Everything posted by mont
rattly clutch
no thats just how they are, they all do it
RENTHAL "420" CHAIN CONVERSION!
hi I run this conversion on my 225 it runs alot smoother as the front sprocket has more teeth on. Previosly I ran a 9 tooth so it used to eat sprockets and wear chains. When you spin the wheel it runs reely smooth now.
Polished hubs
Hi try a tooth brush with solvo atosol metal polish and plenty of elbow grease and a lot of patiance.
125 vs. 250 Gas Gas Weight
.yes I ride a 225 and it dose feel smaller and lighter than my 250 used to. Billy you will have to have a go next time I see you.
- Gasgas Sump
Hi try Simon at Kelcote in Leek, he has loads of second hand gas gas pro bash plates. 01538 383547. He is a top man and will help you out with most bits as he has one or two pro s the he is breaking.- New Gas Gas 250
Im on my 3rd gas gas and can highly recomend them, you wont be disapointed ENJOY!- Differences Between The 2004 And 2005 Txt Pro?
Hi , had a 2004 for 5 years and it was a fantastic bike . No problems and road very well. I now have an 09 gas gas but have kept the forks off my 04 they have a much nicer action . hope this helps.- Pro 225s.how Many Are Out There?
HI got an 09 one and its the dogs dangly bits, realy nice to ride.- Rear Wheel Bearing Txt 280
Hi boil the kettle and pour over hub making removal of bearing alot easyer,- G G Silencer
Dooh no rivets in an o4 silencer, so just cut the end where the rivets would normaly be. Then follow previous instructions and reweld.- Durafix....can I Use In On The Exhaust Box?
I am a welder by trade and have never seen this before. Looks like agood product have a go should do a good job- Frame Protection
Try Birkets first, if not kelcote in Leek will powder coat your frame better than new.- Custom Frame Design
Now youve got me thinking, how about a new frame for my gas gas in titanium. I am a fabricator just seems like their might be a market out there for someone?- Video
Hi had simular problem with mine. You have to download the disc that came with the camera so that the computer can read your sd card.- Sheffield 2009
HI no your not going mental, they did promise one last year but there was no show. somthing to do with technical problems?- Idling?
- Bike Not Revving Out !
check the rubber flap that suposed to stop muck entering the air box is not blocking the air intake. I had this happen and it wouldent rev out. I now zip tie the end to the frame next to the back break master cylinder, revs out cleanly now.- I Want To Buy A New Bike
All the bikes are better than most riders. I sugest ride all of them and see which suits you best, theirs not realy abad one.- Raw Sports Trousers
Hi had complete kit for ayear and a half and still going strong. Its made by hebo so it must be ok.- Plug Gap
- Sherco Brake Squeal
I HAD THE SAME PROBLEM WITH MY BACK BRAKE TURNED OUT, IT WAS LEAKING FLUID, REPLACED SEALS, CLEANED DISC WITH BRAKE CLEANER AND FITTED A SET OF D.P. PADS. WORKS BRILLIANT NOW - NO SQUEALING. GOOD LUCK. - Gasgas Sump
