for a small 4 stroke. OKO come with smaller jets than that as standard, can't remember what 24mm come with but 26mm have 48 pilot and 112 main. On 2-strokes that jetting generally works fine on anything, maybe a 50 or 52 pilot and drop the needle one notch from centre - this is what I have on various Bultacos 250cc, 340cc and Ossa 250cc, 310cc. Some people also use a JJH needle but I've noticed little to no difference when I tried one
  11. Yesterday
  12. lemur
    Beta Techno Carb Woes
    Does it make any difference if you raise or lower the front wheel considerably? That is a tell if the float height is off. for example: it bogs out every time the front wheel is down in a hole, float height is likely off. Inspect the reed valves might also be advised, if there is fuel leak down past the reed valves they must not be sealing very well.
  13. I'm having a mare of a time trying to get the carb to stop *issing out petrol that ultimately causes blk oil to leak out of the exhausat header when kicking the bike over! Let me explain the bike was running ok until I switched over to reserve one day , after a few minutes of running it cut out and has not run properly ever since, I thought there was crap in the carb so refuled the bike and clesaned the carb out , a thousand kicks later still no good so cleaned the carb again and then a while later drained some fuel and even with tha fuel filter there was debris in the sample. I traced this back to a damaged fuel filter so replaced it and clenaed carb again abut still no luck , the bike feels like its binding a bit when i kick it over but still get blak crap out of the header. I cleaned the carb and set the float height and also had the choke to pieces but still it does not fire up , cleaned and checked the plug and still nothing. Weeks later I'm wondering if the floatr height is the issue as looking on the net there seems to be conflicting advice on float height , some say 15mm some say 20mm , some say level tangs with float tangs , I'm confused now and wonder if someone with a working techno on a mikuni carb with plastic floats that slide up and down on pins can give me some advice on how to best set the float height please. I like the techno but now this bike is like the Tardis and i'm losing time not getting anywhere. The carb is now off the bike and I can add photos to check the float setting when I've adjusted it correctly just to confirm. TIA
  14. If you bought it through Mid Atlantic Trials, their guy Roger Annable could undoubtedly give you good advice. If you bought elsewhere, it may be an OKO copy, which are pretty useless.
  15. https://www.jetsrus.com/individual_parts/HUA-1003-PWK 28 jet block oring.html
  16. Ive worked on the Sherco version and yes you remove the trials tank and the longride seat/tank unit replaces the tank and sits over the existing seat. So to go from longride to trials you just need the trials tank. Less than a 5 minute job
  17. Hi all, Just wondering if anyone has fitted an OKO 24mm flatslide carb (copy of Kehin PKW) to their TLR? If just fitted one (with a lot of mucking about) pilot is #55, main is #118. Needle on centre groove. Runs ok to mid throttle, then like ***** above that. Just wondering what others have done.
  18. Pictures would really help, otherwise we're just guessing. Every picture I can find of a TRS has the valve stem and rim lock 180° apart.
  19. Last week
  20. The Montesa Cota 348 Facebook page has lots of 348 documentation available to download, under the Files tab
  21. If the rim has no rim lock hole it is designed for tubeless. You want a Radial tubeless rear and a tube type front that has a rim lock.
  22. To me stock means how they leave the factory, and like 99.99% of all trials bikes across all brands leave the factory, with a conventional front tube. If it does indeed have a tubliss system installed, I can't say for sure as I haven't seen your bike (but it really sounds like it), then imo it's not stock. If you want to think your bike is stock, come on a forum and ask why your front wheel is different than every other trials bike, and still be adamant yours is stock, by all means you are free to do so. It just means every other person who owns a trials bike with a conventional front tube has the non stock option fitted, because yours is the stock option. The stock option of 1 in a 1000
  23. I can't really advise having never owned nor ridden a pre 06 gg, but at the time I remember people saying it made a noticeable difference when the light spring came in 06. There's also the chance someone has fitted the later spring to your 05. As for modifying or replacing the plates I wouldn't be in a rush to do that if the clutch is functioning ok
  24. Ive had both, rebought the older design when they went with formula in 2012 ish, never noticed much difference. Its lies in the toolbox as a spare
  25. I've been looking through the available lit, and searching the forum. I'm still not positive what tires to put on this bike. The giant knobbys have to go. Are the stock rims meant for tubeless tires? Even though this bike is 20 years old, it's light years ahead of my tl125. I've never owned anything this new. Thanks for putting up with these noob questions.
  26. the rear finish plate is cracked on my Italjet Shopping 50, found out the model is niche and there isn’t any research online about it, basically lost to the internet any other enthusiasts with info I would love any info you have I have the original owners manual but it’s in Italian and that doesn’t help with finding parts does anyone know if the parts are interchangeable on any other Italjet scooters for this model
  1. Load more activity
