- Past hour
1974 TY250A - Does the Shedworks Tank/Seat Combo work?
feetupfun replied to onefunride's topic in Yamaha
The tank seat shown on the B&J Racing page is fibreglass and is a Sammy Miller Products tank seat and may be old stock. When you said the A model is lighter than the later ones, do you mean the whole bike or the fuel tank? The CDE models have the lightest rims, being Japanese copies of the lightweight AKRONT trials rims. The A model have lightest swingarm. CDE swingarms have more elaborate gusseting near the pivot. The BCDE flywheel is much heavier than the A model. The BCDE engine covers are lighter than the A model. The lightest tank I've found is a Majesty shape made from very thin aluminium. I bought it from France Trial Classic in about 2008. It dents very easily. I'm not sure if they are still available, but there is/was an aluminium steering stem/axle available. It is a lot lighter than the original. Also the top bolt and slotted nut for the steering axle. There is/was an aluminium swingarm inner bush available. I replaced all the wheel axle spacers with aluminium items. - Yesterday
onefunride replied to onefunride's topic in Yamaha
Feetupfun, thank for the clarification, it shed some light on my confusion. I do have the WES exhaust, and a few other items installed already. I have the forks setup using the InMotion aluminum damper rods and Trials France magical springs. I have an original fuel tank that is in fantastic condition, I am nervous about smashing it up, which sent me down the path of looking for a different fuel tank and possibly a weight saving in the process. The Shedworks tank and seat assembly looks fantastic, but it gets quite pricey to ship to the US. Interestingly, according to the internet the A version was lighter than the later TYs. Possibly a Majestic tank, long fender, and a late model seat with fiberglass pan could be a good option. Something like the attached pics. BJ Racing has a tank seat combination that looks much like the Shedworks, but I think it is all fiberglass and does not have the inner aluminum tank. http://bjracing.com/id121.html hard to tell. -
congngherfid joined the community
quattreotuongpanason joined the community
You can load up photos here,click on add files and you will be able to upload photos
dentoanloi joined the community
The 10w40 should be more than up to the job unless it’s very poor quality. These things will happily change up and down without the clutch just by matching the revs. My gearbox is 20 years old and never been touched!! I have always found 10w40 to stand up better to heat and more abuse than Elf and light gear oils. The lights ALWAYS give a better clutch when cold but they get very grabby and snatchy when working hard. I run Motul 300v factory line for both engine and gear box. **** when cold, but isn’t affected by heat and hard riding. Another thing with the Mont clutch is that you generally need full pull of the lever to find neutral. Any fingers between the lever and bars makes finding neutral tricky. Using the short lever helps, then it’s just 1 finger right at end next to the ball.
Sorted with a ball end allen key. Thanks.
Kubota Premium UDT Hydraulic/Transmission Fluid specifically formulated for transmissions with wet brakes as well as power steering and power takeoff units with wet clutches 👍 At a small fraction of the cost of what those other guys use, I can change it out twice as often and still save money.
john_192 joined the community
For a slimmer look, you could fit the later model seat and rear guard. For an A model frame, this would need some frame tabs added for the seat mounts. The A model airbox is compatible with all known seat/tank/mudguard options. What you wrote about the airbox forming part of the rear guard applies to all TY250 twinshock models. The A model (and B model which was not sold in the USA) rear mudguard arrangement going from front to rear has airbox then seat shroud/fairing then short plastic mudguard. The C, D and E models have airbox then long plastic mudguard. If you want to use the Shedworks tank/seat, you will need to buy a later model rear mudguard. As for buying a later model (long) rear guard https://www.inmotiontrials.com/product/ty-250-rear-mudguard-white/ If you want it to feel lighter to ride, replace the standard exhaust with a WES exhaust. The later model TY250 fuel tank is made of aluminium and is lighter than the steel A model TY250 tank. -
If you can't get ELF HTX740 then GRO TRANS EXTREM 75W is the go for the transmission oil from my experience, never had an issue with either.
Me too but I’m trying to do the simple things first, like changing oil, before kicking a fuss with the dealer it came from. Practice area was mild, not overly hot, mid-evening (UK, so 20° maybe more). Easy rolling practice around some trees on a slope. After a short while it was getting tough to change gears. After an hour it refused to change and refused neutral unless off. After riding down the lane back to the van and the bike being a bit cooler, it would shift a bit easier. Off and cold, the shifting feels a bit clunky but monts are new to me (vs the ‘83 TLR, ‘16 Sherco, and all the trail and road bikes).
I find it hard to believe 10W40 oil could cause that malady.
I'm interested,What do you want for it
got one but been cut in half and gluded back to gether if any good ?
onefunride started following 1974 TY250A - Does the Shedworks Tank/Seat Combo work?
I really like the looks of the Shedworks Tank/Seat combination; however, I can't figure out if it is compatible with the 1974 TY250? I struggle to understand what is compatible with the rear fender that uses the fiberglass seat pan. In all the pictures I see it seems the models are later versions, with a different rear mudguard and I can't find this other mudguard for sale (I have the short mudguard where the air box is part of the rear mudguard). Is a different rear fender needed for this to work? Is the stock air box compatible with the Shedworks setup? I also see majesty style aluminum tanks that look good, they seem to use a different rear fender as well. I am trying to cut weight, have a more "sleek/narrow" look and feel to the bike. Thoughts? Which would be considered better, or is there another option to clean up the bike? Thank you Glenn
mcman56 started following Return of the “what transmission oil”
Gauss Gauss, brilliant! Wish I had thought of that! PM system says you cannot accept mail. Intentional, or full mailbox?
So nothing has changed? Assume you mean Dex 6, not Dex 11? Might try some D6 before spunking on elf.
My son runs elf. I run dex vi Go figure.
Nishijin started following Return of the “what transmission oil”
Hi all, Bought a 2016 300rr and the dealer put 10w40 tranny oil in it. Not Elf. Took for a practice. Felt fine until hot-hot and then refused to find any gear except the one it was in, had to turn off or wait until cool. Prefer not a light-switch clutch. What was the decision after the past decade since people chatting GRO?
Do Jotagas / JTG still exist. G2 Grup?
ChrisCH replied to bikerpet's topic in JGAS (Formerly Jotagas)
I like the Mecatecno but they do not (as best I can see) do much marketing. I have only ever seen one - the one at SW Trials and it was there for a very long time. It is a big leap of faith to buy something at the top end of prices without a test ride and when you do not know anyone that has one. They don't have a demo fleet with the importer like EM. That was what I meant by not cutting it. I am sure the bike is a good bit of kit. -
The market has changed big time - you are right. Was the Mechatecno the SW Trials one? It was a couple of years old IIRC but unused. People are still buying bikes and are buying new bikes but I think the cheaper stuff was massively overpriced for a while and some sellers still kite flying. -
https://www.clasicasdiaz.com/tienda/en/porta-numeros-and-handlebar-protector/1674-handlebar-protector-ossa.html https://mmgracingstore.com/en/motorcycle-accessories-and-handlebars/107693-handlebar-pad-ossa.html that's just two I saw when I googled it with that pic...........
mattslinger started following Jotagas JT300 2013
Time Left: 24 days and 7 hours
- FOR SALE
- USED
Jotagas JT300 trials bike, 2013 model. UK bike, road registered. In great original condition, standard bike apart from Ohlins rear shock and S3 bars, foot pegs, head and exhaust. Comes with headlight, V5 and some spares. Well looked after, runs and rides perfectly. Owned by myself for the last 10 years. The bike has been used infrequently for practice only. £1650 ONO. No swaps or part ex. Located in FY6 0DZ. Call Matt 07884253169 for info.1,650.00 GBP
anachronism replied to bikerpet's topic in JGAS (Formerly Jotagas)
Curious on your definition of not cutting it. They are egregiously expensive. -
In the UK cheap second hand ICE bikes are not selling , the prices are dropping by hundreds and still no sale , Adam Raga dumped by TRS , a Mechatecno on Ebay dropped from 9,000.00 to 5,500.00 and still no sale after months. Sherco makes a budget ICE model for the market. Personally I do not see any room for any type of trials bike in the market certainly not something that costs 10,000 just to faff about on a Sunday afternoon.
Flash1 started following Ossa tr280i bar pad
Hi, does anyone have one of these bar pads they will sell
mattslinger joined the community
I think there is room in the market for another electric as well as EM. Mechatecno are not cutting it (much as I like their bike). I thought Gasgas might have a model out by now but the parent company's financial problems probably explain why they have not.
By pre65wobbler
21 days and 11 hours
