This stream auto-updates
  1. Past hour
  2. Use of the clutch is not *required* to change gear. You can test the gearbox separately from the clutch. If you have no experience doing this, here is a method: Put the bike on a stand. Although not mandatory, it's probably best to remove the chain. (But you will have the extra inertia of the rear wheel to overcome.) Remove the spark plug and flywheel cover. Turn the engine by hand using the flywheel. Attempt to change gears while rotating the flywheel back and forth. It will only take a small fraction of a complete engine revolution to select the next gear. If you have not removed the chain, you may find it easier to rotate the rear wheel instead.
  3. Today
  4. This is obviously only my opinion - But several things, the RS200 was never sold as a UK model, so it would be extremely unlikely that you would ever find one correctly registered from new in the UK - So a later age plate doesn't look out of place. It was also built by what became HRC, so not a standard production line bike, but more a small volume hand built machine.. So I'd be surprised if anywhere outside of Honda in Japan would have any records at all. And at that time many new bikes were not registered when new, often by second or third owners. You have a registration document for your bike which by law gives it an official identity in the UK, so it can be used on the road legally and the Police via the DVLA database would be able to return it to you in the hopefully unlikely event that it was stolen and recovered. I think its best just to stick with what you already have, maybe it is not technically 100% correct, but does it really matter ? I have a 1986 RTL250s which I am going to register, just to give it an identity in case of theft. I've yet to find any info on them relating to production numbers etc, and I've read all I can find on the net including the Honda trials history website. I also have the Four Stroke Finale book, but again no detail... The main thing is that we CAN register old bikes, where my brother lives in Portugal it is impossible to register old bikes...
  5. Yesterday
  6. Hi just replied to your previous post with a bit of general information before I saw this one. The parts book is what I had originally, don’t think there’s much else out there. You can see the chain tubes on there and the tank/seat bulges, but that book shows a full width hub which I think were the earlier models. The clutch mechanism was a bit suspect in that the little pawl 2863.106 was made of poor material and its square hole wasn’t a very accurate fit on the bottom of the operating lever shaft 3863.081. Both the square on the shaft and the hole seemed to wear easily along with the finger end of the pawl. A tiny amount of wear in any of that means pretty rubbish clutch operation.
  7. Oh and it would have had the traditional montesa feature of plastic tubes for the chain to run in which floated on a bracket mounted on the rear spindle. It would be nice to see more photos, they were a decent bike really, underrated in my opinion, apart from the brakes which like most bikes at the time just stopped being brakes as soon as you got them wet !
  8. Hi, I’m not certain but looks like you might possibly have a 200 ‘C’ model from 83. I had one back in the day. I think a couple of noticeable features of that model were half width front hub which I can’t see on your photo, and they also had a small flair/bulge at the rear bottom edge of the tank unit which smoothed over the top rear shock mounts but that might have been cut off if they’d got damaged or cracked over the years. I can see you’re missing the air box & chain tensioner and also the rubber straps which pull the rear of the tank down to the hooks on the frame. I believe ‘in motion’ are a good source of parts in uk.
  9. Thank you so much for the PDF 👍
  10. I can feel the mechanism trying to activate the clutch 👍 I actually can't start And change up to a high gear thank you for your help
  11. A flare nut spanner might be the answer. It is a type of open ended spanner with a bigger purchase. An example is here: https://uk.rs-online.com/web/p/spanners/2358029?cm_mmc=UK-PLA-DS3A-_-bing-_-PLA_UK_EN_Catch+All-_-Mechanical,+Fluid+Power+%26+Tools-_-2358029&matchtype=e&pla-4574999185500285&cq_src=google_ads&cq_cmp=554644865&cq_term=&cq_plac=&cq_net=s&cq_plt=gp&msclkid=095f50e9815a1b0f8679389616c21e79&gclid=095f50e9815a1b0f8679389616c21e79&gclsrc=3p.ds&gad_source=7
  12. https://www.motionpro.com/product/08-0380
  13. When you pull the clutch lever in I assume you can feel the mechanism trying to activate the clutch? Also I assume you have tried riding it in a high gear with the clutch pulled in while accelerating?
  14. On my gasgas enduro bike I went to the shop and bought a cheap ring spanner and ground the outside down until it fit. Scientific torque spec I used was almost as tight as I could do it by hand and then give the the spanner a couple of light hits with a hammer.
  15. Hi guys. Got 2018 txt 250 and tried to replacing the top end but I really can’t find way to how to tighten front cylinder base nuts. Plain ring wrench doesn't fit at all neither most slim wrench(signet 30493) I got. Was tried to tighten with open end wrench but seems like nuts are gonna stripping. Any idea how to tighten these nuts with torque spec??
  16. Last week
  17. It definitely should do much better than that. Could someone have geared it way up?
  18. Anyone still alive on here that has any information on the clutch assembly? *******o clutch will not disingage ( stuck in gear) all gears selectable... Have soaked the basket in petrol and doesn't seem to be sticking.. really need an exploded diagram as I feel a crucial part maybe missing.. engine was rebuilt by someone else.. even the tiniest information would be great 👍
  19. There might be a problem with the exhaust being partialy blocked
  20. There are two forums on here where you can ask Cota 200 questions. One is "Twinshock" and other is "Montesa". There are also facebook pages for Montesa motorbikes.
  21. yeah i did that and even when i incorporated body movement like i do wheelies on other four strokes this one just lifted the front wheel slightly 😅
  22. Hi all recently purchased a Montesa cota 200 81/82 I think, I'm finding it hard to find a knowledge base for this machine,so who's the Go to on here for the knowledge?
  23. You're not using the clutch, your reed valves need attention or the previous owner added weight to the flywheel would be my first guess. The 1980's TY should spool up much more quickly compared to a 1970's TY'
  24. You may be missing the hit or "coming on the pipe" of other type two strokes. Trials bikes mostly have very smooth torque curves so don't tend to do that. IIRC, that particular model does not run to high RPMs so if you are trying to lift the wheel when you are already up in the RPM range, it may not happen. However, It should be able to lift the front wheel. What happens if you are rolling along at a slow walking speed in first or second gear and quickly open the throttle most of the way?
  25. use the long end of the Allen key to access the bolt. then use a wrench (5mm I think) on the Allen key to loosen. It is easier with "ball-end" Allen keys.
  26. Looking at it, I believe the reservoir has been changed. It has a straight spigot instead of an angled one, that is why it doesn't sit correctly. The bottom of the tank is pushing down on it and the straight spigot is trapping/kinking the pipe
  27. Your statement "this is my first time riding a trial bike" tells me that the bike may be working normally, because 2 stroke trials bikes like your TY mono are very different in engine performance and gearing to 2 stroke non-trials bikes. How about you post up a link to a Youtube video of you riding your bike so people can tell you if there is anything wrong with the bike.
  28. I just bought a 1986 yamaha ty250 and this is my first time riding a trial bike, in my experience with many 2-stroke bikes, I find them very strong at the initial throttle, easy to wheelie, but on the ty250 i just bought, in 1st 2nd 3rd gear it is not strong, it just keeps slow speed, can't even do a wheelie, is that normal or is there something wrong with my bike?
  1. Load more activity
