- Today
Got a couple more questions as the bike takes shape, the cooling fan or rather the thermostat/sensor any ideas what the resistence readings should be or how long it would need to idle for before the fan kicks in? My sensor was reading 8 MegOhm reducing to 4 MegOhm after about 10 minutes and the water hoses and rad were all hot but no fan , I know the fan works as I have shorted the sensor and it ran fine. The other issue looks like the clutch plates have swelled due to the water in the oil , any ideas what thickness a new friction plate should be and if i could take a grinder/file to them to reduce them somewhat? The bike starts but clutch drag means I cannot change gear when the engine is running so need to rectify this before I can try the Techno out anywhere apart from my back garden , TIA
Millwoodva started following '98 TX270 - Clutch Tappet Rod Bearing
The needle bearings are exposed on one side only. I did not take note on disassembly. Do the bearings roll on the tappet or the backing plate... Thank you in advance.. Jeff
I had a really good feel for my old (2021) bike with a 51T sprocket on it. Foolishly I left it on when I changed the bike, thinking it would be easy enough to get another one for my new (2023) bike. It's not. I can't find one anywhere. Does anyone one have one to sell, or know where I could get one? 51T preferred but I would go with 50T or 52T too.
Sherco rear tank gas cap https://www.crealitycloud.com/model-detail/sherco-gas-cap Magnet lanyard kill switch https://www.crealitycloud.com/model-detail/trial-magnetic-lanyard
Tried that but never got a reply in fact he did not open the message! Facebook Messanger is notorius for not flagging up new messages especially first time contact.
If you're in the UK, Birketts will be able to do it for you.
I have since come across a pic of a second ISDT Saracen ridden in the 1972 Welsh 2 Day Trial by Steve Wilson who retired after crashing. The reg letters appear to be GJH but actual number not clear, so probably GHJ 59K or 61K . Does anyone have any other pics of that bike?
Is the telephone number for Jon Bliss (01242 239055) still valid as I have tried phoning him several times on that number but no reply and does not go to voice mail. This thread is 19 years old so he may have changed his number in that time.
Thanks @feetupfun, I didn't know that, and it sounds promising because it explains dry cylinder and plug. I shall try and undo my actions, and will report back. The new carb is a VM26-8074 from Motocarb.
jimmyb74 started following Central Ohio riders
Are there any riders in central Ohio that would welcome a newby into their group? Looking to get back into riding trials again, just wanting someone to ride with and show me the lay of the land. thanks
There's a few possibilities here. Most likely is because you have wound in the idle speed screw, the slide might be too high for the start device to function. If it's a modern carb, the starting device is not a choke. Modern starting devices use the pressure difference across the slide to draw fuel through the cold start circuit and if the slide is too high, not enough pressure difference will be generated while kicking, to draw fuel through. If winding the idle speed screw back out again doesn't solve the problem, narrow the range of possibilities by putting a couple of drops of fuel into the cylinder via the plug hole, then see if it fires.
got a manual for a 2017 happy to send it to you PM me your direct e mail addrress and I'll send it via wetransfer
Hello yes It was from SW trials as you thought. For the purchaser with money to burn?
ebay uk now GasGas TXT 250 270 280 AJP Clutch Lever ( M/C + Lever + Hose ) £50 . Item no 116709663436 MX & Trials Spares WS6 6LS Tel 07872329743.
Hi does anyone still have a workshop manual for a 2016 please ?
arden started following master cylinder needed
I need to find a clutch master cylinder for a gasgas txt 280 2001 model. Any hints would be grateful
As trials central is a UK site, I'm assuming you're here ?
Describe the symptoms, there is a huge knowledge base available here, you might be able to do a lot or all the work yourself, as motorcycles go it's not a hard one to learn to work on, almost for certain the original bike purchase included a very good parts and service manual, you need one 👍
Stevenl joined the community
John Walmsley started following Montesa information
I have just purchased a 1978 Montesa 348, can any one point me in the direction of a specialise who can do work on such bikes? Looking at manly engine/gearbox including full rebuilds, Kind Regards John
skyefarmer started following 1978 TY250 resurrection
A 1978 TY250 was left in a stable of a house I bought. After 20yrs of looking at it, I thought I'd get it going. The job was nearly done, but I fear I've just messed it up. The last step was installing a new carb, after which it started fine (multiple times) and sounded decent but did not have enough revs to tick over when the throttle was released. I was adjusting the Idle Adjust Screw, turning it clockwise, and starting to observe an increase in idle revs, when I realised I'd left the choke on. I turned the choke off, and the engine died. Since then I have not been able to start the bike. Not even close. Suspecting that after many failed starting attempts I had flooded it, I drained the carb and removed the plug. Neither the plug nor the cylinder was wet with fuel. Good spark observed outside the bike. Checked there was fuel to carb. Refilled fuel tank. If anyone has any suggestions I'd love to hear them. Thanks.
skyefarmer joined the community
1974 TY250A - Does the Shedworks Tank/Seat Combo work?
feetupfun replied to onefunride's topic in Yamaha
The tank seat shown on the B&J Racing page is fibreglass and is a Sammy Miller Products tank seat and may be old stock. When you said the A model is lighter than the later ones, do you mean the whole bike or the fuel tank? The CDE models have the lightest rims, being Japanese copies of the lightweight AKRONT trials rims. The A model have lightest swingarm. CDE swingarms have more elaborate gusseting near the pivot. The BCDE flywheel is much heavier than the A model. The BCDE engine covers are lighter than the A model. The lightest tank I've found is a Majesty shape made from very thin aluminium. I bought it from France Trial Classic in about 2008. It dents very easily. I'm not sure if they are still available, but there is/was an aluminium steering stem/axle available. It is a lot lighter than the original. Also the top bolt and slotted nut for the steering axle. There is/was an aluminium swingarm inner bush available. I replaced all the wheel axle spacers with aluminium items. -
onefunride replied to onefunride's topic in Yamaha
Feetupfun, thank for the clarification, it shed some light on my confusion. I do have the WES exhaust, and a few other items installed already. I have the forks setup using the InMotion aluminum damper rods and Trials France magical springs. I have an original fuel tank that is in fantastic condition, I am nervous about smashing it up, which sent me down the path of looking for a different fuel tank and possibly a weight saving in the process. The Shedworks tank and seat assembly looks fantastic, but it gets quite pricey to ship to the US. Interestingly, according to the internet the A version was lighter than the later TYs. Possibly a Majestic tank, long fender, and a late model seat with fiberglass pan could be a good option. Something like the attached pics. BJ Racing has a tank seat combination that looks much like the Shedworks, but I think it is all fiberglass and does not have the inner aluminum tank. http://bjracing.com/id121.html hard to tell. -
congngherfid joined the community
quattreotuongpanason joined the community
You can load up photos here,click on add files and you will be able to upload photos
The 10w40 should be more than up to the job unless it’s very poor quality. These things will happily change up and down without the clutch just by matching the revs. My gearbox is 20 years old and never been touched!! I have always found 10w40 to stand up better to heat and more abuse than Elf and light gear oils. The lights ALWAYS give a better clutch when cold but they get very grabby and snatchy when working hard. I run Motul 300v factory line for both engine and gear box. **** when cold, but isn’t affected by heat and hard riding. Another thing with the Mont clutch is that you generally need full pull of the lever to find neutral. Any fingers between the lever and bars makes finding neutral tricky. Using the short lever helps, then it’s just 1 finger right at end next to the ball.
By pre65wobbler
17 days and 17 hours
