Show Me Your Twin Shocker!
John, You will find it OK, it is only mind over matter anyway.
There is no way cable rears ever did work ref. my first Lobito Mod 19 or 20
whatever it was.
Have a good day
Larry
Edited by lbhbul
  • Replies 417
  • Views 242.8k
Most Popular Posts
  • Hi, First post on TC,but have been gleaning as much info on the Mar on TC  as I can over the last year.Some very helpful information from all those who love Ossa's. Pic is of my Mk2 Ossa. Taken appr
  • My OSSA TR77 Verde 1979 The footrests have been relocated lower and rearward a Mikuni VM26 fitted with pleasing results, Saftek brake linings make it stop well and rear tail silencer made from an
  • Here's my 81 TLNW 125.
I'm seriously thinking of making some kind of rod, that goes from the right to the left, so I can get rid of the cable, but still have the brake pedal on the right.
whatever it was.
Have a good day
Larry
They do, as I've ridden two or three bikes with very effective rear cable brakes, one only yesterday.
I can't make mine work though...... even with relined hub, longer arm etc.
Woody, If you cant make it work, join the club.
The only good answer is a later Alp/Pursang rear, and they
are much in demand here.
Guess someone knows.
Regards
Larry
Whilst I have no first hand knowledge of the effectiveness of Bulto cable operated rear brakes, there is no good reason that a cable rear brake should not work satisfactorily. Many British sports twins of the 50/60s utilised them, such as BSA A7SS. I have a Cotton 37A with a cable rear brake, that has plenty of feel and passes MOT. Period cable front brakes work with reduced hand pressure. Perhaps, as previously suggested, it's some inherent design issue within the shoe mechanism, rather than the cable.
You need a very thick cable and a reinforced (and stiff) cable hose with a deflection tube were the hose is attached to the swingarm, most replica solution have far too little diameter for the cable and thus to the hose, when you then operate the foot brake much of your initiated force will be used to compress the hose instead to be used as breaking power.
In all fairness to the engineering of the Sherpa t Mod 199 (1978) & on rear slowing device.
Over here I believe it was not politically correct to import any without right hand brake.
The bikes came with the mounting stud & thru shift shaft, so hence whatever turns you on.
Have a nice day
Larry
  • 10 months later...
My project KT250r, r for rebuilt, radical, ruined etc you choose
The bottom two pic's are of the first test fitting of the soon to be modified plastics, and the tank before final welding.
Not much to change on the Gasgas guard, what luck!!!
Edited by still trying
To show finished bike
the chain system is my own evil concoction to get around putting the swing arm pivot on the rear engine mount.to move the center of gravity back, without changing the engine casing (cut and weld a block in). I did try to not change any of the original parts, so I can still rebuild an original KT if I wash.
So many interesting features on that KT project. The more you look the more you find. Fascinating!
  • 3 weeks later...
First thing that hit me was the rake. That's a serious angle for a Vintage bike. I love all of it though.
Beautiful work! Lots of thought. Bet the floor around your work area is wore out from just walking around it and staring. Can't wait to see some feedback on how it performs. Will it be done in time for any events this year?
