February 22, 201610 yr Hi All Just curious about what others are running on 290 sprockets? I'm finding that whenever I do a steep or muddy uphill, the back wheel spins up and I either come to a stop or slide away to one side... Now some of it is definitely me and my novice experience but I don't have the same problem on an enduro and its not all the tyres... so gearing is the next thing I was thinking of unless others have any suggestions?
February 22, 201610 yr Unless you have your suspension way too hard and you have decent tyres at the correct pressures, then its all about technique I'm afraid. Have you tried using different gears/revs/speeds on the same hill again & again to see what difference it makes? Edited February 22, 201610 yr by tshock250
February 23, 201610 yr Bend your knees and use de space available where supoded to be the seat and tank. Bike need weight on right spot. Maybe your body is too in front of the bike loosing traction or too high making wheeling.
February 23, 201610 yr You have to treat trials tyres differently. If the rear starts to spin, you have to back off the throttle to get grip back. A spinning trials tyre=useless, which is quite different to a spinning knobby. It's a common mistake for people moving from enduro bikes to trials bikes The rear tyre grip thing is why trials bikes engines have more flywheel effect built in than MX or enduro bike engines
February 23, 201610 yr Author here is the pic of the rear tyre.. its a Michelin X11 run at about 3-4psi in the wet, 6 in the dry, no issues in the dry ever, but nightmare on wet grass and mud... I'll check rear shock settings but its pretty soft so then it's more practice required me thinks!
February 23, 201610 yr definitely well past its sell by date.... would be ok when its dry or rocky but you will struggle in the mud with that, you will be amazed at the difference a new one would make
February 23, 201610 yr definitely well past its sell by date.... would be ok when its dry or rocky but you will struggle in the mud with that, you will be amazed at the difference a new one would make :blink: Looks to me like it's still weeks away from needing to be turned?
February 23, 201610 yr Enduro tyres grip far more than trials tyres do in mud,but your tyre has gone well past its best before date .Get a new Michelin,it'll be miles better.Once the square edge wears off the grip diminishes noticeably
February 24, 201610 yr I've never ridden on a tyre that good. Pick a hill that you can ride 8 or 9 times out of 10 and try the following.... Squat into the bike leaving just a couple of inches clearance, a*** around the shock area a little further back than your feet. Accelerate as much as possible in a short distance before the hill. Let your legs take up some of the movement so the suspension doesn't have to do all of the work. Try to maintain just enough momentum to get to the top by gently rolling off. Then try it repeatedly with different fixed body positions, then try moving your body mid hill, then try shorter run ups which will necessitate more work with the throttle, then try a different hill, you'll end up with a feel for it.
