- Past hour
The plate holds the springs straight. They other wise rub on the towers. The springs are much lighter. Available from Webike.
There are springs and plate available which improves the clutch feel. of course it`s only available in Japan.
Baffle in expansion chamber? Removal??
cascao replied to motopsycho87's topic in General Trials Talk
It is a chamber but will never be an expansion chamber like we found on enduro motorcycles simply because the shape and position is not right. -
motopsycho87 replied to motopsycho87's topic in General Trials Talk
I managed to rip it out, turns out the baffle tube is titanium just like the outer. Took about 4 hours of hammer, lever bar and brute force. NOT FOR THE FAINT HEARTED! I repacked the silencer while I was at it. Started the bike up in the shed and very crisp note, slightly louder. I'm interested to see what it rides like potentially utilising the expansion chamber shape for the first time ever...! -
like you said it works the reverse way, the springs push the plates out to the pressure plate on the end, when operated the pressure plate pushes toward the engine and releases the clutch. I've only ridden a few 4RT's and found the clutch to be of a light action so I would compare yours to others before adjusting the springs. It may be you have another issue
Thanks for the clarification. I was installing some spacers to reduce spring preload. I planned to pop the plates out to see if it had dimpled plates but was surprised that the plates could not just slip out. It is sort of the reverse of every other bike clutch I have ever had apart. I learned something new.
jonnyc21 replied to motopsycho87's topic in General Trials Talk
Well unless you want to let out all of the packing behind that baffle I wouldn't recommend it. I can't say for sure on the beta but all of the 2T bikes I have worked on have behind the baffle is one of a few different kinds of packing... Video of an older Sherco getting a re-pack. -
Take a look from 4-42 to 4-45 of the service manual. should help enlighten how the clutch works. (2020 301 RR service manual: https://www.montesa.com/wp-content/uploads/2020/03/OSM-301RR-2020-EN-Web_V04.pdf )
Cool thanks for posting. Gee haven't ridden. Rain on last trial and a few other bikes needed thier wheels rotated every other sunday in the manner of which they demanded and I am but their humble servant. Edit, sorry ever other made it sound 2 weekly. I meant every Sunday other than the rained out Trial. But Sunday looks good to have a proper test at a low key trial, ideal.
You can use a Gas Gas Belville spring there a little softer I took the Belville spring and ground it thinner it worked great
faussy replied to motopsycho87's topic in General Trials Talk
Sorry, im no help. Now I know what's inside that front triangle section anyway. I know you can buy a more conventionally shaped aftermarket front pipe from s3 or the likes for the beta, that I guess doesn't have the baffle -
Beta Evo 300 2013 factory -
What bike is it? -
Technical Resources for Electric Motion Trials Bikes
Gotta_practice replied to konrad's topic in EM (Electric Motion)
This is an amazing technical resource for Electric Motion motorcycles! Terrific work konrad!! As he stated, use the search tool on the site, great way to find all info relating to your topic of interest. Mark 2017 Escape rider -
Gotta_practice joined the community
Not unusual really, same as TLR's albeit they are cable operated......
mcman56 started following 4RT Clutch Actuation?
I had the clutch cover off and am struggling to understand how the clutch actuator works. Every bike I remember controls the bike from the opposite side of the engine. A rod goes through and pushes the pressure plate out to create clearance and release the clutch. On this bike, the slave cylinder pushes in the opposite direction. So, is the movable pressure plate on the back side of the clutch pack when compared to other bikes? The parts list looks like that.
motopsycho87 started following Baffle in expansion chamber? Removal??
Hi all, has anybody removed the baffle from their modern 2 stroke trials expansion chamber? Seems a bit odd as it's the worst place for trapping unburned fuel/oil mix, and kinda negates the point of an expansion chamber in the first place?
motopsycho87 joined the community
Bultaco 350 Carburettor settings 199A
TomGudgeon replied to Adam Bulty's topic in Introduce Yourself
Or this one? https://www.ebay.co.uk/itm/376665968838?chn=ps&_ul=GB&var=645264625710&_trkparms=ispr%3D1&amdata=enc%3A1kL_m6yi5R4-BWruA4BSmVA13&norover=1&mkevt=1&mkrid=710-173151-921626-2&mkcid=2&mkscid=101&itemid=645264625710_376665968838&targetid=2448003509029&device=c&mktype=pla&googleloc=9190959&poi=&campaignid=22924815337&mkgroupid=183371074490&rlsatarget=aud-2317547358629:pla-2448003509029&abcId=10425036&merchantid=5631438962&gad_source=1&gad_campaignid=22924815337&gbraid=0AAAAAD_Lr1dnIkdoNdVfCbDEXvX4OtSA_&gclid=CjwKCAiA2svIBhB-EiwARWDPjn8ILoYjk45RuGuHPej4d8KMDBmpi9uoV9sY6kEm_GYT4-8VSWNfthoCeHEQAvD_BwE Why the massive price difference? -
Hey I've got the same issue with my Bing 84 - not able to find replacement O-rings, choke rubber and gasket kit which have all perished. Is the below link what I should go for, for a straight swap? It's for a Sherpa T 350 1975 https://www.ebay.co.uk/itm/301495710655 -
TomGudgeon changed their profile photo
Thanks guys this is all I need. A new Dellorto from In Motion it is! Over and out
Mikuni or Keihin or OKO or Dell Orto are all a better option. Keihin most expensive. OKO least expensive.
Ye that's the right one. Never liked them it will.most likely be worn so get a new dellorto from in motion comes jetted to suit and better carb
TomGudgeon started following Carburettor kit for Sherpa T 350
Hello there I have a Bing 84 fitted on my 1975 Sherpa which needs new gaskets and O rings, but the price I found online is the same as whole new carburettor! Therefore I’m wondering if: A. Is this is the right carb for the bike? B. Where I can find a cheap rebuild kit so it runs properly? C. Can I put a new carb on it? I don’t know much about this bike so any help is much appreciated. Thanks Tom
TomGudgeon joined the community
The other replies are spot on, but the top hat washers on the springs on some beta models are also worth checking. They can be fitted either way up for more or less preload which makes a big difference to how the clutch feels. While you're in there there's a shim and a spec for the clearance at the end of the push rod, it's worth checking while you're on but it mainly affects drag.
Don't know about EM's but the small Mecatecno's had 5 volt going to the throttle, if the throttle was closed, the control unit expected 0 volt to return. If the control unit received any voltage it wouldn't switch on. If the kids dropped the bike in water it was only a few weeks before this problem materialised, I kept a spare throttle in the tool box when we were competing.
