- Today
Took the Climber to our vintage trials last weekend. Worked great 👍 Fun bike!
New Trials Rider in Denver, CO - 2004 GasGas TXTPro Raga 300
RonH replied to mostexcellentdude's topic in Introduce Yourself
Nice looking bike! -
thanks it was spark plug indeed!
Hello everyone, My name is Eddie and I just picked up my first trials bike. I live in Denver, Colorado. Have experience riding a KTM 300 on mountain and desert singletrack, but never ridden trials before. Excited to get started! If anyone wants to show a newbie the ropes or suggest places to ride, let me know!
- 1 reply
- 1
mostexcellentdude joined the community
Spark plug
robson started following hiccups while on throttle
my gasgas 300 txt developed hiccups while on throttle, idle is fine where to look first?
Thanks so much! I was happy to have found them both. They are very original machines that have not been abused. Well, not yet
Vaughany joined the community
Restoring my one owner 1976 TY175C Yamaha purchased in Japan. I am installing a new piston & rings tomorrow. 80% done
I love all three of your beauties! Your TY looks fantastic (so does the Honda), it still has the tail and headlight on it along with the original plastics. Plus, I can see that awesome, pristine saddle you didn’t know you had. Thanks so much for the photos!
Hey gasaxe You DO NOT need to split the cases. You do not need to remove the engine. You can check, and fix, this quite easily with just the removal of the clutch side cover and the clutch pack. Under the clutch pack you will see were the shift shaft comes right through into the clutch case. On the end of it you will find a top hat shaped piece and spring (see link below for image) https://www.thehellteam.com/gearbox-selector-spring-assy It is more than likely this is the only piece that will need replacing, but even if the shaft is damaged (less likely) from 2012 GG made the bikes so the shaft could be removed with the removal of a small retaining screw and washer, and the hole thing can be wiggled out the right hand side. If you are stuck please feel free to PM or email me for help. Paul. The Hell Team
xavier777 joined the community
Sure thing! I also picked up this little beauty the other day! By the way, they both have titles!
Hey guys thanks for your advice. I will split the case before my son takes off and see if I can't get him to bring the parts home with him in mid November. My summer starts soon and I want to be riding asap.
https://trialssuperstore.com/collections/engine/products/gasgas-shift-shaft-center-locator-and-spring This is the first part to check. that little thin piece of metal is designed to shear. The spring is included and zipped tied as it`s hard to install the spring. Its possible to weld this back together, just the spring is hard to deal with. Good luck, it`s probably one of these parts have failed. The top hat is the easiest to fix.
Shaft Shaft MT280238043 https://trialssuperstore.com/products/gasgas-pro-gear-selector-shaft But the shift drum may be damaged as well. Shift Drum MT280238031 https://trialssuperstore.com/products/gasgas-gear-selector-drum I would disassemble and inspect prior to buying any parts. Trials Superstore is only one example vendor. KTM dealers can also sell those parts.
gasaxe started following Gas gas TXT 250 shifting gear box problem
New member. I wish I had found this form years ago. I have a 2012 TXT 250 I ride near every day. Went to town for milk and bread and when I tried to gear down to 3rd it would not click in. I rode home in forth and drained the oil. It was clean. Topped up the gear oil and went for a short ride. 3rd 2nd 1st now work but no 4th or 5th. It's now parked. I'm in Central America. Parts are limited. My son is going to California in a week and thought maybe he can get what I need to fix my gym on wheels. This bike keeps this old man healthy and fit. Any advice much appreciated. I'm thinking this is the problem in the screenshot attached
gasaxe joined the community
you mean this is problem or not because i dont uderstand can u help me if u have same problem?
The weld broke on the shift shaft. You need to take the clutch off to get the shaft assembly out.
lil started following beta evo 300 4t 2009
I have a problem with the gear shifter. When I shift up, it stalls and the shifter gets stuck up and doesn't go down, but from up to down it goes easily. What could be the problem?
lil joined the community
hello cona i have the same problem can u tell me how can i changeo or to contact u if its the same problem
If it didn't need the ball bearing then they could have made the rod in one piece, if there was no bearing then the ends of the 2 actuator rods would at the very least be rounded and hardened where they contact each other similar to a valve pushrod end. The ball bearing in theory reduces the friction significantly and only needs to spin at half the rate of the 2 rods, it's actually brilliant to have it in there and would serve no purpose to leave it out. How about measuring the straight rod length and have somebody confirm the straight rod part is original 🤓
mcman56 started following Yamaha TY175 Clutch Issue
The parts list shows one but I don't remember if mine has one. https://www.tytrials.com/trailandtrialsuk/cat_57217-Clutch.html
I just wanted to give a shout-out for Custom Hoses (customhouses.co.uk). I ordered a special brake hose at lunchtime on Friday. It was made on Friday afternoon and delivered by Royal Mail on Saturday morning. No connection except as a very satisfied customer.
Best two trials focused helmets with good venting in my opinion is the Hebo Zone 4 and the AIROH TRR/TRRS. I have both and find them nearly the same over all performance on a hot day if I had to pick one as the best I would lean on the AIROH but only just.
Did this get resolved as I seem to have the same issue
