- Today
"Shorting out on points cover". I sent my bike to two garages. Neither could sort it out. Finally I was looking at the engine when I noticed a little black mark on the inside of the points cover. It was arcing across to the cover and shorting out,
RESTOMOD started following IMG_9451.jpeg , IMG_9139.jpeg , IMG_9129.jpeg and 3 others
Try Hugh's Bultaco. www.bultacoclassic.com
- 1 reply
- 1
rszemeti joined the community
Looking for an airbox for a M116....1974 Alpina 350....I'm in the USA
RESTOMOD joined the community
Hi, please see attached picture that's the one I'm looking for
anyone know where to get a good kickstand for my beta rev3
majesty replied to Theo1Jackson's topic in General Trials Talk
https://www.ebay.co.uk/itm/335964704682?_skw=beta+side+stand&itmmeta=01JWBNETYSV4ZDXTA083F26MH6&hash=item4e390e8faa:g:1CYAAOSwHn5oJ4jA&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1dNqfAsMuNA8W9g3U618jWbCw%2B58UW2nkSt0%2B%2F%2B%2BO1rojCvdV%2FmCc5bg7qH7LekqG9CRlfA%2BXvsZWIVVB%2BQthb8qdGuC1xtY3sp3AADBiqRMMbjr3dUhKS3kqhCIhl7aVTSRyYWkIutriR1Fv9vwAAo8VPdvCkvsCPj11lOG%2BYyLT5kqM4RrhB8DpU8mjvJYqmDfsbqAQublJ34iagvzUAnjT71nEblxQpP5yTDxK4C3%2F7FpI%2F%2BkZQwhqpdN3kDqoi%2FXiHdRzeebQVAaNSy2KCQcB0YHpfB8RZXHJNGOOXozg%3D%3D|tkp%3ABk9SR8ivu_XiZQ -
faussy replied to Theo1Jackson's topic in General Trials Talk
In the UK? Try Allens used trial spares on FB -
May be the last one Mitani tank available ...
There is no more space to fit adaptator like this.
Rotarypower101 joined the community
Theo1Jackson joined the community
The 2024 Sport has a clutch but cheaper wheels, suspension, console, and no phone app - but good enough for me
hi i have air box lid
After a bit more research (picking brains) it seems most likely to be for a 248 Cota. Surplus to requirements, so if you need one please drop me a line.
@ahell https://www.agbikes.co.uk/products/jitsie-keihin-carburettor-adaptor-pwk28
Hi, I will give them a call, thanks for your reply
Birkett Motorsport is close to you if you are still in Lancashire. He was the importer for Ossa and might be able to help you. You could read some of the posts in the Ossa section regarding this subject. You will have to do some digging from posts that are years old but it is what i did and over came the problems i had.
I had a brief ride with a cable tie holding the PRB lever in a bit. As near as I could get to the right spot appeared to provide some "engine braking" but it also put a dead zone into the throttle movement. One click more on the cable tie and there was about 90 degrees of throttle movement before anything happened. All this was done on a sloping field. I didn't venture into anything resembling a section. However the result was sufficiently encouraging to persuade me to go the next step with a potentiometer wired in. The parts have come so I'll be doing that over the next few days and then I'll go out for a little ride and decide whether I can live with dead zone.
In all likelihood there will be more then one capacitor involved, the big one connected to the fuel pump acts like a battery and would almost certainly be dedicated to the fuel pump which is the highest draw on the alternator.
Flash1 started following Ossa tr280i k-scan
Hi, does anyone know where I can get the k-scan software and lead for my Ossa TR280i.
I machined a keihin to 32.30mm to fit it into a remanufactured pipe. The original dellorto is 31mm. It fits without forcing. A quick dremel work to pop the pipe lug and remove the shoulder due to the original 26 diameter. I will test Josep Banyeres' sleeve to adapt the airbox. Otherwise I will install a TRS sleeve.
Canario started following Vertigo busto start poorly
Hello, I wonder, if the capacitor is only necessary for the fuel pump or if it is also necessary for the ignition while starting up the engine? Thanks in advance.
Nishijin started following TLR200 - 1983 vs other years
Hi all, I've bought a 1983 MD09 TLR200, so a 'proper' TLR200 vs the Reflex. The only Clymer manual I could see on Haynes is on its way to me, but I'm aware some parts may not be correct. For example it looks like front sprockets (JTF329) are different to the Reflex (JTF328). I've ordered the 329's (PO had it geared very high as a commuter...!) I want to buy a new coil/ht/cap as the original cap is a bit past-it and a spare in the box would be best. Online the only ignition coils I can see are for 1986/87. Any idea of a cross-reference for what parts are compatible between the 1983 and the 86/87? Thanks.
- Earlier
https://www.trialsbike.com.au/product/ossa-5020040211-air-filter-box-lid/ Was an Ossa dealer at the time, so he may still have a stand if you send him an email.
Had to do the same thing to my 250s forks due to wear but used bronze, am using 17mm aluminium axles plus magicals springs & the updated damper rods which work really well
