What Did You Do To Your Gas Gas Today?
Took my bike appart today for some much needed maintance which has been too long on the list now.
I will put in new crankbearings, new clutch basket and crankgear, new idler and kickstartgear, and give the rest a good cleanup! Repair the exhaust (minor leak near rearbrake mounting point), weld the frame (underneath the radiator is a small ''bridge'' which always brakes).
Probably put in the new type waterpump.
Notice the piston rings which are carbonised stuck into the piston!
and probably more!
Edited by crazybond700
  • Replies 599
  • Views 153.3k
Most Popular Posts
  • is it just me that walks in the garage and pumps the clutch lever a few times then walks back out?
  • Today on my 280,which i'm rebuilding,took the crankshaft to Grampian Motors in Liverpool along with the BE bearing,rod and pin kit . Bruce walks out,i gives him the rod kit, crank and a sheet of paper
  • orkney_will
    orkney_will
    I bought it My first bike. Txt Pro 2004 250cc. Bit of haggling and I got it for £850. No helmet yet as I'm waiting for it to be delivered still, but took it for a slow ride round my field just bec
Ahaaa! The first signs of KTM parts (of course disguised as an S3 part) on a Gas Gas engine in the top picture!
Actually its in real life more of a beta red :P Phone cam is quite crappy
Last Saturday morning  was a little cool so went into the shed pulled top end down my Raga had ticked over 260 hrs on std piston pulled it out still mint put in the new S3 piston kit, so in the next 260 hrs will start it over again. Had a cuppa then pulled the clutch pack out of my wife's pro 125 needs new plates should arrive this week from mate Peter B them its time for a spin on them.
Just stripped and cleaned carb thoroughly having had it keep stalling when I took it away. Now just waiting for my new fan rectifier to come and then ride it knowing it is cooling properly...hopefully.
  • 2 months later...
Well as I mentioned elsewhere I rode my newly acquired Gas Gas 125 (2012) today.
My son was getting fed up with hanging around to kick start my old 1980s Montesa.
At age 82 next birthday it was getting to heavy for me anyway ! The old legs give out
more easily nowadays which makes me wonder how I coped with my BSA rigid 350
B32 Oh silly me that was 60 years ago !!  :hyper:
Almost finished my engine work
some teasers
The gearbox bearing was stuck, so took some effort to get out!
Hopefully it will be going for some years more now!
Fed up with awkward oil fill (not really that awkward but anyway) total oil charge can be held in the funnel so nice and easy now!
Edited by jfc
Pump for filling lower unit on outboard motor,fits standard oil bottle
