Importance Of Proper Suspension Spring Rate And Setup ?
Ok looked around couldn't find anything, so here goes. Coming from a dirtbike background where proper suspension setup is key, sag, static sag, preload oil weight etc, and now in the trials world I'm being told that spring rate not important unless you are a top level rider. Im curious is this true ? I have a stock suspension 2015 Beta 300 4T and weigh 200lbs and was thinking of getting the stiffer spring rates, will this help with an Intermediate rider ? I did notice in the owners manual heaviest weight for the stock suspension was something like 178lbs.
I think there are many 200lb riders that do just fine on stock springs, however the rear one is typically the first one to change if desired. If you were at #220 I would say go for it for sure.
The Ohlins shock is a good upgrade as well for most. All it takes is money!
I also race Mx/Enduro and found the same regarding trials bikes, the suspension doesn't seem to be a concern with riders.
I'm quite heavy and thought my beta was sat low at the back, I've had a few people say it's fine but fet it was loosing front control. I didn't find much advise online so set the bike up as I would my ktm and now it feels great. The rear is higher giving good front control, splats and drop-offs are well cushioned t's like a different 'easy to ride' bike now!
I disagree.
http://www.trialscentral.com/forums/topic/58492-v-mar-linkage-or-similar/
http://www.trialscentral.com/forums/topic/14152-suspension-set-up-4rt/
http://www.trialscentral.com/forums/topic/47117-2006-4rt-suspension-settings/
http://www.trialscentral.com/forums/topic/43044-4rt-suspension-setup/
http://www.trialscentral.com/forums/topic/39441-how-to-know-when-to-re-do-suspension/
http://www.trialscentral.com/forums/topic/54995-do-i-need-stiffer-springs-on-my-4rt/
http://www.trialscentral.com/forums/topic/42440-adding-nitrogen-to-rear-suspension/
http://www.trialscentral.com/forums/topic/12917-suspension/
http://www.trialscentral.com/forums/topic/24273-standard-suspension-settings/
http://www.trialscentral.com/forums/topic/41605-suspension-linkages/
http://www.trialscentral.com/forums/topic/15504-suspension-setting/
http://www.trialscentral.com/forums/topic/55088-a-thought-about-toni-bous-suspension/
http://www.trialscentral.com/forums/topic/16697-performance-suspension/
http://www.trialscentral.com/forums/topic/55283-suspension-setting/
http://www.trialscentral.com/forums/topic/7735-sy-250-2006-suspension-set-up/
http://www.trialscentral.com/forums/topic/37579-problems-with-sag-settings/
http://www.trialscentral.com/forums/topic/49929-suspension-sag/
http://www.trialscentral.com/forums/topic/56876-why-no-service-manual-suspension-setup/
http://www.trialscentral.com/forums/topic/6476-06-280-pro-suspension-setup/
http://www.trialscentral.com/forums/topic/13346-on-the-rebound/
http://www.trialscentral.com/forums/topic/15307-suspension/
http://www.trialscentral.com/forums/topic/41364-setting-sag/
http://www.trialscentral.com/forums/topic/33029-static-sag/
http://www.trialscentral.com/forums/topic/53167-merits-of-a-heavier-spring/
http://www.trialscentral.com/forums/topic/33156-315-showa-forks-oil-quantity-and-air-gap/
http://www.trialscentral.com/forums/topic/57958-which-rear-shock/
http://www.thumpertalk.com/topic/646855-how-to-set-shock-spring-preload-sag-on-trials-bike/
http://www.thumpertalk.com/topic/1160321-1999-gg-321-suspension-click-settings/?hl=%2Bsuspension
http://www.thumpertalk.com/topic/1113051-suspension-set-up/?hl=%2Bsuspension#entry12039718
http://www.thumpertalk.com/topic/987387-linkage-greasingmaintenance-rear-shock-questions/?hl=suspension#entry10339441
http://www.thumpertalk.com/topic/942328-setting-up-a-trials-bike-for-a-tallheavy-rider/?hl=suspension#entry9856785
http://www.thumpertalk.com/topic/932817-gg-txt-pro-02-fork-setup-question/?hl=suspension
http://www.thumpertalk.com/topic/927764-sherco-suspension/?hl=suspension#entry9714622
http://www.thumpertalk.com/topic/924112-spring-rate-recommendation/?hl=suspension
http://www.thumpertalk.com/topic/902862-ohlins-is-it-worth-it/?hl=suspension#entry9401141
http://www.thumpertalk.com/topic/893152-suspension-travel/?hl=suspension#entry9314072
http://www.thumpertalk.com/topic/883442-fork-oil-change/?hl=suspension#entry9190798
http://www.thumpertalk.com/topic/877421-rear-shock/?hl=suspension#entry9129531
http://www.thumpertalk.com/topic/874063-gasgas-rear-linkage/?hl=suspension#entry9101679
http://www.thumpertalk.com/topic/843961-suspension-set-up/?hl=suspension#entry8753313
http://www.thumpertalk.com/topic/838092-suspension-question/?hl=suspension#entry8671283
http://www.thumpertalk.com/topic/618690-03-montesa-shock-nitrogen-pressure/page-3?hl=suspension#entry8588908
http://www.thumpertalk.com/topic/794385-basic-setup-on-315r/?hl=suspension#entry8210537
http://www.thumpertalk.com/topic/778788-suspension-set-up-txt321/?hl=suspension#entry8126995
http://www.thumpertalk.com/topic/762342-difference-in-springs-gg/?hl=suspension#entry7814977
http://www.trials.com.au/forum/viewtopic.php?t=3334
https://trials.com.au/forum/viewtopic.php?t=3500
https://trials.com.au/forum/viewtopic.php?t=852
http://www.trials.com.au/forum/viewtopic.php?t=1008
https://trials.com.au/forum/viewtopic.php?t=2795
https://trials.com.au/forum/viewtopic.php?t=8606
https://trials.com.au/forum/viewtopic.php?t=10271
https://trials.com.au/forum/viewtopic.php?t=9379
http://www.trials.com.au/forum/viewtopic.php?t=6254
http://www.trials.com.au/forum/viewtopic.php?t=10091
http://trials.com.au/forum/viewtopic.php?t=10248
https://trials.com.au/forum/viewtopic.php?t=8449
That's the crank up the preload vs heavier spring argument. Get the next size up springs from Steve Saunders. That's what I have on my '13 EVO. When you chrank up the preload you lose some of the suspension compliance for the smaller stuff so the bike gets a bit skittish.
Been riding nearly 50 years never bothered with suspension settings! Might have made a difference... Might not
I weigh 245 lb and put the heavier springs in. The bike seems to feel a bit better than stock did.
People said the same about suspension when they were all riding rigids.
It must make a difference as it wouldnt be adjustable. We are not all the same size or weight.
Are you saying you dont adjust the position of your bars levers or carburettor either??
Cranking up the preload or getting a heavier spring do two different things,increasing preload does not change the spring rate at all.
Comparing trials with MX is not really valid. In MX a couple of clicks on the rear damper or a change of 2.5 wt in the fork oil can make several seconds a lap difference. Make the same changes on a trials bike and it probably will not change the number of marks lost.
Trials bikes capabilities are now so far ahead of most riders capabilities, having the suspension a bit off ideal hardly matters. If you are heavy putting on a stiffer rear spring is worthwhile because in most section where grip is important most of the weight is on the rear wheel. Generally not worth putting stiffer springs in the front end because you want them soft on uphill sections and easy to compress and complient in tight turns. If the bottom out on drop offs or crossing the fell raise the oil level a few mm and use a slightly thicker grade.
Sorry I have to completely disagree with you on this. The reason it makes such a noticeable difference on MX or road race bikes is because you are making the bike suit you and you riding style and maintian grip. It's actually much easier to ride round a minor issue on a road race setup than it is on a trials bike. If the bikes kicking of obstacles you've got no grip or no steering. Loosing marks becomes very easy. Your riding on your own it's not like racing where cleaver tactics can keep people behind you!
I would have to say trials got easier after I set my supention up correctly.
